Kodi Library Problem
jakburn2029
Hello People,
I'm Having a Kodi Library Problem, and it's got me pulling my hair out. :)
Nvidia shield TV, Emby server on laptop, fast sync, Emby for Kodi, Aeon Nox Silvo Skin.
Libraries on Emby are sorted ie: Movies/ Genre/ Action/ A Breed Apart (1984)/ A Breed Apart (1984).mkv
                                           TV/ All TV Shows in Seperate Folders by name/ (No Genre Folders, as Emby can't do this)
All Metadata set Correctly in Emby.
I followed this guide: https://kodi.wiki/view/Custom_home_items/Aeon_Nox_Silvo
And with a bit of tweaking, got my movies set up in kodi perfectly.  Click on movies, I get the whole list, Click on Genre Submenu, I get a list of Genres. Perfect.
This was really easy, and a very clear guide.
So I figured it would be just as easy to setup the TV shows in the same fashion right? Wrong.....
The TV Show folder also Shows All Movies as well as TV shows.
I have setup the tv shows folder, the same as the movies folder, (Separate Playlist) Changing the Playlist Type to "TV Shows".
I've Tried Editing the tv playlist to include "is not/ Does not Contain: Path:Movies.
But alas the movies still show in the TV shows section.
I also tried to find a Custom home items for TV guide, but could not find one, hence I'm asking here.
Hoping to find a solution :)
Tia
Jason
Edited by jakburn2029
Angelblue05
Try running a manual sync. However I'm not sure how you got this result... everything is downloaded by item type, so that would mean at one point your movie might have been considered episodes.
Sent from my iPhone using Tapatalk
Guest
