LiamL 0 Posted April 4, 2018 Posted April 4, 2018 Having trouble connecting to the local server on my Roku TV... I tried to sign in and out and still nothing. I don't know what else to do...
lorac 119 Posted April 4, 2018 Posted April 4, 2018 Having trouble connecting to the local server on my Roku TV... I tried to sign in and out and still nothing. I don't know what else to do...Can you reach your server dashboard? Sent from my STV100-3 using Tapatalk
ebr 16335 Posted April 4, 2018 Posted April 4, 2018 Hi. Exactly what trouble? What are you doing and what is happening? Thanks.
LiamL 0 Posted April 4, 2018 Author Posted April 4, 2018 I am opening the emby channel on my Roku tv and i get to the screen where it says New Server and below says sign out... i click on New seerver and i try to connect but i cant connect
lorac 119 Posted April 4, 2018 Posted April 4, 2018 I am opening the emby channel on my Roku tv and i get to the screen where it says New Server and below says sign out... i click on New seerver and i try to connect but i cant connectAnd for your server are you putting in it's IP address? Has it ever worked? Sent from my STV100-3 using Tapatalk
LiamL 0 Posted April 4, 2018 Author Posted April 4, 2018 well i dont change the host or the port so maby that could be the problem?
lorac 119 Posted April 4, 2018 Posted April 4, 2018 well i dont change the host or the port so maby that could be the problem?Possibly. I would verify what the IP address of your server is. The port is probably fine. Sent from my STV100-3 using Tapatalk
lorac 119 Posted April 4, 2018 Posted April 4, 2018 how?You do have a computer that you installed emby on right? Assuming yes and that you're using some version of Windows go start>run>cmd and type ipconfig Sent from my STV100-3 using Tapatalk
lorac 119 Posted April 4, 2018 Posted April 4, 2018 no emby on my laptopHave you installed emby server on your laptop or other computer? Sent from my STV100-3 using Tapatalk
