bigeyez 10 Posted April 5, 2018 Posted April 5, 2018 Hi The volume control used to work not sure what happened there but as of now the volume slider does not change the volume at all, anbd the volume gesture seems to be gone, meaning no on screeen display shows up when doing the gesture on the right side. The brightness gesture works. I am using LineageOs 7.1 thanks
Luke 42244 Posted April 5, 2018 Posted April 5, 2018 Hi, it seems to work just fine here in my testing. Can you please provide a little more information? Thanks.
bigeyez 10 Posted April 5, 2018 Author Posted April 5, 2018 Luke, sure. What kind of details do you need? It is a simple operation really and moving the slider left and right does not change the volume of the device.
bigeyez 10 Posted April 5, 2018 Author Posted April 5, 2018 (edited) I open a video using my phone as a remote for my tablet. So phone controls my tablet using playon thing, I select the video in phone, but plays on the tablet. Once the video is playing on the tablet (lineageos 7.1) I try to change the volume using the volume slider on the playing screen or using the right screen gesture, and it has no affect on the volume of the device . It does not work. It used to though. Edited April 5, 2018 by bigeyez 1
Luke 42244 Posted April 6, 2018 Posted April 6, 2018 Please try again with the next release of the app, thanks.
AdrianW 1058 Posted July 19, 2018 Posted July 19, 2018 In 3.0.00 brightness adjustment works fine (slide up and down on the LHS) - but touching anywhere on the RHS immediately sets the volume to max, no UI is displayed.
Luke 42244 Posted July 19, 2018 Posted July 19, 2018 The gesture is resolved for the next release. Thanks. 1
darknessgp 3 Posted July 21, 2018 Posted July 21, 2018 I've noticed that the volume doesn't keep what my system media volume is set at and instead is always set to max when starting playback, even when I have volume on system all the way down and I can't hear anything. Sudden shock then, when I accidentally swipe on right hand side and get blasting sound.
Luke 42244 Posted July 21, 2018 Posted July 21, 2018 This is resolved for the next release of the app, thanks. 1
okEric 2 Posted October 6, 2018 Posted October 6, 2018 So the volume gesture bug is partly fixed now for me. It still goes full blast max volume if I touch the zone where the volume gesture occurs. However, now I can gesture down and up after it sets itself to max. So ear damage is still an issue for me if using earbuds lol.
