ginjaninja 605 Posted April 9, 2018 Posted April 9, 2018 added new content for a new series into my 'organise' folder. all series files fail to move (expected) when clicking on the remediate icon the series list is blank and the season and episode number is also blank. unable to add series from remediate ui (not sure if thats an option..would be good if could) choose type 'movies' in remediate ui then revert to type series - series list season and episode number now showing. (was blank) manually add series folder to library. series metadata populated in library. restart server. series name still not showing in autoorgansise remediate ui. need to do a bit more testing but remediate ui was generally broken for me when testing last night. named all files in auto organise folder properly..scheduled ao task successfully moved all files. Sent from my SM-G955F using Tapatalk
Luke 42253 Posted April 9, 2018 Posted April 9, 2018 Thanks for the feedback. While I won't be able to look at these personally, hopefully the developer who contributed can, and anyone else who would like to help is also welcome. The source code for the plugin can be found here: https://github.com/MediaBrowser/Emby.AutoOrganize Thanks !
