pir8radio 1313 Posted April 11, 2018 Posted April 11, 2018 (edited) disable your 302 redirect, let HSTS do what its supposed to do. When you enter the manual address in your TV make sure you enter: https://yourdomain.com and port 443 dont just enter yourdomain.com see if those two things help. Looks like sony may have disabled the ability for redirects to work recently? I think you have a similar issue to this: https://emby.media/community/index.php?/topic/57583-3-sony-atvs-all-exhibit-the-same-issue/ Edited April 11, 2018 by pir8radio 1
Nataniel 0 Posted April 11, 2018 Author Posted April 11, 2018 disable your 302 redirect, let HSTS do what its supposed to do. When you enter the manual address in your TV make sure you enter: https://yourdomain.com and port 443 dont just enter yourdomain.com see if those two things help. Looks like sony may have disabled the ability for redirects to work recently? I think you have a similar issue to this: https://emby.media/community/index.php?/topic/57583-3-sony-atvs-all-exhibit-the-same-issue/ I had just tried to put the address manually with port 443 but it did not work either. I just changed my ciphers on my reverse proxy so there are fewer restrictions with older devices to see if it changes anything to my problem. So I'm waiting to get out of work to try tonight
Nataniel 0 Posted April 11, 2018 Author Posted April 11, 2018 I just re-test my TV and nothing works.I still have the error: Error connecting to the serverI tried with: https://emby.rathorian.fr 443 AND http://emby.rathorian.fr 80
Luke 42239 Posted April 11, 2018 Posted April 11, 2018 Can you try using the default port 8096? thanks.
Nataniel 0 Posted April 12, 2018 Author Posted April 12, 2018 Can you try using the default port 8096? thanks. It does not work either
ebr 16333 Posted April 12, 2018 Posted April 12, 2018 disable your 302 redirect, let HSTS do what its supposed to do. When you enter the manual address in your TV make sure you enter: https://yourdomain.com and port 443 dont just enter yourdomain.com see if those two things help. Looks like sony may have disabled the ability for redirects to work recently? I think you have a similar issue to this: https://emby.media/community/index.php?/topic/57583-3-sony-atvs-all-exhibit-the-same-issue/ Did you do this?
pir8radio 1313 Posted April 12, 2018 Posted April 12, 2018 It does not work either send us a screen shot of what you are manually entering for the server address please.
