FreshDog 8 Posted April 14, 2018 Posted April 14, 2018 I personally don't have this issue as I have one movie per folder, but perhaps it is affecting many people. Actually you (and everybody else) also have this issue. In your case It's just less notable as in my case. In your case every movie gets scanned twice. Once through the regular folder scan and one more time through the scan of the movie itself (because the movie's parent is the same folder). Therefore in your case the overall rescan time is about twice as long as it needs to be. 1
PenkethBoy 2068 Posted April 14, 2018 Posted April 14, 2018 I have tested this also and longer library scans with movies all in one directory do significantly increase the time taken by orders of magnitude so the issue @@FreshDog has highlighted is likely one of the reasons why slow scans are reported quite often if unnecessary double scans are taking place then it needs to be fixed also If there are other issues Luke has alluded to then those need to be fixed as well Its been going on too long and needs a resolution before we move to new features 2
CBers 7542 Posted April 14, 2018 Posted April 14, 2018 OK, perhaps it's not as evident with my libraries as it is with yours Still, it needs fixing.
Happy2Play 9802 Posted April 14, 2018 Posted April 14, 2018 Actually you (and everybody else) also have this issue. In your case It's just less notable as in my case. In your case every movie gets scanned twice. Once through the regular folder scan and one more time through the scan of the movie itself (because the movie's parent is the same folder). Therefore in your case the overall rescan time is about twice as long as it needs to be. Hmm if it is scanning twice, I have really good speeds for 16TB. Last ran a minute ago, taking 1 minute and 45 seconds.
CBers 7542 Posted April 14, 2018 Posted April 14, 2018 Hmm if it is scanning twice, I have really good speeds for 16TB. Last ran a minute ago, taking 1 minute and 45 seconds. And you have all of your movies in one folder?
Happy2Play 9802 Posted April 14, 2018 Posted April 14, 2018 And you have all of your movies in one folder? No they are movie per folder. I was just commenting on FreshDog's post how with that structure we should be experience this double scan scenario. Sure 52 second 16TB scans would sound really good.
PenkethBoy 2068 Posted April 14, 2018 Posted April 14, 2018 lol - 16TB is meaningless its the number of items of media that need to be scanned that matters - 40GB 4k video file has the same effect as a 3GB 1080p video file for the same movie
Happy2Play 9802 Posted April 14, 2018 Posted April 14, 2018 lol - 16TB is meaningless its the number of items of media that need to be scanned that matters - 40GB 4k video file has the same effect as a 3GB 1080p video file for the same movie Okay for my example Movies x 3497 Episodes x 14298 Songs x 3212 Last ran a minute ago, taking 1 minute and 45 seconds.
CBers 7542 Posted April 14, 2018 Posted April 14, 2018 Okay for my example Movies x 3497 Episodes x 14298 Songs x 3212 Last ran a minute ago, taking 1 minute and 45 seconds. So your library might be a good test case for @@FreshDog's observations.
