gtmnyc 12 Posted April 2, 2019 Posted April 2, 2019 this thing is farcical i added channel numbers to my m3u so the guide isnt a mess and the channel order makes some kind of sense.. i added the correct channel id numbers for each channel.. i even add the xmltv from from SD.. BUT the channel number super seeds the channel id and the guide pulls the listings according to the channel number... #EXTINF:-1 tvg-chno="2" channel id="i17154" tvg-name="UK: BBC TWO" group-title="UK",UK: BBC TWO i cant believe this is a PAID!!! feature... there are free guides in kodi that do this with ease. 1
Spaceboy 2573 Posted April 2, 2019 Posted April 2, 2019 this thing is farcical i added channel numbers to my m3u so the guide isnt a mess and the channel order makes some kind of sense.. i added the correct channel id numbers for each channel.. i even add the xmltv from from SD.. BUT the channel number super seeds the channel id and the guide pulls the listings according to the channel number... #EXTINF:-1 tvg-chno="2" channel id="i17154" tvg-name="UK: BBC TWO" group-title="UK",UK: BBC TWO i cant believe this is a PAID!!! feature... there are free guides in kodi that do this with ease. preaching to the converted sir! You want channel numbers with 4 digits ie 1001. That way you can override what you are seeing
gtmnyc 12 Posted April 2, 2019 Posted April 2, 2019 ful preaching to the converted sir!You want channel numbers with 4 digits ie 1001. That way you can override what you are seeing l day wasted... thanks spaceboy.. at least someone will help and answer questions..
