Jamo174 0 Posted April 13, 2018 Posted April 13, 2018 Hi I have installed on my Samsung tv but need to enter IP address for emby server where do I find this?
Luke 42210 Posted April 13, 2018 Posted April 13, 2018 Hi there, have you setup your own Emby Media Server?
Jamo174 0 Posted April 13, 2018 Author Posted April 13, 2018 Hi Luke no new to this sorry how di I do that? I have loaded on to my Tv but asking me now for IP address, I tried putting in my ip but didn't work.
Luke 42210 Posted April 13, 2018 Posted April 13, 2018 I would suggest checking out our quick start guide to learn how you can get started with Emby Media Server: https://github.com/MediaBrowser/Wiki/wiki/Quick%20start Please let us know if this helps. Thanks !
Jamo174 0 Posted April 13, 2018 Author Posted April 13, 2018 Ok thank you. So how do you get invited to share a server?
ebr 16310 Posted April 13, 2018 Posted April 13, 2018 Hi. Emby is a personal media server for your personal media. Either you or a friend or family member need to have content and setup a server.
Sucramhtes 0 Posted April 13, 2018 Posted April 13, 2018 Hi, I just joined Emby and I am enjoying it on my mobile devices. I have downloaded the app on my Samsung TV and can see my server but when I try to connect it gives me a connection failure. I don't have any issues connecting to the content on my iPad on the same network so I don't think it's a firewall or port issue. Any help would be greatly appreciated.
Luke 42210 Posted April 13, 2018 Posted April 13, 2018 Hi, I just joined Emby and I am enjoying it on my mobile devices. I have downloaded the app on my Samsung TV and can see my server but when I try to connect it gives me a connection failure. I don't have any issues connecting to the content on my iPad on the same network so I don't think it's a firewall or port issue. Any help would be greatly appreciated. How exactly did you try to connect? Did you enter the server address manually into the Samsung app?
Luke 42210 Posted April 13, 2018 Posted April 13, 2018 Try opening up your emby server dashboard and check the local network address that is displayed. is this value correct? this is what the app will be using to connect with. thanks.
Sucramhtes 0 Posted April 13, 2018 Posted April 13, 2018 (edited) The tv can see the server and a friends as well. But I get a connection error on both. Edited April 13, 2018 by Sucramhtes
Luke 42210 Posted April 13, 2018 Posted April 13, 2018 Can you please try opening up your emby server dashboard and checking the local network address that is displayed on the front page? is this value correct? this is what the app will be using to connect with. thanks.
Sucramhtes 0 Posted April 14, 2018 Posted April 14, 2018 Hi, I can now connect to my server, but can not connect to my friends. Any suggestions?
Luke 42210 Posted April 14, 2018 Posted April 14, 2018 Hi, I can now connect to my server, but can not connect to my friends. Any suggestions? Hi, ask your friend to check out our Connection Troubleshooter. Please have them try the steps listed there. Thanks.
Sucramhtes 0 Posted April 14, 2018 Posted April 14, 2018 Could the issue be that I downloaded ver. 1.0.39?
Luke 42210 Posted April 15, 2018 Posted April 15, 2018 No, I think your friend needs to setup his server for remote access.
Sucramhtes 0 Posted April 15, 2018 Posted April 15, 2018 I can access the my friends server on the network with all devices except my Samsung tv. I am using the latest rev of code. I’ve port forwarded both 8096 and 8920.
Luke 42210 Posted April 15, 2018 Posted April 15, 2018 If it's his server then he is the one who had to do the port forwarding. Can you check with him on that? Thanks.
Sucramhtes 0 Posted April 15, 2018 Posted April 15, 2018 (edited) But why would it work on every device but the TV? Edited April 15, 2018 by Sucramhtes
Sucramhtes 0 Posted April 15, 2018 Posted April 15, 2018 (edited) I can login either way. Https://xxx.xxx.net:443 or Http://xxx.xxx.net:80 Edited April 15, 2018 by Sucramhtes
Luke 42210 Posted April 15, 2018 Posted April 15, 2018 Well if it's https you will need to tell him to make sure that Samsung devices will accept his SSL cert. If it's a self signed cert, Samsung will not allow that and he'll have to allow http.
