DaSilva 11 Posted April 1, 2018 Posted April 1, 2018 Hi, I’ve been looking the forum but I can’t find the thread with the settings for MPC as external player. Right now I’m using the following parameters: {path} /play /fullscreen /close Everything is fine with these except when I press STOP on my remote MPC just sits there with a black screen instead of quitting and going back to Theater. When I manually close MPC Theater maximises again so that’s fine. What can I do to make MPC close when I press STOP? Thanks in advance.
Jdiesel 1435 Posted April 1, 2018 Posted April 1, 2018 (edited) There should be a setting in mpv under the playback options to exit when playback stops. Edited April 1, 2018 by Jdiesel
DaSilva 11 Posted April 3, 2018 Author Posted April 3, 2018 Sorry but I can’t find any option in Media Player Classic to exit when playback stops. I thought the /close argument was supposed to do that? Anyone else having problems with this or have gotten this to work?
Luke 42240 Posted April 3, 2018 Posted April 3, 2018 What does the documentation of the close argument say? I think it just closes the app when the video ends.
Jdiesel 1435 Posted April 3, 2018 Posted April 3, 2018 (edited) I'm using MPC-HC so I don't know if MPC-BE is any different. In Emby Theater I have the external player setup with only {path} and no arguments. In MPC-HC I have: Playback -> After Playback -> Exit Playback -> Fullscreen -> Launch files in Fullscreen Player -> Keys -> Exit mapped to Backspace I think your issue is that your are using "close" instead of "exit" Edited April 3, 2018 by Jdiesel
hhb97b 11 Posted April 7, 2018 Posted April 7, 2018 I'm having issues with external playback every time I'm adding /<parameter>. Currently I can only get it to work with {path} anything else fails. If I use the same command line in a prompt then it works perfect.
Luke 42240 Posted April 7, 2018 Posted April 7, 2018 What does "anything else fails" mean? What exactly are you trying?
hhb97b 11 Posted April 7, 2018 Posted April 7, 2018 forexample setup a external player to use mpc-hc and then setup the command line to "{path} /close" . Then play a movie. The player opens but says the file can't be found. If I use the exact same syntaxt in a command prompt it works fine. If I change the command line parameter to only contain "{path}" the movie starts playing. Any other combinations fails to start the movie. Also I haven't had any luck with the {ms} option. I have looked in the logs but I couldn't find the specific command that the system creates.
Luke 42240 Posted April 7, 2018 Posted April 7, 2018 How exactly did you enter the command line arguments?
daedalus 434 Posted April 7, 2018 Posted April 7, 2018 (edited) forexample setup a external player to use mpc-hc and then setup the command line to "{path} /close" . Then play a movie. The player opens but says the file can't be found. If I use the exact same syntaxt in a command prompt it works fine. If I change the command line parameter to only contain "{path}" the movie starts playing. Any other combinations fails to start the movie. Also I haven't had any luck with the {ms} option. I have looked in the logs but I couldn't find the specific command that the system creates. read again carefully what's written directly below the command line input field What can I do to make MPC close when I press STOP? simply setting 'STOP ' to exit MPC-BE? in the key shortcut section of it's settings? /play /close only exits when reached the end of the file Edited April 7, 2018 by daedalus
hhb97b 11 Posted April 8, 2018 Posted April 8, 2018 /close was just an example . It wasn't because of the functionality like the thread creater. When /close is added to the command line the movie will never play, in my situation. Also I not using mpc-be, I'm using mpc-hc. My exit working perfect with the options setup in mpc-hc, but I haven't found away where I can use the command line options at all.
DaSilva 11 Posted April 8, 2018 Author Posted April 8, 2018 @@hhb97b You have to pit each command on a seperate line. Like: {path} /play /close NOT: {path} /play /close @@daedalus I will give that a try thanks! 1
hhb97b 11 Posted April 8, 2018 Posted April 8, 2018 (edited) ok, I will try that Update: It worked. I would say that this is an odd usability compared to what all other programs does. I can see that there is a help text. I would probably put the help text about a new line in bold. But that's me. Perhaps make the command line 2 rows high as standard to signal that this field is multi-line Thanks for the help Edited April 8, 2018 by hhb97b
DaSilva 11 Posted April 10, 2018 Author Posted April 10, 2018 Ok a little update. Setting the “STOP” command to exit mpc-be works a charm, thanks for that!! But now when mpc-be closes I get Theater but I can’t control it with my remote. I have to click anywhere on the screen with the mouse and then I can use my remote. Any workaround for this please? Thanks!!!
JMR 4 Posted April 11, 2018 Posted April 11, 2018 I set a button on my remote for right mouse click if that happens i push it and brings back control
jachin99 88 Posted April 11, 2018 Posted April 11, 2018 I mapped my back button to close in MPC settings and that works good for my purposes.
shpitz461 4 Posted May 14, 2018 Posted May 14, 2018 Does anyone using {MS} param? When I enter it into external player param setting, I get an error when playing a movie saying the params are incorrect (in MPC-HC window outside of Theatre). If I copy the command shown in the error and run it through commandline, the movie plays and resumes fine. I have the params set as follows: {path} /play /close /fullscreen /start {ms} I always get an error message unless i remote '/start {ms}'. Using latest MPC-HC x64 on Win10.
daedalus 434 Posted May 14, 2018 Posted May 14, 2018 (edited) you have to use /start {ms} {ms} is also a parameter, and yes its not obvious Edited May 14, 2018 by daedalus 1
shpitz461 4 Posted May 15, 2018 Posted May 15, 2018 Works like a charm, thanks for the clarification! I do have an issue with play resume, this option no longer available when using the external player, is there any way to get it to work?
Luke 42240 Posted May 15, 2018 Posted May 15, 2018 No because there is no way to get the resume point from the external player. All you can really use this for is resuming something that has already been started elsewhere.
shpitz461 4 Posted May 15, 2018 Posted May 15, 2018 So how does it work with MPV then? MPV is external as well
shpitz461 4 Posted May 15, 2018 Posted May 15, 2018 Is there a way I can launch MPV with the problematic movie using different settings and see if anything solves the freezing issue I'm experiencing?
Luke 42240 Posted May 15, 2018 Posted May 15, 2018 So how does it work with MPV then? MPV is external as well Because Theater knows how MPV works, and is using an mpv api. External players are just generic program launchers.
