d00zah 152 Posted March 29, 2018 Posted March 29, 2018 There's a new feature in the server that's buggin' me (& some friends) that I'm hoping can be resolved with some custom CSS magic. 'ServerWMC Recordings' (Live TV plugin) now shows up on the home screen & is now necessary to view recent recordings. Is there any way to hide the 'ServerWMC Recordings' tile without impact on the display of recent recordings? Here's hoping... TIA
Happy2Play 9811 Posted March 29, 2018 Posted March 29, 2018 I will have to look for my post on this, but are you referring to the My Media section?
d00zah 152 Posted March 29, 2018 Author Posted March 29, 2018 I will have to look for my post on this, but are you referring to the My Media section? Precisely. Thanks!
Happy2Play 9811 Posted March 29, 2018 Posted March 29, 2018 You just need to get the data-id for the library. Click on the library and use the topparentid from url. https://emby.media/community/index.php?/topic/30882-how-do-i-remove-collections-from-home-screen/?p=296830
d00zah 152 Posted March 29, 2018 Author Posted March 29, 2018 (edited) You just need to get the data-id for the library. Click on the library and use the topparentid from url. https://emby.media/community/index.php?/topic/30882-how-do-i-remove-collections-from-home-screen/?p=296830 I see the following URL: http://localhost:8096/web/list.html?parentId=69e88d4e1462d56fb23d93d8a312d597&serverId=19ed211e30584810997fa68ecd1c0fbd where I see a 'parentid', but adding to your code yields no change... [data-itemid=69e88d4e1462d56fb23d93d8a312d597] {display: none !important;} Did I miss something? I see that standard library tile URLs contain a 'topparentid', while 'channel' tile URLs all look like URL above. Edited March 29, 2018 by d00zah
Happy2Play 9811 Posted March 30, 2018 Posted March 30, 2018 I see the following URL: http://localhost:8096/web/list.html?parentId=69e88d4e1462d56fb23d93d8a312d597&serverId=19ed211e30584810997fa68ecd1c0fbd where I see a 'parentid', but adding to your code yields no change... [data-itemid=69e88d4e1462d56fb23d93d8a312d597] {display: none !important;} Did I miss something? I see that standard library tile URLs contain a 'topparentid', while 'channel' tile URLs all look like URL above. Sorry looks like it changed to data-id instead of data-itemid. example as seen in browser console.
d00zah 152 Posted March 30, 2018 Author Posted March 30, 2018 (edited) Seems that changing the original: 'data-itemid' to 'data-id' was the only necessary change. [data-id=69e88d4e1462d56fb23d93d8a312d597] {display: none !important;} seems to have done the trick. Thank you, @@Happy2Play !!! Edited March 30, 2018 by d00zah
