Harbinger1080 3 Posted March 26, 2018 Posted March 26, 2018 In order to be more in line with other applications, and to improve compatibility with common utilities such as fail2ban, an option should be added to utilize logrotate instead of the built-in log rotation. Logrotate can take a standard log file name, and rollover on a schedule configured by the administrator, compress, and purge as specified. This also work well with utilities, such as fail2ban, that can greatly improve security of an exposed application like Emby. 2
Luke 42246 Posted March 26, 2018 Posted March 26, 2018 Hi, so basically you want to disable the built in log rotation and setup your own?
Harbinger1080 3 Posted March 26, 2018 Author Posted March 26, 2018 It would be preferable, yes. An option to disable built in rotation and use my own would work great, I think. People who don't want to fiddle could still have the workable solution you've already got, and other users could have a little more control and flexibility.
Luke 42246 Posted March 26, 2018 Posted March 26, 2018 This sort of thing would probably be left as a hidden config switch because otherwise we'll have to troubleshoot users that toggle it for no reason and then complain about a 10gb log file.
mastrmind11 722 Posted March 26, 2018 Posted March 26, 2018 (edited) Even if you left the existing built-in rotation intact, simply changing the name of the current log file from server-234523452345.txt to just server.txt would fix the fail2ban issue. Just append the date/time to server.txt when you roll the file. edit: Doing this would also make finding the current log file easier, w/o having to sort the files by time in order to find the most recent. Edited March 26, 2018 by mastrmind11 1
dcrdev 255 Posted March 26, 2018 Posted March 26, 2018 +1 for this Although I rely on Apache (proxy) logs for fail2ban - I utilise the logrotate facility quite extensively to compress and move log files around; sadly emby doesn't play nice with this because of the built in log rotator. 1
Luke 42246 Posted March 26, 2018 Posted March 26, 2018 Ok so maybe that standard behavior would be better than an option. 2
Luke 42246 Posted March 29, 2018 Posted March 29, 2018 This may help with fail2ban: https://emby.media/community/index.php?/topic/57525-33111-log-file-rotation
