Clems6 1 Posted April 9, 2018 Posted April 9, 2018 (edited) Hello guys, Im writing you because i have some troubles configuring emby-server on my new dedicated server. I had an old server before and i decided to replace it by a new one. I used the same config files as the old one (just replaced ip adress by new server and some other things). It was working perfectly on the old server. On the new one, it's more complicated. I have troubles with auto sync in kodi. Kodi just won't auto sync the library :/ Access my emby server through webbrowser with https://domain.name is working great with ssl and working cert. Connecting the server and play content --> Works Manual sync --> Works The thing is... every time i wan't to be able to see the new content, i have to manual sync or restart kodi otherwise it's not showing the new content Here is the config of reverse proxy, I used apache2.... <IfModule mod_ssl.c> <VirtualHost 35.122.150.69:443> ServerName servername ServerAlias servername DocumentRoot /var/www/domain/ CustomLog /var/log/apache2/secure_access.log combined <proxy *> AddDefaultCharset off Order Allow,Deny Allow from all </proxy> ProxyPreserveHost On ProxyRequests Off ProxyPass "/embywebsocket" "ws://127.0.0.1:8096/embywebsocket" ProxyPassReverse "/embywebsocket" "ws://127.0.0.1:8096/embywebsocket" ProxyPass "/" "http://127.0.0.1:8096/" ProxyPassReverse "/" "http://127.0.0.1:8096/" SSLEngine on SSLCertificateFile /etc/ssl/certs/cert1.crt SSLCertificateKeyFile /etc/ssl/private/cert1.key SSLCertificateChainFile /etc/ssl/certs/GandiStandardSSLCA2.pem SSLVerifyClient None </VirtualHost> </IfModule> As i said, its perfectly the same as the old working config file... But i have an error in apache2 error.log file ... AH01144: No protocol handler was valid for the URL /embywebsocket. If you are using a DSO version of mod_proxy, make sure the proxy submodules are included in the configuration using LoadModule. I don't understand why i got this error. Didn't have it on the old server... I saw that it can be a mssing proxy mod but they seems to be all activated... Proxy Mods enabled : root@server:/etc/apache2/mods-enabled# ls -la proxy_ajp.load -> ../mods-available/proxy_ajp.loadproxy_balancer.conf -> ../mods-available/proxy_balancer.confproxy_balancer.load -> ../mods-available/proxy_balancer.loadproxy.conf -> ../mods-available/proxy.confproxy_fcgi.load -> ../mods-available/proxy_fcgi.loadproxy_http.load -> ../mods-available/proxy_http.loadproxy.load -> ../mods-available/proxy.load and of course... ssl.conf -> ../mods-available/ssl.conf ssl.load -> ../mods-available/ssl.load The only thing who doesn't work is auto sync with kodi... Please can you help Thanks in advance. Clems6 Edited April 9, 2018 by Clems6
dcrdev 255 Posted April 10, 2018 Posted April 10, 2018 You need mod_proxy_wstunnel , which you do not appear to have. Source: I have been using Apache for reverse proxying Emby and other things for years. 1
pir8radio 1313 Posted April 10, 2018 Posted April 10, 2018 You need mod_proxy_wstunnel , which you do not appear to have. Source: I have been using Apache for reverse proxying Emby and other things for years. There you go.. I'm an nginx kind of guy. hopefully that was what they needed!
Clems6 1 Posted April 13, 2018 Author Posted April 13, 2018 Thirst of all, Thanks you for your answers and sorry for the answer delay. @@dcrdev Thanks a lot your answer fixed my problem perfectly and now auto sync seems to be working. Thanks guys 1
