xbmcgotham 35 Posted March 19, 2018 Posted March 19, 2018 Hi, Not sure if its related to the recent app update, however I can't play any files anymore. When I click them, I get after a couple of seconds a "Fail. Click to exit" message. When I check the emby server dashboard it does show the video playing for the device. Attached the log. Thanks ps. I also notice a few error messages in the log. love to have them fixed as well. Log.txt
xbmcgotham 35 Posted March 19, 2018 Author Posted March 19, 2018 when I click the video to play, it opens the "play/black/next" page and you see a small loading circle, soon after instead of showing the play osd it shows a black screen with in the middle the text. and top left the return option.
xbmcgotham 35 Posted March 19, 2018 Author Posted March 19, 2018 even better attached S80319-21204115.mp4.zip
Luke 42244 Posted March 19, 2018 Posted March 19, 2018 As a test, can you try playing something that's not a movie?
Luke 42244 Posted March 19, 2018 Posted March 19, 2018 how about other videos? also what device is this on?
xbmcgotham 35 Posted March 19, 2018 Author Posted March 19, 2018 tv shows, music videos all give the same error. Meizu M6 Android
xbmcgotham 35 Posted March 19, 2018 Author Posted March 19, 2018 Worked fine before last update. and phone android os was not updated
ebr 16337 Posted March 19, 2018 Posted March 19, 2018 Are you running the Android version of the server or are you talking about the Android mobile app talking to the server on some other platform?
xbmcgotham 35 Posted March 19, 2018 Author Posted March 19, 2018 using the meizu M6 android phone with the latest android emby app
xbmcgotham 35 Posted March 19, 2018 Author Posted March 19, 2018 windows 7 sp1 running emby server Version 3.2.70.0
ebr 16337 Posted March 19, 2018 Posted March 19, 2018 Thank you . Please update your Emby server to the latest release. And, before you do so, please ensure Windows 7 has all update patches applied. You may have to run Windows update multiple times...
xbmcgotham 35 Posted March 20, 2018 Author Posted March 20, 2018 Hi, unfortunately this made no difference. Still same error.
xbmcgotham 35 Posted March 22, 2018 Author Posted March 22, 2018 @@ebr and @@Luke update please. not able to use Emby. Thanks
xbmcgotham 35 Posted March 23, 2018 Author Posted March 23, 2018 @ebr and @Luke reading the update history, it looks like you update the play osd. My best guess that its related to that part of the code.
xbmcgotham 35 Posted March 24, 2018 Author Posted March 24, 2018 With one phone I use it regularly, But that phone was not yet updated to the latest emby android version or android OS (Same phone hardware) and still works fine with playing videos. The other phone which gives the current problem described above had downloaded some files, and I use it some times to watch them and they play ok offline.
Luke 42244 Posted March 24, 2018 Posted March 24, 2018 Ok then let's wait until sometime next week. I can give you a test build to try but right now it would break the download feature due to other changes currently in progress.
