tekman13 0 Posted March 30, 2018 Posted March 30, 2018 I noticed Emby is not HW transcoding on my machine anymore. I'm certain it has used hardware to transcode in the past, and pretty sure it was as recently as a couple weeks ago. Now when I play media, I am seeing high CPU utilization from ffmpeg, and 0% GPU utilization. I have an i7-7700, and 2 streams is too much for it to even handle. Any ideas on why it isn't using HW? I checked to make sure HW encoding is enabled in the server settings, and checked the log and it appears that quicksync (libmfx) is enabled in the ffmpeg config (though to TBH I'm not the most experienced with ffmpeg and what don't really know what I'm looking for when it comes to diagnosing). Any thoughts, or anyone else notice this? Server-Log.txt Transcode-Log.txt
Luke 42208 Posted March 30, 2018 Posted March 30, 2018 I would double check to make sure that you have it enabled in server transcoding settings. Also did you overwrite the included ffmpeg executable with your own version? That doesn't look like the one we supply with the server. While you're certainly welcome to do this, you're going to be kind of on your own as far as troubleshooting is concerned. Thanks.
tekman13 0 Posted March 30, 2018 Author Posted March 30, 2018 Confirmed I have hardware transcoding enabled. It is set to Intel QuickSync. I've even tried to toggle it back and forth a few times to see if that reset something. (super technical level of troubleshooting) I have not replaced ffmpeg. I just reinstalled the OS last night and the only things installed right now are firefox, bitdefender, and emby. OS is windows 10. Emby was downloaded directly from the web.
tekman13 0 Posted March 30, 2018 Author Posted March 30, 2018 Again, not an expert, but looking at the logs again, it looks like the ffmpeg call is missing the --hwaccel options. (Assuming that's necessary for quicksync acceleration.)
Luke 42208 Posted March 30, 2018 Posted March 30, 2018 My mistake, sorry. Can you show a screenshot of your server transcoding settings? thanks.
cybergrimes 93 Posted April 1, 2018 Posted April 1, 2018 Try turning off decode but leave encoding checked, see if you get a different result.
tekman13 0 Posted April 1, 2018 Author Posted April 1, 2018 Turning off decoding pings both the GPU and CPU at 50-60%% for a single stream. It also doesn’t release the resources for a couple minutes after ending the stream. I have an i7-7700. I should be able to get more than 1 stream out of it (and previous to a few weeks ago I thought I saw transcodes at around 10-15% GPU and negligible CPU).
tekman13 0 Posted April 1, 2018 Author Posted April 1, 2018 Turning off decoding pings both the GPU and CPU at 50-60%% for a single stream. It also doesn’t release the resources for a couple minutes after ending the stream. I have an i7-7700. I should be able to get more than 1 stream out of it (and previous to a few weeks ago I thought I saw transcodes at around 10-15% GPU and negligible CPU). Additionally, the stream never actually plays. I’m only getting the first frame. It just sits with a spinning circle after that.
tekman13 0 Posted April 2, 2018 Author Posted April 2, 2018 My mistake, sorry. Can you show a screenshot of your server transcoding settings? thanks.Any update or info I can try?
Luke 42208 Posted April 2, 2018 Posted April 2, 2018 Have you made sure that both windows and your graphics drivers are up to date?
tekman13 0 Posted April 2, 2018 Author Posted April 2, 2018 Have you made sure that both windows and your graphics drivers are up to date? Yes, but are latest (according to windows update)
tekman13 0 Posted April 2, 2018 Author Posted April 2, 2018 Yes, but are latest (according to windows update) Both* are latest
cybergrimes 93 Posted April 2, 2018 Posted April 2, 2018 (edited) Intel dropped new drivers on 3/27, Windows Update probably doesn't have them yet https://downloadcenter.intel.com/product/98909/Intel-HD-Graphics-630 Not sure it will change much, I get similar CPU/GPU usage on my i7-7700t also. I've seen QSV encoding around 10-15% on a single encode before too but not sure it was with Emby *shrug* Edited April 2, 2018 by cybergrimes
