PenkethBoy 2068 Posted April 13, 2018 Posted April 13, 2018 ok I have an emby user (actually disabled) this may be a legacy of using the early beta emby server from a few months ago @@Luke would have to confirm if its still needed - probably not so does Emby still crash?
PenkethBoy 2068 Posted April 13, 2018 Posted April 13, 2018 (edited) my settings are different You were logged in as the Admin when you installed Emby? [edit] Sorry just spotted you were doing the properties of a gif file not the embyserver directory doing the same on _80.gif i get the same permissions Edited April 13, 2018 by PenkethBoy
RRo100 10 Posted April 13, 2018 Author Posted April 13, 2018 (edited) yes crashes, look at the label of the buttons I restarted emby again and now the buttons are ok, but emby continues to crash Edited April 13, 2018 by RRo100
PenkethBoy 2068 Posted April 13, 2018 Posted April 13, 2018 (edited) does it say anything in the syslogs on the NAS can you post the log from emby? what browser are you using? Edited April 13, 2018 by PenkethBoy
RRo100 10 Posted April 13, 2018 Author Posted April 13, 2018 -- Syslog is nothing -- I have re-installed and started emby again. Attached the new log file. I started the WEB GUI at 2018-04-13 03:33:56 -- Browser -> Chrome server-63659187210.txt
PenkethBoy 2068 Posted April 13, 2018 Posted April 13, 2018 well there is no crash in the log can you detail what you see when emby crashes? the dlna error is harmless
RRo100 10 Posted April 13, 2018 Author Posted April 13, 2018 (edited) You are welcome to look at my system via fastsupport (is a remote tool) that's all I see Edited April 14, 2018 by RRo100
PenkethBoy 2068 Posted April 14, 2018 Posted April 14, 2018 So if i understand you are saying its "crashed" because the setup wizard does not work?
RRo100 10 Posted April 14, 2018 Author Posted April 14, 2018 I install emby, then I wait a while. Then I open emby, the website opens and the wizard starts. Then emby crashes.
PenkethBoy 2068 Posted April 14, 2018 Posted April 14, 2018 what you need to explain is what the "crash" is as nothing in the log you provided and just showing a screenshot does not give any info to me or Luke IIRC you can cancel the wizard and set emby up manually from the dashboard
RRo100 10 Posted April 14, 2018 Author Posted April 14, 2018 (edited) Emby stops responding, the browser window freezes. When I reopen ebmy in Qnap App Center this message comes up: Edited April 14, 2018 by RRo100
PenkethBoy 2068 Posted April 14, 2018 Posted April 14, 2018 so when the above happens what does the emby log say?
RRo100 10 Posted April 14, 2018 Author Posted April 14, 2018 (edited) The log file in yesterday's post 4:40 is everything. The second start from the App Center nothing is written to the log. In the LOG file "kmsg.1" i found the following entry: [8215.878496] traps: EmbyServer [23820] trap invalid opcode ip: 7f32e5b702d4 sp: 7f32695c2dd0 error: 0 in libcoreclr.so [7f32e58e2000 + 39e000] Edited April 14, 2018 by RRo100
PenkethBoy 2068 Posted April 16, 2018 Posted April 16, 2018 no other than there is something wrong with your qnap setup or hardware - i would run a full filesystem check and a full smart test of all drives one final thing you do have java script enabled in your browser and try without any chrome plugins
Luke 42241 Posted April 16, 2018 Posted April 16, 2018 At this point, no. What version of QTS are you on now?
RRo100 10 Posted April 16, 2018 Author Posted April 16, 2018 (edited) I had the system rebuilt because of emby. Then I will continue to use Plex .. Thank you for your support. PS: Apparently other users have similar problems. The error message is the same https://lime-technology.com/forums/topic/62391-problem-with-new-emby-net-dot-container/ https://emby.media/community/index.php?/topic/50012-emby-server-for-net-core/page-85 Edited April 16, 2018 by RRo100
PenkethBoy 2068 Posted April 17, 2018 Posted April 17, 2018 So possibly a .net core runtime issue and / or related to your j series intel cpu
LukeNukem 1 Posted April 17, 2018 Posted April 17, 2018 I have the same issue with same QNAP 453Bmini. Wizard is stopping after clicking next and if I reload the page it's not responding. So if it's a problem with .net on this CPU the only option is to use the community version with qmono again? That was working fine. Is there a way to install 3.3.1.0 with qmono? Community version isn't updated anymore as far as I know?
Aidsy75 0 Posted April 18, 2018 Posted April 18, 2018 Hi Guys, I can confirm that i have a QNAP 453B Mini and I had "Alot" of trouble getting emby running on it. My Server Logs showed no reason to crash and i was experiencing the exact same issue as RRo100 where it crashed as soon as i entered the startup wizard. I too had a error on teh DLNA devices and so i investigated and found the DLNA server in QTS and the DLNA Emby Service were clashing and creating lots DLNA registers on my other devices in my network. I found there were several things i had to do to get it working 1) Turn off the DLNA Server that is running with QTS via the Control Panel 2) Check your other devices / cleints and remove any EMBY DLNA registers For me - with this on and the Emby server on by default they caused a clash and i had 10's of "EMBY" DLNA entries on some of my other devices. 3) Install Emby and then restart the qnap box 4) Once rebooted, give the emby server 5 minutes to finish starting up and then login. 5) You can turn on the DLNA Server that is a part of QTS once the Emby Server is up and running.
LukeNukem 1 Posted April 19, 2018 Posted April 19, 2018 Thanks for your info, but did not work for me. Or I still have a dlna client that I did not remember which is interfering. Qts dlna server is off in my station.. I will search the logs again later.
RRo100 10 Posted April 19, 2018 Author Posted April 19, 2018 Thanks, the same as LukeNukem, does not work for me
Aidsy75 0 Posted April 19, 2018 Posted April 19, 2018 Hey Guys, there was a firmware update released recently that seems to resolve issues with the bugged 4.3.3.537 firmware that QNAP pulled. It might be worth reinstalling emby then installing the firmware update and rebooting your box.
