Jay99 3 Posted March 23, 2018 Posted March 23, 2018 Android TV does not remember the login info after closing app. I'm using an Nvidia Shield TV 2017
mastrmind11 722 Posted March 23, 2018 Posted March 23, 2018 I assume you have it set to remember last login in the app?
ebr 16338 Posted March 23, 2018 Posted March 23, 2018 Yes, please confirm what you have set the login behavior to (first option in settings). We don't default this on in TV apps because they are typically used in shared situations.
Jay99 3 Posted March 23, 2018 Author Posted March 23, 2018 Yes, this is set to remember however its not doing so.
ebr 16338 Posted March 23, 2018 Posted March 23, 2018 What, exactly, is the option set to and what, exactly is happening? How to Report a Problem
Jdiesel 1439 Posted March 24, 2018 Posted March 24, 2018 Also see this. App fails to load on the first attempt. Second attempt usually works but requests the login information.
deallier 8 Posted March 27, 2018 Posted March 27, 2018 Hi i have the same problem and yes it is set to login as the last user but 8 times out of ten i does not work plus occasionally the app won't start the first time and your new beta Emby tv V 1.5.63g is the same thanks
ebr 16338 Posted March 27, 2018 Posted March 27, 2018 Hi i have the same problem and yes it is set to login as the last user but 8 times out of ten i does not work plus occasionally the app won't start the first time and your new beta Emby tv V 1.5.63g is the same thanks Hi. Please see the link posted above for instructions on reproducing and reporting this issue. It sounds like a potential network problem where the initial login attempt is failing.
deallier 8 Posted March 27, 2018 Posted March 27, 2018 hi thanks but it is not a network problem it only happens with emby tv plus the server is not on the locale network but 20 miles away on a fiber line so all connections are WAN and not on the https i would have though that the connection works the same as Emby for android maybe i am wrong thanks ps : Ebr i would be more than happy to give you access to the server to see you or Luke emby is a great system works really well with chrome but the apps just let it down i am sure it will get there in the end
Luke 42246 Posted March 28, 2018 Posted March 28, 2018 @@deallier, can you provide the information that @@ebr requested? We are happy to help. Just click the link he posted and scroll down to the bottom. There are instructions on how you can submit an android tv app log. Thanks !
x-cimo 23 Posted May 2, 2018 Posted May 2, 2018 Same issue here. I just sent logs 3 minutes ago. I have the setting to save password. However on the shield remote when I press back all the way so emby closed and I get back to the Android TV launcher. The next time I start emby it will display a connection error then bring me to the list of users. If I enter the password it works fine... Until I do the same thing. User was JP Thanks
Jdiesel 1439 Posted May 2, 2018 Posted May 2, 2018 Same issue here. I just sent logs 3 minutes ago. I have the setting to save password. However on the shield remote when I press back all the way so emby closed and I get back to the Android TV launcher. The next time I start emby it will display a connection error then bring me to the list of users. If I enter the password it works fine... Until I do the same thing. User was JP Thanks Are you using a reverse proxy by chance?
x-cimo 23 Posted May 2, 2018 Posted May 2, 2018 Not in this example. In this case I am connected directly to the server IP. But I do also have a reverse proxy with https. The Android TV app just doesn't want to connect using the reverse proxy at all..
Luke 42246 Posted May 2, 2018 Posted May 2, 2018 Not in this example. In this case I am connected directly to the server IP. But I do also have a reverse proxy with https. The Android TV app just doesn't want to connect using the reverse proxy at all.. Possible configuration problem with the reverse proxy?
Luke 42246 Posted May 2, 2018 Posted May 2, 2018 Same issue here. I just sent logs 3 minutes ago. I have the setting to save password. However on the shield remote when I press back all the way so emby closed and I get back to the Android TV launcher. The next time I start emby it will display a connection error then bring me to the list of users. If I enter the password it works fine... Until I do the same thing. User was JP Thanks Does this happen if you try this immediately after backing out to the android tv launcher?
x-cimo 23 Posted May 2, 2018 Posted May 2, 2018 Yes. Step to reproduce were Back back ... Back to Android launcher. Launch emby right away. Unable to connect. Then user screen. I have re applied the setting to login as current user and save password. Uncheck then re check setting and it appears to stick for now. So there is a little glitch somewhere. I'll report back if it break again
ebr 16338 Posted May 2, 2018 Posted May 2, 2018 Yes. Step to reproduce were Back back ... Back to Android launcher. Launch emby right away. Unable to connect. Then user screen. I have re applied the setting to login as current user and save password. Uncheck then re check setting and it appears to stick for now. So there is a little glitch somewhere. I'll report back if it break again Did the password change at some point?
mastrmind11 722 Posted May 2, 2018 Posted May 2, 2018 I ran into this when I migrated servers (same IP). Fix was to remove the old server from the app and add the new one.
Jdiesel 1439 Posted May 2, 2018 Posted May 2, 2018 It may not be the same issue as I had but when I was messing around with setting up SSL I had be switching between different certs and reverse proxy setups. At a certain point the ATV stopped remembering my login credentials. My solution was to clear the Android app data from the Emby app.
ebr 16338 Posted May 3, 2018 Posted May 3, 2018 I'll look at improving this. Probably the app just needs to forget any saved login information if the automatic login ever fails.
hsran 0 Posted June 30, 2018 Posted June 30, 2018 I’m facing this exact problem.Had this a few months back with stable builds but then I moved to the beta builds which rectified this issue.Now for some reason I think I’m back on stable builds and every time I have to type in my password Android TV version 1.6.40g Android 7.0 (TCL C2US Series) Server 3.4.1.0 on a Debian 9
neik 874 Posted June 30, 2018 Posted June 30, 2018 @@hsran, I was having the same issue but ebr's suggestion over here (https://emby.media/community/index.php?/topic/59410-single-sign-in-and-refresh-rate-adaption-not-working/&do=findComment&comment=582335) solved it. You might want to try it!
frankw 10 Posted August 5, 2018 Posted August 5, 2018 (edited) I also have this problem as soon as the app is force closed or the system rebooted. It happens on 2 nvidia shield boxes, 1 local and 1 remote. No reverse proxy involved. I have tried the fix suggested by Jdiesel but that does fix the issue. Edit: nm fix suggested by ebr seems to have worked, very strange. Cheers Edited August 5, 2018 by frankw
sch586 5 Posted June 21, 2020 Posted June 21, 2020 @ebr @CBers How do you set it to remember last login. I dont see any way to do that on the Emby Server. Do you have to do that on the Nvidia Shield box? If so, please explain how to do this in detail as I am an old man and just trying to watch my dvds. Thank You!
