PenkethBoy 2068 Posted April 1, 2018 Posted April 1, 2018 (edited) Just updated my QNAP to the latest firmware 4.3.4.0537 and now getting large numbers of errors in the log and LiveTv cannot connect to Schedules Direct, plugin check fails and any other emby external service using ssl fails Example error trace 2018-04-01 15:50:48.215 Error HttpClient: Error getting response from https://json.schedulesdirect.org/20141201/token *** Error Report *** Version: 3.3.1.0 Command line: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system/EmbyServer.dll -programdata /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata -ffmpeg /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg -ffprobe /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffprobe -defaultdirectory /share/CACHEDEV1_DATA -updatepackage emby-server-qnap_{version}_x86_64.qpkg Operating system: Unix 4.2.8.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.Http.CurlException: Problem with the SSL CA cert (path? access rights?) at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) --- End of inner exception stack trace --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult() at System.Net.Http.HttpClient.<FinishSendAsyncUnbuffered>d__59.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() System.Net.Http.HttpRequestException at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult() at System.Net.Http.HttpClient.<FinishSendAsyncUnbuffered>d__59.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() InnerException: System.Net.Http.CurlException System.Net.Http.CurlException: Problem with the SSL CA cert (path? access rights?) at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error) at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult) Any ideas what to check for that might have changed?? Edited April 1, 2018 by PenkethBoy
PenkethBoy 2068 Posted April 1, 2018 Author Posted April 1, 2018 Ok - found a temporary solution I re installed the 3.3.1.1. package over my existing install and this corrected the ssl error (Dont uninstall the package first or this will remove you database and settings!) I assume the package install must set some permissions on the ssl cert - which QNAP then reset with a new firmware This needs to be fixed otherwise you are going to get a lot of support posts on this!
OddbOd 21 Posted April 5, 2018 Posted April 5, 2018 Same thing happened to me on 3.3.1.0. Emby's error log is accurate as the QNAP firmware update is the root cause, curl and it's CA bundle were updated. Installing the same Emby version over the top of itself is the simplest solution as there's nothing for Emby devs to fix.
PenkethBoy 2068 Posted April 5, 2018 Author Posted April 5, 2018 Yes there is it should not happen in the first place
Luke 42240 Posted April 5, 2018 Posted April 5, 2018 Yes we should try to find a way to prevent it from happening.
PenkethBoy 2068 Posted April 20, 2018 Author Posted April 20, 2018 (edited) This has happened again with 3.3.1 i shut down Emby - and restarted emby a couple of hours later i had to re-install Emby again to get the server to work properly So do we have any idea what causes it? And no i had not updated my firmware Edited April 20, 2018 by PenkethBoy
Luke 42240 Posted April 21, 2018 Posted April 21, 2018 I'm not sure yet, probably a system update resetting something.
PenkethBoy 2068 Posted April 21, 2018 Author Posted April 21, 2018 no - nothing like that changed - just shutting down Emby is enough to trigger it
OddbOd 21 Posted April 22, 2018 Posted April 22, 2018 After many hours and much vodka I finally found it. The link to /etc/ssl/certs/ca-certificates.crt is created when the package is installed instead of when Emby starts. When the system is rebooted that link no longer exists. That's why reinstalling the QPKG makes Emby work again. @@alucryd & @Luke QNAP is not a "normal" Linux distro, there are many quirks that are poorly documented. You can do whatever you want in Emby's package directory but changes to /root;/etc;/share or cronjobs will not survive reboots. @@PenkethBoy Replace emby-server.sh with this and all will be well. Thanks for the reminder that I don't know everything #!/bin/sh CONF=/etc/config/qpkg.conf QPKG_NAME=EmbyServer QPKG_DIR=$(getcfg $QPKG_NAME Install_Path -f $CONF) PID_FILE=/var/run/emby-server.pid case "$1" in start) ENABLED=$(getcfg $QPKG_NAME Enable -u -d FALSE -f $CONF) if [ "$ENABLED" != "TRUE" ]; then echo "$QPKG_NAME is disabled." exit 1 fi if [ -f $PID_FILE ] && kill -0 $(cat $PID_FILE); then echo "$QPKG_NAME is already running." exit 1 else if [ ! -e /etc/ssl/certs/ca-certificates.crt ]; then ln -s /etc/ssl/certs/rootca.pem /etc/ssl/certs/ca-certificates.crt fi $QPKG_DIR/bin/emby-server & echo $! > $PID_FILE fi ;; stop) if [ -f $PID_FILE ]; then PID=$(cat $PID_FILE) if kill -0 $PID; then kill $PID while [ -e /proc/$PID ]; do sleep 1; done fi rm $PID_FILE else echo "$QPKG_NAME is not running." exit 1 fi ;; restart) $0 stop $0 start ;; *) echo "Usage: $0 {start|stop|restart}" exit 1 esac exit 0
PenkethBoy 2068 Posted April 22, 2018 Author Posted April 22, 2018 (edited) @@OddbOd Thanks i will give it a try - i assume this gets replaced on each emby install? will install the latest beta .21 then update for now Edited April 22, 2018 by PenkethBoy
alucryd 318 Posted April 23, 2018 Posted April 23, 2018 @@OddbOd I'm aware of that, I've already been doing that since several betas back.
PenkethBoy 2068 Posted April 23, 2018 Author Posted April 23, 2018 @@alucryd - so you think its a different error causing Emby to become unusable?
Luke 42240 Posted April 23, 2018 Posted April 23, 2018 The beta posted yesterday I think is the first build you've gotten with the changes.
OddbOd 21 Posted April 24, 2018 Posted April 24, 2018 I've double checked the 3.3.1.21 beta and it definitely contains fixed install and start scripts. Thanks alucryd, keep up the good work.
