Alexwerilles 3 Posted October 10, 2023 Posted October 10, 2023 On 10/28/2022 at 3:31 PM, iBoss said: I believe the guys here more experience than me in Nginx... and pasting my configuration will not help because it is exactly same as the first post. I'll help you but first what are you using, Nginx (Docker or not) or Nginx Proxy Manager? also please paste your configuration. Thanks can you still help me? (yes, I only saw it almost a year later)
Luke 42239 Posted October 10, 2023 Posted October 10, 2023 3 hours ago, Alexwerilles said: can you still help me? (yes, I only saw it almost a year later) Hi, I would also suggest looking at this:
Alexwerilles 3 Posted October 11, 2023 Posted October 11, 2023 20 hours ago, Luke said: Hi, I would also suggest looking at this: yes, I use the config in this topic, but I never managed to make the speed limitation work. I don't know if I'm putting the code in the wrong place, but I've never been able to
Luke 42239 Posted October 11, 2023 Posted October 11, 2023 2 hours ago, Alexwerilles said: yes, I use the config in this topic, but I never managed to make the speed limitation work. I don't know if I'm putting the code in the wrong place, but I've never been able to OK, @pir8radio may have some tips.
