NYRANGERS423 2 Posted April 1, 2018 Posted April 1, 2018 So for a while now I just thought maybe the file format or transcodeing of the video was not able to be played back on some of my devices. Playback of any content using the android emby app on my galaxy S8 or S8+ doesn't play. I get the "No compatible streams are currently available. Please try again later or contact your system administrator for details." I have tested Samsung tablets, Galaxy S7, Note 5, and other android. They all are able to play back the same media. So could this be a phone compatibility issue? Maybe the 18.5 by 9 aspect ratio has something to do with it. I am not to sure. App version is 2.9.92 and the server is 3.3.1.0.
rikiwi 32 Posted April 1, 2018 Posted April 1, 2018 You might like to look at these posts I contributed to. They are concerned with playing videos etc in the Android Mobile App using a Samsung S8 phone. https://emby.media/community/index.php?/topic/57020-skip-forwardback-stopped-working-in-version-2992/ https://emby.media/community/index.php?/topic/57602-no-subtitles-when-playing-offline-content/ To get around these problems I downloaded Android app version: 9.2.90 Luke is aware of problems with some Samsung devices and is looking into it.
NYRANGERS423 2 Posted April 1, 2018 Author Posted April 1, 2018 Thanks! Also where did you get the app version 9.2.90?
rikiwi 32 Posted April 2, 2018 Posted April 2, 2018 Thanks! Also where did you get the app version 9.2.90?Here's the website I found for older APK's.https://apksfull.com/version/com.mb.android Hope that helps Sent from my SM-G950F using Tapatalk
