tired dad 28 Posted March 23, 2014 Posted March 23, 2014 (edited) Hello, I have four accounts set up, two of which are for the kids. Both have age limits set on them, but this does not seem to be honoured in the suggested movies. I was doing some testing when I went to the movie suggestions under my daughter's account, I saw this: The movie in questions shows this metadata: Two things: 1. The movie exceeds the age limit that was set 2. The movie is not even in a folder that her account has access to. Anyone else have examples like this? Edited March 23, 2014 by tired dad
ebr 16305 Posted March 23, 2014 Posted March 23, 2014 If you use MBC can you please confirm that this does not happen there. Thanks.
Solution Luke 42176 Posted March 23, 2014 Solution Posted March 23, 2014 it will be fixed for the next server release. 1
tired dad 28 Posted March 23, 2014 Author Posted March 23, 2014 If you use MBC can you please confirm that this does not happen there. Thanks. The theme I use doesn't have suggestions, so not quite sure how to do this. it will be fixed for the next server release. OK, good to know.
ebr 16305 Posted March 23, 2014 Posted March 23, 2014 The theme I use doesn't have suggestions, so not quite sure how to do this. All themes have them. Just bring up the context menu on any item and select "Similar To..."
tired dad 28 Posted March 25, 2014 Author Posted March 25, 2014 All themes have them. Just bring up the context menu on any item and select "Similar To..." So far, nothing out of place; the web browser brings up movies in folders she has no access to, while the MBC program is fine (just shows Disney films and other cartoons)
