nick naim 18 Posted April 6, 2018 Posted April 6, 2018 I have some content with 4:3 aspect ratio and a resolution of 1440x1080, but it is still classified at 720p: The same is true for other, more exotic resolutions: 1800x1078 or 1894x784 are all under 720p, where they should be classified as 1080p.
Deathsquirrel 745 Posted April 6, 2018 Posted April 6, 2018 Unless they have changed it in response to others reporting this, the current check is looking for width over 1280ish to declare something to be a 1080 res item. It's not checking height.
nick naim 18 Posted May 6, 2018 Author Posted May 6, 2018 I can confirm that in version 3.4.0.0, a resolution of 1440 x 1080 is correctly identified as 1080p. The same is true for 1800x1078. Thank you for addressing this so quickly! Unfortunately the resolutions of 1894x784 and 1876x822 are still reported as 720p. Both resolutions are clearly larger than 720p and they are the original resolution of a 1080p Bluray, so I would argue, they also should be classified as 1080p. I also noticed that this fix had no effect on how the resolutions are classified in the Statistics plugin (version 2.4.0.2), but I guess I should address that in a different sub-forum. 1
Luke 42210 Posted May 6, 2018 Posted May 6, 2018 Right because this is just at the point of display and wont' actually affect any core functions.
