Protektor 12 Posted May 11, 2018 Posted May 11, 2018 (edited) I should mention that the neat thing about the sonic finger print is that it does not matter what encoder you used on the song, and it does not matter what bitrate you used to encode the song it will give the same sonic finger print for the same song encoded as 96k MP3 and 320k MP3 and FLAC and 128k AAC. All of them will give the same sonic finger print for the exact same song from the same source. Thus it is a much better way to identify music when it isn't tagged properly or when you aren't sure where your music came from or if it isn't sorted properly. I should be noted also that it can tell if a song was remixed or even changed a little in mastering for a greatest hits album since the sonic finger print between the albums will be different. Edited May 12, 2018 by Protektor
Luke 42213 Posted June 24, 2018 Posted June 24, 2018 Can anyone provide some samples for testing? Ideally what you can do is zip up an entire album or artist folder, that would be great, thanks !
Luke 42213 Posted August 23, 2018 Posted August 23, 2018 There should be no more issues with this in emby server 3.6. thanks.
