Network credentials with external static IP and special Port
Go to solution Solved by Angelblue05,
Dear community,
we´re trying to setup an Emby Server on a regular Linux Webserver with a static IP. Everything works fine by connecting via browser with https://X.X.X.X:Port (we don´t use standard port).
However I want to use the emby library with Kodi. Therefore the Emby for Kodi addon is a nice tool! Connecting to the server is working, sync is working and the content is meanwhile in my Kodi library. However I´m not able to start playing the video files since the network credentials are missing.
Which data should I put into the network credentials of the addon in case of an external static IP with special Port?
\X.X.X.X:Port\
or
X.X.X.X:Port
or
https://X.X.X.X:Port ?
And which network username should I use? My Emby user login?
Alternatively should we use path substitution / (optional) shared network folder in the emby server settings? But what should I put inside here if I have a folder like /mnt/video?
Thanks in advance!
Tumba
  • Solution
Angelblue05
Remote access is only available for add-on playback mode. Make the change in the add-on settings > sync options, then reset the local database. That's all you need to do to get video playback working.
  • Like 2
Hi Angelblue05,
this is it! Just missed this info for the setup! Now it works perfect!
Thanks a lot
Tumba
  • Like 1
Guest
