jachin99 88 Posted March 27, 2018 Posted March 27, 2018 How would I accomplish this? I changed the fonts in media center using media center theme but the changes aren't reflected in EMC. I have found a donotedit_fonts.mcml but I would rather be cautious than jump right in. I have the font I like already installed I windows
throgmorton 96 Posted March 27, 2018 Posted March 27, 2018 How would I accomplish this? I changed the fonts in media center using media center theme but the changes aren't reflected in EMC. I have found a donotedit_fonts.mcml but I would rather be cautious than jump right in. I have the font I like already installed I windows You should search the forums but you should be able to use a CustomFontsFile I forget the exact name of the file but it should override the fonts in EMC Sent from my iPhone using Tapatalk 1
Solution jachin99 88 Posted March 27, 2018 Author Solution Posted March 27, 2018 I figured it out thanks. For chocolate at least fonts are stored in the themes folder in a fonts.mcml file. It's really simple to change them. 1
Smitty018210 146 Posted March 28, 2018 Posted March 28, 2018 I figured it out thanks. For chocolate at least fonts are stored in the themes folder in a fonts.mcml file. It's really simple to change them. Hey if you don't mind where on you system were the files located?
jachin99 88 Posted March 28, 2018 Author Posted March 28, 2018 I'm not in front of my machine but I believe they were nested somwhere in C\programdata\mediabrowser. If you go there, then do a search in file explorer for fonts, you should get a list of the various font files. I didn't edit the one that says do not edit. You have to find the fonts for your particular theme or skin. They should be nested in the theme's folder. I can look later if need be just let me know. 1
Smitty018210 146 Posted March 28, 2018 Posted March 28, 2018 I'm not in front of my machine but I believe they were nested somwhere in C\programdata\mediabrowser. If you go there, then do a search in file explorer for fonts, you should get a list of the various font files. I didn't edit the one that says do not edit. You have to find the fonts for your particular theme or skin. They should be nested in the theme's folder. I can look later if need be just let me know. I was looking for these awhile back and forgot where they were. Thanks.
