gfrung4 0 Posted March 31, 2018 Posted March 31, 2018 A few weeks ago I posted this topic about an Emby error: An unexpected problem (but not server timeout or HTTP error) has been detected. I thought I had solved it (and that it was due to low disk space), but I've determined that it's (at least sometimes) caused by something else. Live TV is frustrating to watch because it stops every few minutes. I think this is a server problem, but I am playing on a Roku TV if that matters. The server version is 3.3.1.0, which I'm told is the latest. Below I've attached a log of the instant that error appeared on my screen. It looks like it starts off with something about "killing transcoding". This seems odd to me, because the server dashboard says my Roku is "direct streaming", and the CPU usage is low, indicating there is no transcoding occurring. What's going on here? Thanks so much for your help, gfrung4 2018-03-31 08:34:45.982 Info App: Transcoding kill timer stopped for JobId 542a7ad321d04689ad0a560efed5fbb6 PlaySessionId a1b8dc8792b54683bbca43d975164e76. Killing transcoding 2018-03-31 08:34:45.994 Info App: Stopping ffmpeg process with q command for /var/lib/emby/transcoding-temp/96f4e6a692cb1ebf6f242851dc99bc6b.m3u8 2018-03-31 08:34:46.053 Info App: FFMpeg exited with code 0 2018-03-31 08:34:46.060 Info App: Deleting partial stream file(s) /var/lib/emby/transcoding-temp/96f4e6a692cb1ebf6f242851dc99bc6b.m3u8 2018-03-31 08:34:46.067 Error HttpServer: Error in HttpListenerResponseWrapper: Broken pipe *** Error Report *** Version: 3.3.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.4.0.116 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.Net.Sockets.SocketException (0x80004005): Broken pipe at SocketHttpListener.SocketStream.Write(Byte[] buffer, Int32 offset, Int32 count) at SocketHttpListener.Net.HttpResponseStream.DisposeCore() at SocketHttpListener.Net.HttpResponseStream.Dispose(Boolean disposing) at System.IO.Stream.Close() at Emby.Server.Implementations.HttpServer.SocketSharp.WebSocketSharpResponse.CloseOutputStream(HttpListenerResponse response) System.Net.Sockets.SocketException at SocketHttpListener.SocketStream.Write(Byte[] buffer, Int32 offset, Int32 count) at SocketHttpListener.Net.HttpResponseStream.DisposeCore() at SocketHttpListener.Net.HttpResponseStream.Dispose(Boolean disposing) at System.IO.Stream.Close() at Emby.Server.Implementations.HttpServer.SocketSharp.WebSocketSharpResponse.CloseOutputStream(HttpListenerResponse response) 2018-03-31 08:34:46.067 Info HttpServer: HTTP Response 500 to 127.0.0.1. Time: 357557ms. http://127.0.0.1:8096/LiveTv/LiveStreamFiles/a05bb9a7bb4d401c936f0234c6e91e03/stream.ts 2018-03-31 08:34:46.075 Info MediaSourceManager: Closing live stream 09efa0d56b934a82adec00a87b837fb0_84f34b4d24654ae39ccc15897842e7ed_native_e79be9963278fb5a7994bbfef66aa59a_2d75fc359c636369d39923d018976865 with provider LiveTvMediaSourceProvider 2018-03-31 08:34:46.079 Info App: Closing live stream from Emby, stream Id: 84f34b4d24654ae39ccc15897842e7ed_native_e79be9963278fb5a7994bbfef66aa59a_2d75fc359c636369d39923d018976865 2018-03-31 08:34:46.083 Info App: Live stream 84f34b4d24654ae39ccc15897842e7ed_native_e79be9963278fb5a7994bbfef66aa59a_2d75fc359c636369d39923d018976865 consumer count is now 0 2018-03-31 08:34:46.083 Info App: Closing live stream 84f34b4d24654ae39ccc15897842e7ed_native_e79be9963278fb5a7994bbfef66aa59a_2d75fc359c636369d39923d018976865 2018-03-31 08:34:46.084 Info App: Closing SharedHttpStream 2018-03-31 08:34:46.084 Info App: Live stream 84f34b4d24654ae39ccc15897842e7ed_native_e79be9963278fb5a7994bbfef66aa59a_2d75fc359c636369d39923d018976865 closed successfully 2018-03-31 08:34:46.097 Info App: Deleting temp files /var/lib/emby/transcoding-temp/a05bb9a7bb4d401c936f0234c6e91e03.ts 2018-03-31 08:34:48.395 Info HttpServer: HTTP GET http://192.168.0.8:8096/emby/videos/9caa9689a73d559750fa814aa6473833/live.m3u8?DeviceId=7ff88320-ad69-5f85-8217-0be35aa64510&MediaSourceId=84f34b4d24654ae39ccc15897842e7ed_native_e79be9963278fb5a7994bbfef66aa59a_2d75fc359c636369d39923d018976865&VideoCodec=h264,mpeg2video,hevc,vp9&AudioCodec=ac3,mp3,aac&AudioStreamIndex=-1&VideoBitrate=79808000&AudioBitrate=192000&MaxFramerate=30&MaxWidth=1920&MaxHeight=1080&PlaySessionId=a1b8dc8792b54683bbca43d975164e76&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_84f34b4d24654ae39ccc15897842e7ed_native_e79be9963278fb5a7994bbfef66aa59a_2d75fc359c636369d39923d018976865&TranscodingMaxAudioChannels=6&RequireAvc=false&SegmentContainer=ts&SegmentLength=3&MinSegments=1&BreakOnNonKeyFrames=True&h264-maxrefframes=16&h264-videobitdepth=8&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&audiochannels=6&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported. Host=192.168.0.8:8096, User-Agent=Roku/DVP-8.0 (388.00E04156A), Accept=*/*, Accept-Encoding=deflate, gzip 2018-03-31 08:34:48.403 Error HttpServer: Error processing request *** Error Report *** Version: 3.3.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.4.0.116 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system MediaBrowser.Common.Extensions.ResourceNotFoundException: Exception of type 'MediaBrowser.Common.Extensions.ResourceNotFoundException' was thrown. at Emby.Server.Implementations.Library.MediaSourceManager.<GetLiveStreamInfo>d__32.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Library.MediaSourceManager.<GetLiveStreamWithDirectStreamProvider>d__31.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.BaseStreamingService.<GetState>d__78.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.<ProcessRequest>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceExecGeneral.<Execute>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__74.MoveNext() MediaBrowser.Common.Extensions.ResourceNotFoundException at Emby.Server.Implementations.Library.MediaSourceManager.<GetLiveStreamInfo>d__32.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Library.MediaSourceManager.<GetLiveStreamWithDirectStreamProvider>d__31.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.BaseStreamingService.<GetState>d__78.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.<ProcessRequest>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceExecGeneral.<Execute>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__74.MoveNext() 2018-03-31 08:34:48.403 Info HttpServer: HTTP Response 404 to 192.168.0.2. Time: 8ms. http://192.168.0.8:8096/emby/videos/9caa9689a73d559750fa814aa6473833/live.m3u8?DeviceId=7ff88320-ad69-5f85-8217-0be35aa64510&MediaSourceId=84f34b4d24654ae39ccc15897842e7ed_native_e79be9963278fb5a7994bbfef66aa59a_2d75fc359c636369d39923d018976865&VideoCodec=h264,mpeg2video,hevc,vp9&AudioCodec=ac3,mp3,aac&AudioStreamIndex=-1&VideoBitrate=79808000&AudioBitrate=192000&MaxFramerate=30&MaxWidth=1920&MaxHeight=1080&PlaySessionId=a1b8dc8792b54683bbca43d975164e76&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_84f34b4d24654ae39ccc15897842e7ed_native_e79be9963278fb5a7994bbfef66aa59a_2d75fc359c636369d39923d018976865&TranscodingMaxAudioChannels=6&RequireAvc=false&SegmentContainer=ts&SegmentLength=3&MinSegments=1&BreakOnNonKeyFrames=True&h264-maxrefframes=16&h264-videobitdepth=8&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&audiochannels=6&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported 2018-03-31 08:34:48.509 Info HttpServer: HTTP GET http://192.168.0.8:8096/emby/videos/9caa9689a73d559750fa814aa6473833/live.m3u8?DeviceId=7ff88320-ad69-5f85-8217-0be35aa64510&MediaSourceId=84f34b4d24654ae39ccc15897842e7ed_native_e79be9963278fb5a7994bbfef66aa59a_2d75fc359c636369d39923d018976865&VideoCodec=h264,mpeg2video,hevc,vp9&AudioCodec=ac3,mp3,aac&AudioStreamIndex=-1&VideoBitrate=79808000&AudioBitrate=192000&MaxFramerate=30&MaxWidth=1920&MaxHeight=1080&PlaySessionId=a1b8dc8792b54683bbca43d975164e76&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_84f34b4d24654ae39ccc15897842e7ed_native_e79be9963278fb5a7994bbfef66aa59a_2d75fc359c636369d39923d018976865&TranscodingMaxAudioChannels=6&RequireAvc=false&SegmentContainer=ts&SegmentLength=3&MinSegments=1&BreakOnNonKeyFrames=True&h264-maxrefframes=16&h264-videobitdepth=8&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&audiochannels=6&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported. Host=192.168.0.8:8096, User-Agent=Roku/DVP-8.0 (388.00E04156A), Accept=*/*, Accept-Encoding=deflate, gzip 2018-03-31 08:34:48.524 Error HttpServer: Error processing request *** Error Report *** Version: 3.3.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.4.0.116 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system MediaBrowser.Common.Extensions.ResourceNotFoundException: Exception of type 'MediaBrowser.Common.Extensions.ResourceNotFoundException' was thrown. at Emby.Server.Implementations.Library.MediaSourceManager.<GetLiveStreamInfo>d__32.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Library.MediaSourceManager.<GetLiveStreamWithDirectStreamProvider>d__31.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.BaseStreamingService.<GetState>d__78.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.<ProcessRequest>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceExecGeneral.<Execute>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__74.MoveNext() MediaBrowser.Common.Extensions.ResourceNotFoundException at Emby.Server.Implementations.Library.MediaSourceManager.<GetLiveStreamInfo>d__32.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Library.MediaSourceManager.<GetLiveStreamWithDirectStreamProvider>d__31.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.BaseStreamingService.<GetState>d__78.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.<ProcessRequest>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceExecGeneral.<Execute>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__74.MoveNext() 2018-03-31 08:34:48.525 Info HttpServer: HTTP Response 404 to 192.168.0.2. Time: 17ms. http://192.168.0.8:8096/emby/videos/9caa9689a73d559750fa814aa6473833/live.m3u8?DeviceId=7ff88320-ad69-5f85-8217-0be35aa64510&MediaSourceId=84f34b4d24654ae39ccc15897842e7ed_native_e79be9963278fb5a7994bbfef66aa59a_2d75fc359c636369d39923d018976865&VideoCodec=h264,mpeg2video,hevc,vp9&AudioCodec=ac3,mp3,aac&AudioStreamIndex=-1&VideoBitrate=79808000&AudioBitrate=192000&MaxFramerate=30&MaxWidth=1920&MaxHeight=1080&PlaySessionId=a1b8dc8792b54683bbca43d975164e76&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_84f34b4d24654ae39ccc15897842e7ed_native_e79be9963278fb5a7994bbfef66aa59a_2d75fc359c636369d39923d018976865&TranscodingMaxAudioChannels=6&RequireAvc=false&SegmentContainer=ts&SegmentLength=3&MinSegments=1&BreakOnNonKeyFrames=True&h264-maxrefframes=16&h264-videobitdepth=8&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&audiochannels=6&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported 2018-03-31 08:34:48.534 Info HttpServer: HTTP GET http://192.168.0.8:8096/emby/videos/9caa9689a73d559750fa814aa6473833/live.m3u8?DeviceId=7ff88320-ad69-5f85-8217-0be35aa64510&MediaSourceId=84f34b4d24654ae39ccc15897842e7ed_native_e79be9963278fb5a7994bbfef66aa59a_2d75fc359c636369d39923d018976865&VideoCodec=h264,mpeg2video,hevc,vp9&AudioCodec=ac3,mp3,aac&AudioStreamIndex=-1&VideoBitrate=79808000&AudioBitrate=192000&MaxFramerate=30&MaxWidth=1920&MaxHeight=1080&PlaySessionId=a1b8dc8792b54683bbca43d975164e76&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_84f34b4d24654ae39ccc15897842e7ed_native_e79be9963278fb5a7994bbfef66aa59a_2d75fc359c636369d39923d018976865&TranscodingMaxAudioChannels=6&RequireAvc=false&SegmentContainer=ts&SegmentLength=3&MinSegments=1&BreakOnNonKeyFrames=True&h264-maxrefframes=16&h264-videobitdepth=8&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&audiochannels=6&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported. Host=192.168.0.8:8096, User-Agent=Roku/DVP-8.0 (388.00E04156A), Accept=*/*, Accept-Encoding=deflate, gzip 2018-03-31 08:34:48.539 Error HttpServer: Error processing request *** Error Report *** Version: 3.3.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.4.0.116 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system MediaBrowser.Common.Extensions.ResourceNotFoundException: Exception of type 'MediaBrowser.Common.Extensions.ResourceNotFoundException' was thrown. at Emby.Server.Implementations.Library.MediaSourceManager.<GetLiveStreamInfo>d__32.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Library.MediaSourceManager.<GetLiveStreamWithDirectStreamProvider>d__31.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.BaseStreamingService.<GetState>d__78.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.<ProcessRequest>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceExecGeneral.<Execute>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__74.MoveNext() MediaBrowser.Common.Extensions.ResourceNotFoundException at Emby.Server.Implementations.Library.MediaSourceManager.<GetLiveStreamInfo>d__32.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Library.MediaSourceManager.<GetLiveStreamWithDirectStreamProvider>d__31.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.BaseStreamingService.<GetState>d__78.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.<ProcessRequest>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceExecGeneral.<Execute>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__74.MoveNext() 2018-03-31 08:34:48.539 Info HttpServer: HTTP Response 404 to 192.168.0.2. Time: 6ms. http://192.168.0.8:8096/emby/videos/9caa9689a73d559750fa814aa6473833/live.m3u8?DeviceId=7ff88320-ad69-5f85-8217-0be35aa64510&MediaSourceId=84f34b4d24654ae39ccc15897842e7ed_native_e79be9963278fb5a7994bbfef66aa59a_2d75fc359c636369d39923d018976865&VideoCodec=h264,mpeg2video,hevc,vp9&AudioCodec=ac3,mp3,aac&AudioStreamIndex=-1&VideoBitrate=79808000&AudioBitrate=192000&MaxFramerate=30&MaxWidth=1920&MaxHeight=1080&PlaySessionId=a1b8dc8792b54683bbca43d975164e76&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_84f34b4d24654ae39ccc15897842e7ed_native_e79be9963278fb5a7994bbfef66aa59a_2d75fc359c636369d39923d018976865&TranscodingMaxAudioChannels=6&RequireAvc=false&SegmentContainer=ts&SegmentLength=3&MinSegments=1&BreakOnNonKeyFrames=True&h264-maxrefframes=16&h264-videobitdepth=8&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&audiochannels=6&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported 2018-03-31 08:34:50.064 Info HttpServer: HTTP POST http://192.168.0.8:8096/emby/Sessions/Playing/Stopped. UserAgent: Roku/DVP-8.0 (388.00E04156A) log.log
gfrung4 0 Posted March 31, 2018 Author Posted March 31, 2018 It says 3.0.64 in the upper corner of settings.
Luke 42208 Posted March 31, 2018 Posted March 31, 2018 Can you try the beta app and see how that compares: https://emby.media/community/index.php?/topic/41174-welcome-to-the-new-roku-app-beta/ Thanks.
gfrung4 0 Posted March 31, 2018 Author Posted March 31, 2018 Can you try the beta app and see how that compares: https://emby.media/community/index.php?/topic/41174-welcome-to-the-new-roku-app-beta/ Thanks. It says I don't have permission to view that forum!
ebr 16310 Posted April 1, 2018 Posted April 1, 2018 Hi. You can install it from the Roku page on the main website. Thanks.
Luke 42208 Posted April 1, 2018 Posted April 1, 2018 @@gfrung4 please let us know if this helps. Thanks !
