Kimballslice1890 8 Posted April 4, 2018 Posted April 4, 2018 Has anyone attempted an emby setup for LiveTV streaming that has FiOS? If so could you share some info on how you went about setting it up? Want to know how in dept the setup is and what kind of Tuners I should be looking into.
legallink 187 Posted April 5, 2018 Posted April 5, 2018 I have Fios and emby. It’s pretty straightforward. Request a cable card, put it in an hd Homeric, activate and follow the emby live tv setup. You’ll also want schedules direct subscription to get your epg.
mastrmind11 727 Posted April 5, 2018 Posted April 5, 2018 same here. extremely simple if you follow the instructions. and schedules direct is well worth the $. just make sure once you've got everything set up, you update the HDHR firmware to the latest.
