naeyaert 8 Posted March 24, 2018 Posted March 24, 2018 Hello Emby I started to notice something weird over the past few weeks with tiles on my home screen missing on each library. The weird thing is, the missing tile is always the 4th image from the left. I have uploaded two screen shots of my setup, one on the "MY Movies" screen and one on "KIDS Movies" which shows the missing tiles in the yellow outline. It is ALWAYS the 4th tile on the screen. When I select the movie and the exit out, the image loads fine. It's almost like I need to refresh just that image on the 4th movie. Can you please let me know how to fix this as it's slightly annoying having to refresh the image to see what the movie is. Many thanks for your help in advance. Rob
naeyaert 8 Posted March 25, 2018 Author Posted March 25, 2018 Hi, I'll do some testing on this, thanks. Thanks - is there anything more you need from me?
naeyaert 8 Posted March 27, 2018 Author Posted March 27, 2018 No, I'm looking into it, thanks. Hi - just checking to see if there is any progress on this please? Many thanks
joshhuggins 22 Posted March 30, 2018 Posted March 30, 2018 Yeah seeing this again too last few versions, maybe 2-3 versions after the last time it was fixed. Usually I can scroll them just off screen and scroll them back on and they display instantly. Seems to be a draw glitch or something since they re-appear so quick.
naeyaert 8 Posted March 30, 2018 Author Posted March 30, 2018 Just checking if there is a resolution to this yet? Many thanks in advance. Cheers Rob
naeyaert 8 Posted April 4, 2018 Author Posted April 4, 2018 Still looking into it, thanks. any update on this please?
Luke 42243 Posted April 5, 2018 Posted April 5, 2018 I have not been able to reproduce it. I am still investigating it. Thanks.
GhostRider 49 Posted April 5, 2018 Posted April 5, 2018 I have the same issue. I see this missing tile effect for the some columns in both Emby Theater and the Web interface for recently added items. Always the missing tiles are in the same column. Clicking on one of them causes all the missing tiles to reappear when you go back.
