Happy2Play 9806 Posted October 13, 2018 Posted October 13, 2018 (edited) I noticed today the scrollbar appears miraculously in the first attempt, did you do something server side maybe? There hasn't been a new Stable release, so no. Unless you were only seeing the issue via Connect? Edited October 13, 2018 by Happy2Play
Richard Branches 336 Posted October 13, 2018 Author Posted October 13, 2018 (edited) There hasn't been a new Stable release, so no. Unless you were only seeing the issue via Connect? I don't need to use connect on the browser, it always connects automatically, but I was using an static IP so I'm going to switch again to that to confirm and I'll let you know. Edited October 13, 2018 by delacosta78
Happy2Play 9806 Posted October 13, 2018 Posted October 13, 2018 I made the comment about Connect because it provides different versioning as it is web based and usually is very close to the Beta branch. If you are connecting to your server via ip/hostname/localhost you are seeing your installed version.
Luke 42216 Posted October 13, 2018 Posted October 13, 2018 No, didn't do anything. Perhaps you weren't able to locate it before?
Richard Branches 336 Posted October 13, 2018 Author Posted October 13, 2018 I switched to static IP and the scrollbar appeared in the first attempt so I wonder why it's working OK this time.
Richard Branches 336 Posted October 13, 2018 Author Posted October 13, 2018 (edited) Unfortunately it's broken again, it goes back and forth... Edited October 13, 2018 by delacosta78
Richard Branches 336 Posted January 15, 2019 Author Posted January 15, 2019 On the new 4.0 version of the server the scroll bar is still broken...
Happy2Play 9806 Posted January 15, 2019 Posted January 15, 2019 On the new 4.0 version of the server the scroll bar is still broken... I have a scroll bar in Edge, Firefox and Chrome.
Richard Branches 336 Posted January 15, 2019 Author Posted January 15, 2019 (edited) I have a scroll bar in Edge, Firefox and Chrome. I do have it when I press F5 everytime!!, isn't that nice!?... Edited January 15, 2019 by delacosta78
Happy2Play 9806 Posted January 15, 2019 Posted January 15, 2019 I do have it when I press F5 everytime!!, isn't that nice!... Is this specific to one machine? I have tested on multiple local machines and logging via app.emby.media and all have scollbar.
Q-Droid 1003 Posted January 16, 2019 Posted January 16, 2019 (edited) On the new 4.0 version of the server the scroll bar is still broken... What type of monitor do you have? I also had this problem (posted in this thread) and recently had to replace my monitor. Wouldn't you know it the problem went away. Old monitor was a 16:10 (WSXGA+) 1680x1050 Acer. The new one is a full HD 16:9 1920x1080 Dell. Also changed from DVI to HDMI cable. I don't know why but the problem went away from Opera and Chrome. I don't know if the browsers didn't like the old aspect ratio, resolution or what. Not likely that the monitor itself was at fault. Edit: Added a few details. Edited January 16, 2019 by Q-Droid
Richard Branches 336 Posted January 16, 2019 Author Posted January 16, 2019 What type of monitor do you have? I also had this problem (posted in this thread) and recently had to replace my monitor. Wouldn't you know it the problem went away. Old monitor was a 16:10 1680x1050 Acer. The new one is a full HD 16:9 1920x1080 Dell. I don't know why but the problem went away from Opera and Chrome. I don't know if the browsers didn't like the old aspect ratio, resolution or what. Not likely that the monitor itself was at fault. I'm using a laptop with 1366x768px screen, I have another computer (all-in-one) with a resolution a little bit higher than this so I'm gonna check on that as soon as I can.
Luke 42216 Posted January 16, 2019 Posted January 16, 2019 Yes i can reproduce when you leave the dashboard and then come back to it. Thanks.
