EuG0000 3 Posted April 5, 2018 Posted April 5, 2018 (edited) Something weird has happened to my Emby Theater. Everything was working fine, but then w/o me making any config. etc. changes at all the look of it has changed. It used to look like this: with it's "horizontal" interface where you could roll the mouse wheel and it would scroll horizontally All of a sudden it changed to look like this: This interface looks like my ROKU interface, which is kind of interesting, because I think (not 100% sure) it happened right after I logged in and watched something through my ROKU. On top of that the window cannot be resized all of a sudden. I can only minize or maximize it. It won't run in window mode. I used to be able to double click in the middle of the screen (while playing a movie) or click the box icon in top right corner and it would resize to a window mode - no more. Would appreciate some advise. Thank you, Edited April 5, 2018 by EuG0000
Luke 42243 Posted April 5, 2018 Posted April 5, 2018 Hi if you prefer the horizontal home screen you can enable that in app display settings by clicking your user icon in the top right.
EuG0000 3 Posted April 5, 2018 Author Posted April 5, 2018 Luke, thanks for quick reply. What is the setting I'm looking for?
EuG0000 3 Posted April 5, 2018 Author Posted April 5, 2018 OK - so I checked and I had it set to TV and Horizontal already. I changed it to Desktop and vertical and then back to TV and Horizontal and it fixed the issue. Thanks for your help. 1
aspdend 177 Posted April 6, 2018 Posted April 6, 2018 OK - so I checked and I had it set to TV and Horizontal already. I changed it to Desktop and vertical and then back to TV and Horizontal and it fixed the issue. Thanks for your help. Aah - that's how I can get back to the original layout - I don't have a Roku and experienced the same change - much to my horror - it will be good to get back...
EuG0000 3 Posted April 6, 2018 Author Posted April 6, 2018 Aah - that's how I can get back to the original layout - I don't have a Roku and experienced the same change - much to my horror - it will be good to get back... Awesome!
