andyblac644 69 Posted April 15, 2018 Author Posted April 15, 2018 (edited) Please try the next beta, thanks. @@Luke @@ebr sorry but just the same. 2018-04-15 16:21:39.449 Application version: 3.3.1.18 Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (eac3 (native) -> ac3 (native)) logs-6.zip Edited April 15, 2018 by andyblac644
Luke 42242 Posted April 15, 2018 Posted April 15, 2018 @@ebr you'd need to add eac3 to the requested audio codecs.
ebr 16335 Posted April 16, 2018 Posted April 16, 2018 Andy - you are positive you are running the current beta of the Apple TV app (force-restart it) and this is on an apple TV 4k...
andyblac644 69 Posted April 16, 2018 Author Posted April 16, 2018 (edited) Andy - you are positive you are running the current beta of the Apple TV app (force-restart it) and this is on an apple TV 4k... yes, AppleTV 4K, MediaRoom tvOS 1.2.04 (Beta), I force restart every time I go to box as this is the only way I can get a updated front page, else it does not see the days newly added files. Edited April 16, 2018 by andyblac644
andyblac644 69 Posted April 16, 2018 Author Posted April 16, 2018 @@ebr just tried again and just the same. logs-7.zip
Senna 368 Posted April 16, 2018 Posted April 16, 2018 Didn't read this whole thread, but has this something to do that Apple broke audio passthrough in tvOS 11.3 ? https://forums.developer.apple.com/message/302920#302920 Apps like Infuse and MrMC had to do workarounds for this issue.
ebr 16335 Posted April 16, 2018 Posted April 16, 2018 Didn't read this whole thread, but has this something to do that Apple broke audio passthrough in tvOS 11.3 ? https://forums.developer.apple.com/message/302920#302920 Apps like Infuse and MrMC had to do workarounds for this issue. DD Pass-thru still working fine for me as of today on 11.3. This issue, though, is about doing a stream copy on DD Plus when re-muxing due to the container.
Senna 368 Posted April 16, 2018 Posted April 16, 2018 When you have a multi channel PCM receiver, all is fine indeed. More info here : https://forum.mrmc.tv/viewtopic.php?f=15&t=3991
andyblac644 69 Posted April 16, 2018 Author Posted April 16, 2018 (edited) When you have a multi channel PCM receiver, all is fine indeed. More info here : https://forum.mrmc.tv/viewtopic.php?f=15&t=3991 as @@ebr says, this is about DDP stream copy, to stop emby server transcoding to AC3, as the AppleTV 4K can do this internally, it works fine when in a MP4 so it should be able to do it when remuxing from a MKV. Edited April 16, 2018 by andyblac644
