Intel i3 6100 hardware acceleration mode?
I'm currently using AUTO as the acceleration mode but noticed some videos not playing full screen (although ET was full screen).
All other settings are default.
I switched it to AUTO copy back and it fixed some but not all videos but I'm not entirely sure the difference!
I don't have an issue with stuttering or anything so should I just set this to none?
Are there any draw backs from AUTO?
It's running Windows 10 on a gigabit network.
Edited by Crestj
Guest asrequested
Can you post a screenshot?
Well typically my HTPC crashed and now I can't get it to produce the error using AUTO on the video file that was causing issues !!!!
I'll try later when can try a few more files.
Maybe it's resolved itself!!!
On a side note, I can see the GPU load in task manager when I play a video in ET when set to AUTO so the acceleration is doing something.
