capitaineflam25 71 Posted March 30, 2018 Posted March 30, 2018 (edited) Hi, after changing the audio source from a video, you can't navigate on the OSD until you hide it and show it again. This is a minor issue of course but a bit annoying when you want to switch the audio channel then adjust the subtitles. In this situation you can't navigate anymore to select the "CC" menu unless you press "back, down, right, right, right, right, right, OK" Regards Edited April 3, 2018 by capitaineflam25
capitaineflam25 71 Posted April 3, 2018 Author Posted April 3, 2018 A similar situation occurs when you quickly press down when a video is starting. (You do that when you know you’ll have to change audio or subtitles on a media) I can do a video if it helps.
CBers 7554 Posted April 3, 2018 Posted April 3, 2018 It should have been fixed. https://emby.media/community/index.php?/topic/53973-osd-non-functional-after-turning-subs-onoff What version of the app are you running?
capitaineflam25 71 Posted April 4, 2018 Author Posted April 4, 2018 I’m on Beta channel, last test was with 1.5.63
ebr 16337 Posted April 4, 2018 Posted April 4, 2018 It is a tricky focus problem that just needs to be refined. Thanks.
