Damob9k 2 Posted April 10, 2018 Posted April 10, 2018 Hi all, Using Emby server 3.3.1.0 DVB Viewer Pro v6.0.4.0 DVBVservice v1.33.2.0 DVBSource v3.9.5.0 ET 3.0.0 I am unable to delete any recordings either from ET or the web interface. The recorder file path is the same in both Emby and DVBViewer. The only way I am able to delete recordings is to go into the web interface of DVBViewer>Recordings> then select Delete. Any ideas ? Cheers Damian
Luke 42244 Posted April 10, 2018 Posted April 10, 2018 Hi, what do you mean unable to? What happens when you try?
Damob9k 2 Posted April 10, 2018 Author Posted April 10, 2018 Hi Luke, I click \ select Delete, select Yes and it just closed that popup and the recording is still there. Even after a close and re open, also when i view the recording folder, the files are still there.
Luke 42244 Posted April 10, 2018 Posted April 10, 2018 Ok. Please attach the information requested in how to report a problem. thanks.
