guymyer 1 Posted March 21, 2018 Posted March 21, 2018 Just got a Sony Bravia, my audio receiver is only capable of DD and DTS over optical. I'm getting DD 5.1 from other apps and pass through from HDMI input but emby isn't sending it. My receiver is receiving 2 channels. Downmix to stereo is not checked. Any thoughts? Going nuts trying to figure it out.
ebr 16337 Posted March 21, 2018 Posted March 21, 2018 From what other apps? If you follow the instructions to send an in app log, we can take a look. Thanks.
guymyer 1 Posted March 21, 2018 Author Posted March 21, 2018 I'm getting 5.1 from netflix, hulu, amazon prime, i also tried Kodi with emby plugin... 5.1. Emby app itself isn't getting 5.1. I'll submit a log once I get home and report the time.
guymyer 1 Posted March 21, 2018 Author Posted March 21, 2018 I just hit send log. 12pm eastern. Though I'm not sure it went through, got the android app timeout/ stopped responding. I hit wait but it didn't ever seem to completely finish.
ebr 16337 Posted March 21, 2018 Posted March 21, 2018 I just hit send log. 12pm eastern. Though I'm not sure it went through, got the android app timeout/ stopped responding. I hit wait but it didn't ever seem to completely finish. Sounds like you will need to try again but I need to know the name of the Emby user logged in and what, exactly, you did during the session for which you sent the log. Thanks. Then add the following information to your report in the forum: Exactly what you were doing and what happened. Include the name of whatever you played if it is a playback problem The time you sent the log The name of the Emby user on the local server that was logged in at the time
guymyer 1 Posted March 21, 2018 Author Posted March 21, 2018 Every time I try to send a lot I get the.. "Emby isn't responding" error.
ebr 16337 Posted March 21, 2018 Posted March 21, 2018 Are you on the release version of the app? If so, can you try the beta?
guymyer 1 Posted March 21, 2018 Author Posted March 21, 2018 I should be on the beta already. I'll try getting off the beta and see if I can then send. I did however just try sending one and it went through.. about 3:10pm. username will, played contact
guymyer 1 Posted March 21, 2018 Author Posted March 21, 2018 Actually... Turning off beta got my 5.1 Dolby back. DTS however is now being downmuxed to 2.0. Is there a setting to have 5.1 DTS muxed to 5.1 DD?
ebr 16337 Posted March 21, 2018 Posted March 21, 2018 I should be on the beta already. I'll try getting off the beta and see if I can then send. I did however just try sending one and it went through.. about 3:10pm. username will, played contact There is no playback in this log...
