pünktchen 1410 Posted March 26, 2018 Posted March 26, 2018 (edited) I try to duplicate some of Emby's tv schedules methodes to my live tv plugins, but the implementation of "ILibraryManager" doesn't work. I get a System.argument.Null.Exception. What i'm doing wrong? using System; using System.Collections.Generic; using System.Linq; using System.Threading; using System.Threading.Tasks; using MediaBrowser.Controller.Entities; using MediaBrowser.Controller.Entities.TV; using MediaBrowser.Controller.Library; using MediaBrowser.Controller.LiveTv; using MediaBrowser.Model.Extensions; using MediaBrowser.Model.Tasks; namespace MediaBrowser.Plugins.MediaPortal.Helpers { public class CheckTimers { //private readonly ILibraryManager _libraryManager; public void SkipTimers(CancellationToken cancellationToken) { MediaPortal1TvService tvservice = new MediaPortal1TvService(); var timers = tvservice.GetTimersAsync(cancellationToken).Result; foreach ( var timer in timers) { if (IsAlreadyInLibrary(timer)) { tvservice.CancelTimerAsync(timer.Id, cancellationToken); } } } public bool IsAlreadyInLibrary(TimerInfo timer) { if ((timer.EpisodeNumber.HasValue && timer.SeasonNumber.HasValue) || !string.IsNullOrWhiteSpace(timer.EpisodeTitle)) { var seriesIds = (this as ILibraryManager).GetItemIds(new InternalItemsQuery { IncludeItemTypes = new[] { typeof(Series).Name }, Name = timer.Name }).Select(i => i.ToString("N")).ToArray(); // It never reaches this point. System.Argument.Null.Exception if (seriesIds.Length == 0) { return false; } //if (timer.EpisodeNumber.HasValue && timer.SeasonNumber.HasValue) //{ // var episode = _libraryManager.GetItemIds(new InternalItemsQuery // { // IncludeItemTypes = new[] { typeof(Episode).Name }, // ParentIndexNumber = timer.SeasonNumber.Value, // IndexNumber = timer.EpisodeNumber.Value, // AncestorIds = seriesIds, // IsVirtualItem = false, // Limit = 1 // }); // if (episode.Count > 0) // { // return true; // } //} } return false; } } } Edited March 26, 2018 by pünktchen
pünktchen 1410 Posted March 26, 2018 Author Posted March 26, 2018 Line 816 at 2018-03-26 22:42:16.459
Luke 42239 Posted March 26, 2018 Posted March 26, 2018 Ok, your reference to _libraryManager is null. Try putting it into the constructor of your CheckTimers class.
pünktchen 1410 Posted March 26, 2018 Author Posted March 26, 2018 And that's my problem. How to do this without the need of implementing all methods of ILibraryManager? public class CheckTimers : ILibraryManager
Luke 42239 Posted March 26, 2018 Posted March 26, 2018 You don't need to do that. Create a constructor for CheckTimers public CheckTimers(ILibraryManager libraryManager){ _libraryManager = libraryManager; }
pünktchen 1410 Posted March 26, 2018 Author Posted March 26, 2018 But if i do this public class CheckTimers { private readonly ILibraryManager _libraryManager; public CheckTimers(ILibraryManager libraryManager) { _libraryManager = libraryManager; } //Do something } what would be the parameter here public Task CreateSeriesTimerAsync(SeriesTimerInfo info, CancellationToken cancellationToken) { Plugin.TvProxy.CreateSeriesSchedule(cancellationToken, info); CheckTimers checkTimers = new CheckTimers(); //Missing ILibraryManager Parameter checkTimers.SkipTimers(cancellationToken); return Task.Delay(0, cancellationToken); }
Luke 42239 Posted March 26, 2018 Posted March 26, 2018 Same concept in that class. Add it to the constructor all the way up your call chain.
pünktchen 1410 Posted March 26, 2018 Author Posted March 26, 2018 Success! You're the man! I really don't understand those constructors
ebr 16332 Posted March 27, 2018 Posted March 27, 2018 Success! You're the man! I really don't understand those constructors Google "dependency injection c#" for some light reading . 1
chef 3811 Posted March 27, 2018 Posted March 27, 2018 (edited) Google "dependency injection c#" for some light reading .I find being able to call the interfaces in the constructor sooo much easy to reuse class style structures. Make coding with the API very easy Edited March 27, 2018 by chef
pünktchen 1410 Posted April 1, 2018 Author Posted April 1, 2018 @@Luke is there a property to query for "Original Title" in ILibraryManager? var seriesIds = _libraryManager.GetItemIds(new InternalItemsQuery { IncludeItemTypes = new[] { typeof(Series).Name }, // OriginalName = seriesName }).Select(i => i.ToString("N")).ToArray();
pünktchen 1410 Posted April 1, 2018 Author Posted April 1, 2018 Another one: How to get the name or id off all libraries?
Luke 42239 Posted April 2, 2018 Posted April 2, 2018 Do you want the collection folders from library setup? or the actual folder paths within them?
pünktchen 1410 Posted April 3, 2018 Author Posted April 3, 2018 Do you want the collection folders from library setup? or the actual folder paths within them?Only the collections folder.
Luke 42239 Posted April 3, 2018 Posted April 3, 2018 Try this. var folders = _libraryManager.GetUserRootFolder().Children.ToList();
