berrick 30 Posted March 23, 2014 Posted March 23, 2014 Hi, Apologies if this had already been covered. Is it possible to add items to the top level menu Can you excluded items from a top level menu The reason I ask is that I have a library called cartoons which I would like to appear on the TLM and not be part of TV. If it cant be done now is it something which will be at some point in time? thanks muchly 1
yaksplat 68 Posted March 24, 2014 Posted March 24, 2014 (edited) I'd also like to have a folder type that excluded from library. The type is movie, but do not include the items in movies, or the type is TV, but don't include these items in TV. Possibly a check box, "Exclude from main libraries (TV or Movies)" Edited March 24, 2014 by yaksplat
