FlashTMH 0 Posted April 12, 2018 Posted April 12, 2018 Hi,i would like to activate the vaapi hwacc support on my system, but ffmpeg will be start without vaapi options.What am I doing wrong.Thanks for your support.System Info Intel® Core i5-7500 CPU Debian 9.4 vainfo (package from buster (testing) repo)error: can't connect to X server!libva info: VA-API version 1.1.0libva info: va_getDriverName() returns 0libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.solibva info: Found init function __vaDriverInit_1_0libva info: va_openDriver() returns 0vainfo: VA-API version: 1.1 (libva 2.1.0)vainfo: Driver version: Intel i965 driver for Intel® Kaby Lake - 2.0.0vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Simple : VAEntrypointEncSlice VAProfileMPEG2Main : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264Main : VAEntrypointEncSliceLP VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264High : VAEntrypointEncSliceLP VAProfileH264MultiviewHigh : VAEntrypointVLD VAProfileH264MultiviewHigh : VAEntrypointEncSlice VAProfileH264StereoHigh : VAEntrypointVLD VAProfileH264StereoHigh : VAEntrypointEncSlice VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice VAProfileHEVCMain10 : VAEntrypointVLD VAProfileHEVCMain10 : VAEntrypointEncSliceinstalled deb package from githublogfile/opt/emby-server/bin/ffmpeg -noaccurate_seek -i file:"/mnt/movie/serien/Suits/s04/Suits.S04E01.mkv" -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -bsf:v h264_mp4toannexb -copyts -vsync -1 -codec:a:0 aac -strict experimental -ac 2 -ab 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 6 -individual_header_trailer 0 -break_non_keyframes 1 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/lib/emby/transcoding-temp/e3dd8e415881b6ab39ac1bf963d9e7a0.m3u8" -y "/var/lib/emby/transcoding-temp/e3dd8e415881b6ab39ac1bf963d9e7a0%d.ts"
Luke 42245 Posted April 12, 2018 Posted April 12, 2018 Hi, there's no transcoding in this log. It is stream copying the original video as-is, therefore no gpu transcoding is needed.
FlashTMH 0 Posted April 12, 2018 Author Posted April 12, 2018 Oh sorry, my mistakePlease see this log from a transcoding pvr record of ip tv stream.This should be a trascode or do I have a mistake again?Thanks for youre help. /opt/emby-server/bin/ffmpeg -async 1 -vsync -1 -fflags +igndts -analyzeduration 5000000 -i "rtp://@239.35.20.21:10000" -t 00:08:46.457 -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -vf "yadif=0:-1:0" -pix_fmt yuv420p -preset superfast -crf 23 -b:v 25000000 -maxrate 25000000 -bufsize (25000000*2) -vsync -1 -profile:v high -level 41 -fflags +genpts -map_metadata -1 -threads 0 -codec:a:0 aac -strict experimental -ab 320000 -sn -y "/srv/emby/rec/The Middle/Season 3/The Middle S03E05 Der Test.mkv"
Luke 42245 Posted April 12, 2018 Posted April 12, 2018 Please attach the complete ffmpeg log. thanks.
FlashTMH 0 Posted April 12, 2018 Author Posted April 12, 2018 (edited) Thanks record-transcode-8955075e-8df2-4dce-aeb9-4368a462d444.txt Edited April 12, 2018 by FlashTMH
Solution Luke 42245 Posted April 12, 2018 Solution Posted April 12, 2018 Ok, we don't currently use it with the recording transcoding feature, but if you try to play media that requires transcoding then it will be used. thanks. 1
FlashTMH 0 Posted April 12, 2018 Author Posted April 12, 2018 Thanks for your fast reply and the great project emby
