trmentry 0 Posted April 1, 2018 Posted April 1, 2018 So I just got a spiffy new DS918+. Installed the Emby Server 3.3.1.0-1. When running though the wizard to add local paths to the library.. I get "path can't be found" my original path was /volume1/Media/MOVIES(HD) However I figured it was due to the ( ) in the name.. so changed it to MOVIES_HD Still no joy. When I click the little magnify glass next to browse.. I can click on volume1 then Media then it just goes blank. I've tried it with /volume1/uploads/movies as well.... and that didn't work. I've stopped/restarted the app... but still the same issue.
trmentry 0 Posted April 1, 2018 Author Posted April 1, 2018 scratch this. figured it out. embysvr user needed permissions to the shares. got that sorted and now added in paths. sorry for the time waste.
