Guest plexman Posted March 20, 2018 Posted March 20, 2018 (edited) Emby has the amazing feature to allow users to download content. This is pretty cool but when an user downloads content it uses all available bandwith of your server. Adding this location block in your nginx config will limit the speed of the download and the number of simultaneous downloads per IP address. # Add this outside of you server block limit_conn_zone $binary_remote_addr zone=addr:10m; # Bandwith limit (inside server block) location ~ /emby/Items/(.*)/Download$ { # Send traffic to the backend proxy_pass http://localhost:8096; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; # Send websocket data to the backend aswell proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "upgrade"; limit_rate 1700k; # Speed limit (here is on kb/s) limit_conn addr 3; # Number of simultaneous downloads per IP limit_conn_status 460; proxy_buffering on; } # Error page error_page 460 http://your-page-telling-your-limit/; So in this case 3 parallel downloads at 1,7 Mb/s (note that Nginx takes speed values, not bandwith) are allowed, the "460 error" (you can specify whatever error number you want) redirects the user to a custom page when he tries to download the 4th item. In my case I have a webpage telling something like "Ops... You are downloading too much... Wait until your current downloads are completed" Hope it helps somebody! References: https://emby.media/community/index.php?/topic/47508-how-to-nginx-reverse-proxy/ https://www.nginx.com/blog/rate-limiting-nginx/ Edited September 17, 2018 by plexman
Guest plexman Posted September 17, 2018 Posted September 17, 2018 I've edited the location regex with a cleaner one.
Justy 2 Posted April 25, 2019 Posted April 25, 2019 Hi, I'm following this community since almost one year. It's amazing and you can find many answers to almost every question. But now I'm stuck. Is this config still working with actual emby 4.1.0.26? i put it in my nginx, but does not seem to have any effect.Thanks in advance
Justy 2 Posted July 6, 2019 Posted July 6, 2019 (edited) Hi @@plexman, please see my configs below. I think I placed your code at the wrong places. Can you check/help?FYI: I build my config by several post i.e. by Swynol's .And I'm a newbie in nginx and linux.My emby server is running on openmediavault 4; no docker;nginx.conf user www-data; worker_processes 2; pid /run/nginx.pid; include /etc/nginx/modules-enabled/*.conf; events { worker_connections 1024; # multi_accept on; } http { ## # Basic Settings ## sendfile on; tcp_nopush on; tcp_nodelay on; keepalive_timeout 65; types_hash_max_size 2048; # server_tokens off; # server_names_hash_bucket_size 64; # server_name_in_redirect off; include /etc/nginx/mime.types; default_type application/octet-stream; ## # SSL Settings ## ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE ssl_prefer_server_ciphers on; ## # Logging Settings ## access_log /var/log/nginx/access.log; error_log /var/log/nginx/error.log; ## # Gzip Settings ## gzip on; gzip_disable "msie6"; # gzip_vary on; # gzip_proxied any; # gzip_comp_level 6; # gzip_buffers 16 8k; # gzip_http_version 1.1; # gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript; #timeout #proxy_connect_timeout 1h; #proxy_send_timeout 1h; #proxy_read_timeout 1h; #limit_conn_zone $binary_remote_addr zone=addr:10m; ## # Virtual Host Configs ## include /etc/nginx/conf.d/*.conf; include /etc/nginx/sites-enabled/*; } sites-available limit_conn_zone $binary_remote_addr zone=addr:10m; server { listen 443 ssl http2; listen [::]:443 ssl http2; ssl_certificate /etc/ssl/certs/openmediavault.crt; ssl_certificate_key /etc/ssl/private/openmediavault.key; ssl_dhparam /etc/ssl/certs/dhparam.pem; server_name emby.emby4ever.de; index index.html; access_log /var/log/nginx/1c5b4f27-66bb-4384-a5c0-access.log; error_log /var/log/nginx/1c5b4f27-66bb-4384-a5c0-error.log; large_client_header_buffers 4 8k; server_tokens off; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_ciphers 'ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA'; ssl_prefer_server_ciphers on; location ^~ /swagger { ## Disables access to swagger interface return 404; } location ~ /emby/Items/(.*)/Download$ { proxy_pass http://192.168.178.24:8096; # Local emby ip and non SSL port proxy_hide_header X-Powered-By; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; add_header 'Referrer-Policy' 'no-referrer'; add_header Strict-Transport-Security "max-age=63072000; includeSubdomains; preload" always; add_header X-Frame-Options "SAMEORIGIN" always; add_header X-Content-Type-Options "nosniff" always; add_header X-Xss-Protection "1; mode=block" always; add_header Content-Security-Policy "default-src 'none'; child-src 'self'; font-src 'self' data:; connect-src 'self' wss: ws: https://mb3admin.com https://github.com/MediaBrowser/; media-src 'self' blob: data: https://github.com/MediaBrowser/; manifest-src 'self'; base-uri 'none'; form-action 'self'; frame-ancestors 'self'; object-src 'none'; worker-src 'self' blob:; script-src 'self' https://www.gstatic.com; img-src data: https: http: ; style-src 'unsafe-inline' 'self' https://fonts.googleapis.com/css" always; #Next three lines allow websockets proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection ""; limit_rate 1700k; # Speed limit (here is on kb/s) limit_conn addr 3; # Number of simultaneous downloads per IP limit_conn_status 460; proxy_buffering on; } } thanks in advance Justy Edited July 18, 2019 by Justy
Guest plexman Posted July 9, 2019 Posted July 9, 2019 I don't see any error in your config, what does the command "nginx -t" say? The only thing I see, not relative to the download, limit is this line in websockets: proxy_set_header Connection ""; Should it be?: proxy_set_header Connection "upgrade";
Justy 2 Posted July 9, 2019 Posted July 9, 2019 where did you find "nginx -t"? Can't find it. proxy_set_header Connection ""; I have it from here: https://emby.media/community/index.php?/topic/48236-setting-up-emby-behind-a-reverse-proxy-nginx/ post #96 ------------------------- but I forgot something:Shouldn' there be also a line like this location / {proxy_pass http://192.168.178.24:8096; # Local emby ip and non SSL port beforelocation ~ /emby/Items/(.*)/Download$ { or both locations???
Justy 2 Posted July 9, 2019 Posted July 9, 2019 (edited) Ah, I checked it : root@omv:~# nginx -tnginx: the configuration file /etc/nginx/nginx.conf syntax is oknginx: configuration file /etc/nginx/nginx.conf test is successful Edited July 9, 2019 by Justy
Justy 2 Posted July 9, 2019 Posted July 9, 2019 Hi plexman,I was thinking about the problem this evening. Maybe this is not correct for me:location ~ /emby/Items/(.*)/Download$ {nginx does not find anything here ??
Justy 2 Posted July 25, 2019 Posted July 25, 2019 (edited) Hi @@plexman, I figured it out!I don't know why, but my path is https://emby.mydomain.de/web/index.html#!/itemdetails.html?id=43802&serverId=xyz it should be (If I add /emby/ between it already works) https://emby.mydomain.de/emby/web/index.html#!/itemdetails.html?id=43802&serverId=xyz So first option is to change/correct path herelocation ~ /emby/Items/(.*)/Download$ {or to correct https://emby.mydomain.de/web/index.html#!/itemdetails.html?id=43802&serverId=xyz But how can I achieve this? Can you help? why is the /emby missing???Thanks in advance justy Edited July 25, 2019 by Justy
Justy 2 Posted August 6, 2019 Posted August 6, 2019 (edited) Hi, so I finally got it. Just for information for everyone: location ~ /Items/(.*)/Download$ { proxy_pass http://192.168.178.24:8096; # Local emby ip and non SSL port proxy_hide_header X-Powered-By; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_redirect off; #Next three lines allow websockets proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "upgrade"; limit_rate 2500k; # Speed limit (here is on kb/s) limit_conn addr 1; # Number of simultaneous downloads per IP limit_conn_status 460; # custom error page proxy_buffering on; } error_page 460 /460.html; # for a custom local hosted error page (named 460.html) location = /460.html { root /var/www/html; # path to the local error page internal; } and in http { limit_conn_zone $binary_remote_addr zone=addr:10m; just one question for the pro's:What do I have to change, because the error page does not show up after clicking for second download at once. it shows instead file not available 404. After a refresh it shows the custom error page? Edited August 6, 2019 by Justy
Luke 42239 Posted July 29, 2021 Posted July 29, 2021 On 7/12/2021 at 3:59 PM, Alexwerilles said: It doesn't seem to work anymore Hi there, what exactly is the issue?
iBoss 31 Posted May 9, 2022 Posted May 9, 2022 This is amazing and working perfectly but only with emby web browser. how can I make it work with apps like emby iOS Thanks
Luke 42239 Posted May 9, 2022 Posted May 9, 2022 1 hour ago, iBoss said: This is amazing and working perfectly but only with emby web browser. how can I make it work with apps like emby iOS Thanks Hi there, can you please describe your issue in more detail? Thanks.
iBoss 31 Posted May 9, 2022 Posted May 9, 2022 @Luke When I add the nginx config that posted by "Guest plexman" or "Justy", it works and limit the IPs and the speed of the download .. but this only works when I use emby on the browser (like Chrome) ... but if I download the content from the emby app (like emby on iOS), it will use the full speed of internet without any limitation. Thanks
Luke 42239 Posted May 9, 2022 Posted May 9, 2022 23 minutes ago, iBoss said: @Luke When I add the nginx config that posted by "Guest plexman" or "Justy", it works and limit the IPs and the speed of the download .. but this only works when I use emby on the browser (like Chrome) ... but if I download the content from the emby app (like emby on iOS), it will use the full speed of internet without any limitation. Thanks Yea looks like he only designed it for the manual one-off downloads in the web app.
iBoss 31 Posted May 10, 2022 Posted May 10, 2022 @Luke Thats why I'm asking if there is anyway to make it works with mobile app as well? when I download manually from the web app it use: https://{my_emby_website}/emby/Items/{some_number}/Download?{api} so we are using this location ~ /emby/Items/(.*)/Download$ So I think we need to change it to the url download link that is used in mobile app Please anyone can help here? Thanks
iBoss 31 Posted May 15, 2022 Posted May 15, 2022 (edited) @Luke please, can you provide the the format of the url download link for mobile app? Thanks Edited May 15, 2022 by iBoss
Luke 42239 Posted May 16, 2022 Posted May 16, 2022 5 hours ago, iBoss said: @Luke please, can you provide the the format of the url download link for mobile app? Thanks Try /Sync/JobItems/{Id}/File 1
iBoss 31 Posted July 29, 2022 Posted July 29, 2022 On 5/16/2022 at 4:47 AM, Luke said: Try /Sync/JobItems/{Id}/File Many thanks @Luke ... this works 1
iBoss 31 Posted July 30, 2022 Posted July 30, 2022 please I need your support for two issues: 1) I have already limit the download speed for both Desktop and mobile ... but this module: limit_rate 2m; limit_conn addr 3; will limit the speed to 2MB per connection for one IP; so if there another connection for the same IP the speed of download will become 4MB. how I can keep the number of limit connection 3 with the bandwidth of 2MB: first connection: 2MB second connection: still 2MB ... divide the speed with two download I hope the first issue is clear -------------------------- 2) I want to exclude my IP from the limitation: I have tried this but does not wotk with me http{ geo $whitelist { default 0; xxx.xxx.xxx.xxx 1; #my IP } map $whitelist $limit { 0 $binary_remote_addr; 1 ""; } limit_conn_zone $limit zone=addr:10m; } --------- please any one can help? @pir8radio Thank
Alexwerilles 3 Posted October 20, 2022 Posted October 20, 2022 On 7/30/2022 at 7:22 AM, iBoss said: please I need your support for two issues: 1) I have already limit the download speed for both Desktop and mobile ... but this module: limit_rate 2m; limit_conn addr 3; will limit the speed to 2MB per connection for one IP; so if there another connection for the same IP the speed of download will become 4MB. how I can keep the number of limit connection 3 with the bandwidth of 2MB: first connection: 2MB second connection: still 2MB ... divide the speed with two download I hope the first issue is clear -------------------------- 2) I want to exclude my IP from the limitation: I have tried this but does not wotk with me http{ geo $whitelist { default 0; xxx.xxx.xxx.xxx 1; #my IP } map $whitelist $limit { 0 $binary_remote_addr; 1 ""; } limit_conn_zone $limit zone=addr:10m; } --------- please any one can help? @pir8radio Thank Can you share your nginx configuration privately? Until today I could never get this to work on my server
iBoss 31 Posted October 28, 2022 Posted October 28, 2022 On 10/20/2022 at 10:32 PM, Alexwerilles said: Can you share your nginx configuration privately? Until today I could never get this to work on my server I believe the guys here more experience than me in Nginx... and pasting my configuration will not help because it is exactly same as the first post. I'll help you but first what are you using, Nginx (Docker or not) or Nginx Proxy Manager? also please paste your configuration. Thanks
