Wurlitzer_ 1 Posted April 1, 2018 Posted April 1, 2018 (edited) Problem: - I configure a user to be able to only see certain folders - User still can see movies from forbidden folders from the main page, in "Latest Movies" section Edited April 1, 2018 by Wurlitzer_
Luke 42208 Posted April 1, 2018 Posted April 1, 2018 Hi, no that doesn't sound right. Can you please discuss an example? This shouldn't be happening.
Wurlitzer_ 1 Posted April 2, 2018 Author Posted April 2, 2018 (edited) I have a folder called "Limbo" for movies that are still to be classified, or identified correctly. The content in this folder is not to be seen from a certain user, so in the admin panel, I remove access to that folder, like shown in the screenshot: https://i.imgur.com/xXm4z5c.png On that user's home page, the "My Media" section correctly doesn't display the "Limbo" folder, and only "Documentaries", "Movies", "Series". However, scrolling down a bit, in the section "Latest Movies", movies only present in "Limbo" appear, along with content from the other folders. Edited April 2, 2018 by Wurlitzer_
Luke 42208 Posted April 2, 2018 Posted April 2, 2018 Can you show a screenshot of emby library setup?
Solution Wurlitzer_ 1 Posted April 2, 2018 Author Solution Posted April 2, 2018 (edited) #@#$!, the "Limbo" folder was also part of the paths in one of the public folders. I have resolved the issue. Sorry for wasting your time, and thanks for the help. Edited April 3, 2018 by ebr 1
Luke 42208 Posted April 2, 2018 Posted April 2, 2018 That what's what I was thinking. Thanks for the feedback.
