jachin99 88 Posted March 18, 2018 Posted March 18, 2018 I have setup mcphc as an external player in EMC and I have a custom mp4 intro and trailer enabled for cinema mode. When I try to play a movie, nothing happens. When I disable cinema mode, the movie plays fine through mpchc. I will provide logs but right now I'm at my machine. Has anyone else had this problem?
Luke 42238 Posted March 18, 2018 Posted March 18, 2018 Hi, please attach the emby for wmc log. thanks.
ebr 16332 Posted March 18, 2018 Posted March 18, 2018 I'm honestly not sure we ever supported Cinema mode with an external player in EMC. I'll have to double-check.
jachin99 88 Posted March 19, 2018 Author Posted March 19, 2018 Here are some logs. For this instance, MPC-HC played the movie fine but EMC didn't play any trailers or the video intro with cinema mode enabled. Thanks guys 2018-03-18 21:33:30.4810,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\strings-en.xml,1,Application 2018-03-18 21:33:30.5010,Debug,,=========System looking for assembly: System.Data.SQLite,, Version=1.0.88.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1,Application 2018-03-18 21:33:30.5010,Info,,System.Data.SQLite,, Version=1.0.88.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139 is being resolved to System.Data.SQLite,, Version=1.0.88.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1,Application 2018-03-18 21:33:30.5110,Info,,==========Using new SQL Repo========,1,Application 2018-03-18 21:33:30.6510,Info,,Playstate initialization took 0.01 seconds.,1,Application 2018-03-18 21:33:30.6610,Info,,Total Kernel Init took 0.22 seconds.,1,Application 2018-03-18 21:33:30.6910,Info,,Successfully loaded fastload data for : C:\ProgramData\MediaBrowser-Classic\Cache\playstate MediaBrowser.Library.Entities.PlaybackStatus,13,Worker thread for FastLoadLoader 2018-03-18 21:33:30.7310,Info,,Finished validating : C:\ProgramData\MediaBrowser-Classic\Cache\playstate MediaBrowser.Library.Entities.PlaybackStatus,13,Worker thread for FastLoadLoader 2018-03-18 21:33:30.7310,Info,,Dictionary loading and validation took 0.08 seconds.,13,Worker thread for FastLoadLoader 2018-03-18 21:33:31.0010,Info,,Information DisplayText: Welcome to Emby for WMC,1,Application 2018-03-18 21:33:31.0210,Info,,Emby (version 3.0.314.0 ) Starting up.,1,Application 2018-03-18 21:33:31.0210,Info,,Startup parameters: ,1,Application 2018-03-18 21:33:31.0310,Debug,,Having to get media experience by reflection due to bug in Windows 7,1,Application 2018-03-18 21:33:31.0310,Debug,,GetMediaExperienceUsingReflection was unsuccessful,1,Application 2018-03-18 21:33:31.3010,Info,,Sending Http Get to http://192.168.29.194:8096/emby/System/Info/Public?format=Json,1,Application 2018-03-18 21:33:31.3610,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/Public?isDisabled=False&format=Json,1,Application 2018-03-18 21:33:31.5410,Info,,Connected to server THEATERPC at http://192.168.29.194:8096,1,Application 2018-03-18 21:33:31.5410,Info,,Server version: 3.3.1.0,1,Application 2018-03-18 21:33:31.5410,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/MetroLoginPage,1,Application 2018-03-18 21:33:31.5710,Info,,Application Init took 0.90 seconds.,1,Application 2018-03-18 21:33:32.8710,Debug,,Sending Http Post to http://192.168.29.194:8096/emby/Users/19f91e16b77d4fc4a43fedbd78496a6b/Authenticate?format=Json,17,Worker thread for Common 2018-03-18 21:33:33.1110,Info,,Sending Http Get to http://192.168.29.194:8096/emby/System/Configuration?format=Json,17,Worker thread for Common 2018-03-18 21:33:33.2110,Info,,Sending Http Get to http://192.168.29.194:8096/emby/System/Info?format=Json,17,Worker thread for Common 2018-03-18 21:33:33.2710,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Plugins?format=Json,17,Worker thread for Common 2018-03-18 21:33:33.3310,Info,,*** Theme in use is: Chocolate,17,Worker thread for Common 2018-03-18 21:33:33.3310,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Packages?packagetype=UserInstalled&targetsystems=MBClassic&format=Json,17,Worker thread for Common 2018-03-18 21:33:33.3410,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.308.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1,Application 2018-03-18 21:33:33.3410,Info,,Plug-in reference to MediaBrowser,, Version=3.0.308.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.314.0,1,Application 2018-03-18 21:33:33.3410,Debug,,Added Plugin assembly: Chocolate,, Version=3.0.9.0,, Culture=neutral,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2018-03-18 21:33:33.3610,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\Chocolate-strings-en.xml,1,Application 2018-03-18 21:33:33.3910,Info,,Chocolate Theme (version 3.0.9.0) Loaded.,1,Application 2018-03-18 21:33:33.3910,Info,,Plugin Loading and Init took 0.06 seconds.,1,Application 2018-03-18 21:33:33.4010,Debug,,=========System looking for assembly: WebSocket4Net,, Version=0.12.0.0,, Culture=neutral,, PublicKeyToken=eb4e154b696bf72a,1,Application 2018-03-18 21:33:33.4010,Info,,Resolving WebSocket4Net,, Version=0.12.0.0,, Culture=neutral,, PublicKeyToken=eb4e154b696bf72a to C:\ProgramData\MediaBrowser-Classic\websocket4net.dll,1,Application 2018-03-18 21:33:33.4210,Info,,Connected to ws://192.168.29.194:8096/mediabrowser,1,Application 2018-03-18 21:33:33.4410,Debug,,Sending Http Post to http://192.168.29.194:8096/emby/Sessions/Capabilities?format=Json,1,Application 2018-03-18 21:33:33.5180,Debug,,Navigating to My Library item type MediaBrowser.Library.FolderModel,1,Application 2018-03-18 21:33:33.5180,Debug,,Loading display prefs for ,1,Application 2018-03-18 21:33:33.5200,Info,,Sending Http Get to http://192.168.29.194:8096/emby/DisplayPreferences/3f0912cb-11f9-0ea0-1031-b8d6746fa181?userId=19f91e16b77d4fc4a43fedbd78496a6b&client=MBC&format=Json,1,Application 2018-03-18 21:33:33.5910,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16b77d4fc4a43fedbd78496a6b/Views?format=Json,1,Application 2018-03-18 21:33:34.0050,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/Page,1,Application 2018-03-18 21:33:34.0050,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Items/3f0912cb11f90ea01031b8d6746fa181/ThemeMedia?InheritFromParent=False&UserId=19f91e16b77d4fc4a43fedbd78496a6b&format=Json,27,Worker thread for Common 2018-03-18 21:33:34.0550,Error,,Error getting response from http://192.168.29.194:8096/emby/Items/3f0912cb11f90ea01031b8d6746fa181/ThemeMedia?InheritFromParent=False&UserId=19f91e16b77d4fc4a43fedbd78496a6b&format=Json ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (404) Not Found. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),27,Worker thread for Common 2018-03-18 21:33:34.5650,Debug,,=========System looking for assembly: Chocolate,1,Application 2018-03-18 21:33:34.5750,Info,,Resolving plug-in reference to: Chocolate,1,Application 2018-03-18 21:33:34.9650,Debug,,Loading display prefs for ,1,Application 2018-03-18 21:33:35.0250,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Images/General?format=Json,1,Application 2018-03-18 21:33:35.0450,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Localization/ParentalRatings?format=Json,1,Application 2018-03-18 21:33:35.0550,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items?ParentId=9df4efab1f9566a6088195a3f6029855&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&artistIds=&years=&format=Json,22,Worker thread for Common 2018-03-18 21:33:35.0950,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Images/MediaInfo?format=Json,1,Application 2018-03-18 21:33:35.1050,Debug,,Could not find resource 'rated_none' in theme Chocolate,1,Application 2018-03-18 21:33:35.1050,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/rated_none being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:33:35.1250,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16b77d4fc4a43fedbd78496a6b/Items?ParentId=9df4efab1f9566a6088195a3f6029855&limit=20&sortBy=DateCreated&sortOrder=Descending&fields=Overview,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&Filters=&ImageTypes=&recursive=True&genres=&Ids=&studioIds=&ExcludeItemTypes=series,,season,,musicalbum,,musicartist,,folder,,movie,,audio,,episode&IncludeItemTypes=boxset&ExcludeLocationTypes=Virtual&personIds=&personTypes=&artistIds=&years=&format=Json,20,Worker thread for Common 2018-03-18 21:33:35.1550,Info,,RAL child retrieval for Collections option added took 0.04 seconds.,20,Worker thread for Common 2018-03-18 21:33:35.1550,Debug,,added list for Collections loaded with 0 items.,20,Worker thread for Common 2018-03-18 21:33:35.1750,Info,,Information DisplayText: Welcome to Emby for WMC,1,Application 2018-03-18 21:33:36.9450,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16b77d4fc4a43fedbd78496a6b/Items?ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805&sortBy=&fields=Overview,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&Filters=&ImageTypes=&recursive=True&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=Movie&ExcludeLocationTypes=&personIds=&personTypes=&artistIds=&years=&format=Json,21,Worker thread for Common 2018-03-18 21:33:37.4750,Info,,Sending Http Get to http://192.168.29.194:8096/emby/DisplayPreferences/f137a2dd21bbc1b99aa5c0f6bf02a805?userId=19f91e16b77d4fc4a43fedbd78496a6b&client=MBC&format=Json,27,Worker thread for Common 2018-03-18 21:33:37.4950,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16b77d4fc4a43fedbd78496a6b/Items?ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805&limit=20&sortBy=DateCreated&sortOrder=Descending&fields=Overview,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&Filters=&ImageTypes=&recursive=True&genres=&Ids=&studioIds=&ExcludeItemTypes=series,,season,,musicalbum,,musicartist,,folder,,boxset&IncludeItemTypes=movie&ExcludeLocationTypes=Virtual&personIds=&personTypes=&artistIds=&years=&format=Json,21,Worker thread for Common 2018-03-18 21:33:37.5550,Info,,RAL child retrieval for Movies option added took 0.06 seconds.,21,Worker thread for Common 2018-03-18 21:33:37.5550,Debug,,added list for Movies loaded with 20 items.,21,Worker thread for Common 2018-03-18 21:33:37.5550,Info,,Sending Http Get to http://192.168.29.194:8096/emby/DisplayPreferences/3940a914-d772-f9de-cc32-64f4ddd41ec5?userId=19f91e16b77d4fc4a43fedbd78496a6b&client=MBC&format=Json,21,Worker thread for Common 2018-03-18 21:33:39.5250,Debug,,Navigating to Movies item type MediaBrowser.Library.FolderModel,1,Application 2018-03-18 21:33:39.5250,Debug,,Loading display prefs for C:\Users\DenComputer\AppData\Roaming\Emby-Server\programdata\root\default\Movies,1,Application 2018-03-18 21:33:39.5350,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/Page,1,Application 2018-03-18 21:33:39.5350,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/ThemeMedia?InheritFromParent=False&UserId=19f91e16b77d4fc4a43fedbd78496a6b&format=Json,27,Worker thread for Common 2018-03-18 21:33:39.5550,Debug,,Loading display prefs for C:\Users\DenComputer\AppData\Roaming\Emby-Server\programdata\root\default\Movies,1,Application 2018-03-18 21:33:40.0050,Debug,,Could not find resource 'rated_r' in theme Chocolate,1,Application 2018-03-18 21:33:40.0050,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/rated_r being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:33:40.2970,Debug,,Could not find resource 'codec_h262' in theme Chocolate,1,Application 2018-03-18 21:33:40.2970,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/codec_h262 being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:33:40.2970,Debug,,Could not find resource 'codec_ac3' in theme Chocolate,1,Application 2018-03-18 21:33:40.2970,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/codec_ac3 being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:33:40.3070,Debug,,Could not find resource 'channels_6' in theme Chocolate,1,Application 2018-03-18 21:33:40.3070,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/channels_6 being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:33:40.3070,Debug,,Could not find resource 'aspect_150' in theme Chocolate,1,Application 2018-03-18 21:33:40.3070,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/aspect_150 being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:33:40.3170,Debug,,Could not find resource 'media_mkv' in theme Chocolate,1,Application 2018-03-18 21:33:40.3170,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/media_mkv being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:33:42.2090,Debug,,Could not find resource 'codec_h264' in theme Chocolate,1,Application 2018-03-18 21:33:42.2090,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/codec_h264 being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:33:42.2090,Debug,,Could not find resource 'channels_2' in theme Chocolate,1,Application 2018-03-18 21:33:42.2090,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/channels_2 being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:33:42.2190,Debug,,Could not find resource 'aspect_177' in theme Chocolate,1,Application 2018-03-18 21:33:42.2190,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/aspect_177 being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:33:42.7790,Debug,,Could not find resource 'hdtype_720' in theme Chocolate,1,Application 2018-03-18 21:33:42.7790,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/hdtype_720 being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:33:43.2590,Debug,,Could not find resource 'hdtype_1080' in theme Chocolate,1,Application 2018-03-18 21:33:43.2590,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/hdtype_1080 being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:33:43.2590,Debug,,Could not find resource 'media_wtv' in theme Chocolate,1,Application 2018-03-18 21:33:43.2590,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/media_wtv being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:33:43.3290,Debug,,Could not find resource 'rated_g' in theme Chocolate,1,Application 2018-03-18 21:33:43.3290,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/rated_g being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:33:43.3390,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Plugins/RegistrationRecords/mbsupporter?Mb2Equivalent=mbsupporter&format=Json,21,Worker thread for Common 2018-03-18 21:33:43.5510,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Packages/MBClassic?format=Json,26,Worker thread for Common 2018-03-18 21:33:43.6910,Debug,,Could not find resource 'rated_pg_13' in theme Chocolate,1,Application 2018-03-18 21:33:43.6910,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/rated_pg_13 being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:33:44.3930,Info,,==== Emby for WMC is up to date.,26,Worker thread for Common 2018-03-18 21:33:45.1930,Debug,,Could not find resource 'codec_dts_ds' in theme Chocolate,1,Application 2018-03-18 21:33:45.1930,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/codec_dts_ds being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:33:45.5730,Debug,,Could not find resource 'channels_8' in theme Chocolate,1,Application 2018-03-18 21:33:45.5730,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/channels_8 being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:33:46.7050,Debug,,Navigating to The Avengers item type MediaBrowser.Library.Item,1,Application 2018-03-18 21:33:46.7050,Debug,,Loading full details for The Avengers,1,Application 2018-03-18 21:33:46.7050,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items/f77cd9a6-0e3e-a0a7-70a8-9926ebccd48b?format=Json,1,Application 2018-03-18 21:33:46.8150,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/MovieDetailsPage,1,Application 2018-03-18 21:33:46.8150,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Items/f77cd9a60e3ea0a770a89926ebccd48b/ThemeMedia?InheritFromParent=False&UserId=19f91e16b77d4fc4a43fedbd78496a6b&format=Json,19,Worker thread for Common 2018-03-18 21:33:47.1450,Debug,,Having to get media experience by reflection due to bug in Windows 7,1,Application 2018-03-18 21:33:47.1450,Debug,,GetMediaExperienceUsingReflection was unsuccessful,1,Application 2018-03-18 21:33:50.3850,Debug,,Setting now playing status to True,1,Application 2018-03-18 21:33:50.4650,Info,,Information DisplayText: Emby for WMC is up to date,1,Application 2018-03-18 21:33:50.8050,Debug,,Environment property changed - hooking transport,1,Application 2018-03-18 21:33:53.8050,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items/f77cd9a60e3ea0a770a89926ebccd48b/Intros?format=Json,1,Application 2018-03-18 21:33:54.4650,Info,,Playing 2 Intros before The Avengers,1,Application 2018-03-18 21:33:54.5550,Debug,,Setting now playing status to False,1,Application 2018-03-18 21:33:54.5650,Debug,,Theme background stopped - unhooking,1,Application 2018-03-18 21:33:54.6350,Info,,Internal Player about to play (http://192.168.29.194:8096/emby/videos/d73bdc6968bb7387f6447ddaf05ffe2c/stream.asf?DeviceId=5f7736fd120448379ff50419ba4588c5&MediaSourceId=866edee537f593d9b4e003d1355710f7&VideoCodec=msmpeg4&AudioCodec=wmav2&AudioStreamIndex=-1&VideoBitrate=29872000&AudioBitrate=128000&MaxAudioChannels=2&api_key=222221129f814887b5a653336ac4e74b&CopyTimestamps=false&ForceLiveStream=false) ,1,Application 2018-03-18 21:33:54.6350,Info,,Internal Player playing ,1,Application 2018-03-18 21:33:54.6450,Debug,,Calling MediaCenterEnvironment.PlayMedia: Microsoft.MediaCenter.MediaCollection,1,Application 2018-03-18 21:33:54.6950,Error,,Error playing item: ( Exception. Type=System.ArgumentException Msg=Registry subkeys should not be greater than 255 characters. Src=mscorlib Method=HandleReturnMessage Line=0 Col=0 [n] StackTrace= [n] [n] Server stack trace: [n] at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource) [n] at Microsoft.Win32.RegistryKey.ValidateKeyName(String name) [n] at Microsoft.Win32.RegistryKey.OpenSubKey(String name,, Boolean writable) [n] at Microsoft.Win32.RegistryKey.OpenSubKey(String name) [n] at ServiceBus.UIFramework.EhFileInfo.GetPerceivedType(String path) [n] at Microsoft.MediaCenter.Playback.MediaCollectionEntryBuilder.Build(MediaCollectionItem mediaCollectionItem) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItem.Initialize(MediaCollection mediaCollection) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItem..ctor(MediaCollection mediaCollection) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItemBuilder.Build(MediaCollection mediaCollection) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean fAddToQueue) [n] at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target,, Boolean fExecuteInContext) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg,, Int32 methodPtr,, Boolean fExecuteInContext) [n] [n] Exception rethrown at [0]: [n] at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg,, IMessage retMsg) [n] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData,, Int32 type) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean fAddToQueue) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md,, Object[] args,, Object server,, Int32 methodPtr,, Boolean fExecuteInContext,, Object[]& outArgs) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.PrivateProcessMessage(RuntimeMethodHandle md,, Object[] args,, Object server,, Int32 methodPtr,, Boolean fExecuteInContext,, Object[]& outArgs) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg,, Int32 methodPtr,, Boolean fExecuteInContext) [n] [n] Exception rethrown at [1]: [n] at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg,, IMessage retMsg) [n] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData,, Int32 type) [n] at Microsoft.MediaCenter.AddIn.HostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean addToQueue) [n] at Microsoft.MediaCenter.MediaCenterEnvironment.PlayMedia(MediaType mediaType,, Object media,, Boolean addToQueue) [n] at MediaBrowser.Library.Playables.PlaybackControllerHelper.CallPlayMedia(MediaCenterEnvironment mediaCenterEnvironment,, MediaType type,, Object media,, Boolean queue) [n] at MediaBrowser.PlaybackController.CallPlayMediaUsingMediaCollection(MediaCenterEnvironment mediaCenterEnvironment,, PlayableItem playable) [n] at MediaBrowser.PlaybackController.CallPlayMediaForPlayableItem(MediaCenterEnvironment mediaCenterEnvironment,, PlayableItem playable) [n] at MediaBrowser.PlaybackController.PlayPlayableItem(PlayableItem playable) ),1,Application 2018-03-18 21:33:58.1950,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items/f77cd9a60e3ea0a770a89926ebccd48b/Intros?format=Json,1,Application 2018-03-18 21:33:58.2550,Info,,Playing 2 Intros before The Avengers,1,Application 2018-03-18 21:33:58.2550,Info,,Internal Player about to play (http://192.168.29.194:8096/emby/videos/69fd7c4ea244aaf4eb0168a5b45be6bf/stream.asf?DeviceId=5f7736fd120448379ff50419ba4588c5&MediaSourceId=0b2d00263057c6c82e95df8b6210b4e6&VideoCodec=msmpeg4&AudioCodec=wmav2&AudioStreamIndex=-1&VideoBitrate=29872000&AudioBitrate=128000&MaxAudioChannels=2&api_key=222221129f814887b5a653336ac4e74b&CopyTimestamps=false&ForceLiveStream=false) ,1,Application 2018-03-18 21:33:58.2550,Info,,Internal Player playing ,1,Application 2018-03-18 21:33:58.2550,Debug,,Calling MediaCenterEnvironment.PlayMedia: Microsoft.MediaCenter.MediaCollection,1,Application 2018-03-18 21:33:58.2650,Error,,Error playing item: ( Exception. Type=System.ArgumentException Msg=Registry subkeys should not be greater than 255 characters. Src=mscorlib Method=HandleReturnMessage Line=0 Col=0 [n] StackTrace= [n] [n] Server stack trace: [n] at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource) [n] at Microsoft.Win32.RegistryKey.ValidateKeyName(String name) [n] at Microsoft.Win32.RegistryKey.OpenSubKey(String name,, Boolean writable) [n] at Microsoft.Win32.RegistryKey.OpenSubKey(String name) [n] at ServiceBus.UIFramework.EhFileInfo.GetPerceivedType(String path) [n] at Microsoft.MediaCenter.Playback.MediaCollectionEntryBuilder.Build(MediaCollectionItem mediaCollectionItem) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItem.Initialize(MediaCollection mediaCollection) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItem..ctor(MediaCollection mediaCollection) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItemBuilder.Build(MediaCollection mediaCollection) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean fAddToQueue) [n] at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target,, Boolean fExecuteInContext) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg,, Int32 methodPtr,, Boolean fExecuteInContext) [n] [n] Exception rethrown at [0]: [n] at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg,, IMessage retMsg) [n] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData,, Int32 type) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean fAddToQueue) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md,, Object[] args,, Object server,, Int32 methodPtr,, Boolean fExecuteInContext,, Object[]& outArgs) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.PrivateProcessMessage(RuntimeMethodHandle md,, Object[] args,, Object server,, Int32 methodPtr,, Boolean fExecuteInContext,, Object[]& outArgs) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg,, Int32 methodPtr,, Boolean fExecuteInContext) [n] [n] Exception rethrown at [1]: [n] at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg,, IMessage retMsg) [n] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData,, Int32 type) [n] at Microsoft.MediaCenter.AddIn.HostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean addToQueue) [n] at Microsoft.MediaCenter.MediaCenterEnvironment.PlayMedia(MediaType mediaType,, Object media,, Boolean addToQueue) [n] at MediaBrowser.Library.Playables.PlaybackControllerHelper.CallPlayMedia(MediaCenterEnvironment mediaCenterEnvironment,, MediaType type,, Object media,, Boolean queue) [n] at MediaBrowser.PlaybackController.CallPlayMediaUsingMediaCollection(MediaCenterEnvironment mediaCenterEnvironment,, PlayableItem playable) [n] at MediaBrowser.PlaybackController.CallPlayMediaForPlayableItem(MediaCenterEnvironment mediaCenterEnvironment,, PlayableItem playable) [n] at MediaBrowser.PlaybackController.PlayPlayableItem(PlayableItem playable) ),1,Application 2018-03-18 21:34:01.6450,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items/f77cd9a60e3ea0a770a89926ebccd48b/Intros?format=Json,1,Application 2018-03-18 21:34:01.6850,Info,,Playing 2 Intros before The Avengers,1,Application 2018-03-18 21:34:01.6950,Info,,Internal Player about to play (http://192.168.29.194:8096/emby/videos/d73bdc6968bb7387f6447ddaf05ffe2c/stream.asf?DeviceId=5f7736fd120448379ff50419ba4588c5&MediaSourceId=866edee537f593d9b4e003d1355710f7&VideoCodec=msmpeg4&AudioCodec=wmav2&AudioStreamIndex=-1&VideoBitrate=29872000&AudioBitrate=128000&MaxAudioChannels=2&api_key=222221129f814887b5a653336ac4e74b&CopyTimestamps=false&ForceLiveStream=false) ,1,Application 2018-03-18 21:34:01.6950,Info,,Internal Player playing ,1,Application 2018-03-18 21:34:01.6950,Debug,,Calling MediaCenterEnvironment.PlayMedia: Microsoft.MediaCenter.MediaCollection,1,Application 2018-03-18 21:34:01.7050,Error,,Error playing item: ( Exception. Type=System.ArgumentException Msg=Registry subkeys should not be greater than 255 characters. Src=mscorlib Method=HandleReturnMessage Line=0 Col=0 [n] StackTrace= [n] [n] Server stack trace: [n] at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource) [n] at Microsoft.Win32.RegistryKey.ValidateKeyName(String name) [n] at Microsoft.Win32.RegistryKey.OpenSubKey(String name,, Boolean writable) [n] at Microsoft.Win32.RegistryKey.OpenSubKey(String name) [n] at ServiceBus.UIFramework.EhFileInfo.GetPerceivedType(String path) [n] at Microsoft.MediaCenter.Playback.MediaCollectionEntryBuilder.Build(MediaCollectionItem mediaCollectionItem) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItem.Initialize(MediaCollection mediaCollection) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItem..ctor(MediaCollection mediaCollection) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItemBuilder.Build(MediaCollection mediaCollection) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean fAddToQueue) [n] at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target,, Boolean fExecuteInContext) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg,, Int32 methodPtr,, Boolean fExecuteInContext) [n] [n] Exception rethrown at [0]: [n] at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg,, IMessage retMsg) [n] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData,, Int32 type) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean fAddToQueue) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md,, Object[] args,, Object server,, Int32 methodPtr,, Boolean fExecuteInContext,, Object[]& outArgs) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.PrivateProcessMessage(RuntimeMethodHandle md,, Object[] args,, Object server,, Int32 methodPtr,, Boolean fExecuteInContext,, Object[]& outArgs) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg,, Int32 methodPtr,, Boolean fExecuteInContext) [n] [n] Exception rethrown at [1]: [n] at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg,, IMessage retMsg) [n] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData,, Int32 type) [n] at Microsoft.MediaCenter.AddIn.HostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean addToQueue) [n] at Microsoft.MediaCenter.MediaCenterEnvironment.PlayMedia(MediaType mediaType,, Object media,, Boolean addToQueue) [n] at MediaBrowser.Library.Playables.PlaybackControllerHelper.CallPlayMedia(MediaCenterEnvironment mediaCenterEnvironment,, MediaType type,, Object media,, Boolean queue) [n] at MediaBrowser.PlaybackController.CallPlayMediaUsingMediaCollection(MediaCenterEnvironment mediaCenterEnvironment,, PlayableItem playable) [n] at MediaBrowser.PlaybackController.CallPlayMediaForPlayableItem(MediaCenterEnvironment mediaCenterEnvironment,, PlayableItem playable) [n] at MediaBrowser.PlaybackController.PlayPlayableItem(PlayableItem playable) ),1,Application 2018-03-18 21:34:04.4570,Debug,,Could not find resource 'rated_pg' in theme Chocolate,1,Application 2018-03-18 21:34:04.4570,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/rated_pg being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:34:07.2010,Debug,,Navigating to Back to the Future item type MediaBrowser.Library.Item,1,Application 2018-03-18 21:34:07.2010,Debug,,Loading full details for Back to the Future,1,Application 2018-03-18 21:34:07.2010,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items/536666f8-6ce6-7745-bd70-b22863b1a8d5?format=Json,1,Application 2018-03-18 21:34:07.2310,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/MovieDetailsPage,1,Application 2018-03-18 21:34:07.2310,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Items/536666f86ce67745bd70b22863b1a8d5/ThemeMedia?InheritFromParent=False&UserId=19f91e16b77d4fc4a43fedbd78496a6b&format=Json,20,Worker thread for Common 2018-03-18 21:34:07.5710,Debug,,Setting now playing status to True,1,Application 2018-03-18 21:34:07.5810,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2018-03-18 21:34:07.6210,Debug,,Environment property changed - hooking transport,1,Application 2018-03-18 21:34:07.6210,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2018-03-18 21:34:07.8910,Debug,,HandlePropertyChange has recognized that playback has started,1,Application 2018-03-18 21:34:07.8910,Debug,,Sending Http Post to http://192.168.29.194:8096/emby/Sessions/Playing?CanSeek=False&IsPaused=False&IsMuted=False&ItemId=d73bdc6968bb7387f6447ddaf05ffe2c&QueueableMediaTypes=Audio&PlayMethod=Transcode&format=Json,1,Application 2018-03-18 21:34:08.0210,Debug,,Playstate changed to Playing for file://homeserver/Movies/Back to the Future/backdrops/theme.mp4,, PositionTicks:0,, Playlist Index:0,1,Application 2018-03-18 21:34:08.0210,Debug,,Back from PlayStateChanged,1,Application 2018-03-18 21:34:08.0410,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2018-03-18 21:34:08.0710,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2018-03-18 21:34:08.1310,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items/d73bdc69-68bb-7387-f644-7ddaf05ffe2c?format=Json,1,Application 2018-03-18 21:34:08.5710,Info,,Received web socket message: UserDataChanged,10, 2018-03-18 21:34:09.4010,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2018-03-18 21:34:09.7410,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items/536666f86ce67745bd70b22863b1a8d5/Intros?format=Json,1,Application 2018-03-18 21:34:09.7710,Info,,Playing 2 Intros before Back to the Future,1,Application 2018-03-18 21:34:09.8311,Debug,,Setting now playing status to False,1,Application 2018-03-18 21:34:09.8311,Debug,,Theme background stopped - unhooking,1,Application 2018-03-18 21:34:09.8411,Debug,,Setting now playing status to True,1,Application 2018-03-18 21:34:09.8411,Debug,,Playstate changed to Undefined for file://homeserver/Movies/Back to the Future/backdrops/theme.mp4,, PositionTicks:0,, Playlist Index:0,1,Application 2018-03-18 21:34:09.8411,Debug,,Back from PlayStateChanged,1,Application 2018-03-18 21:34:09.8411,Debug,,Calling HandleStopedState,1,Application 2018-03-18 21:34:09.8511,Debug,,In HandleStoppedState,1,Application 2018-03-18 21:34:09.8511,Debug,,Events unhooked,1,Application 2018-03-18 21:34:09.8511,Debug,,Turning off NPV,1,Application 2018-03-18 21:34:09.8511,Debug,,Setting now playing status to False,1,Application 2018-03-18 21:34:09.8511,Info,,Internal Player about to play (http://192.168.29.194:8096/emby/videos/eaf0d8cd4dea49a786e20ee42ccfd92a/stream.asf?DeviceId=5f7736fd120448379ff50419ba4588c5&MediaSourceId=22523e44ca2c2896e754c31e39b2878b&VideoCodec=msmpeg4&AudioCodec=wmav2&AudioStreamIndex=-1&VideoBitrate=29872000&AudioBitrate=128000&MaxAudioChannels=2&api_key=222221129f814887b5a653336ac4e74b&CopyTimestamps=false&ForceLiveStream=false) ,1,Application 2018-03-18 21:34:09.8511,Info,,Internal Player playing ,1,Application 2018-03-18 21:34:09.8511,Debug,,Calling MediaCenterEnvironment.PlayMedia: Microsoft.MediaCenter.MediaCollection,1,Application 2018-03-18 21:34:09.8511,Debug,,Internal Player playback finished,19,Worker thread for Common 2018-03-18 21:34:09.8511,Debug,,Firing Application.PlaybackFinished for: ,19,Worker thread for Common 2018-03-18 21:34:09.8511,Debug,,Updating Resume status...,19,Worker thread for Common 2018-03-18 21:34:09.8511,Debug,,Creating a new instance of MpcHcPlaybackController,20,Worker thread for Common 2018-03-18 21:34:09.8511,Debug,,All post-playback actions have completed.,19,Worker thread for Common 2018-03-18 21:34:09.8611,Error,,Error playing item: ( Exception. Type=System.ArgumentException Msg=Registry subkeys should not be greater than 255 characters. Src=mscorlib Method=HandleReturnMessage Line=0 Col=0 [n] StackTrace= [n] [n] Server stack trace: [n] at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource) [n] at Microsoft.Win32.RegistryKey.ValidateKeyName(String name) [n] at Microsoft.Win32.RegistryKey.OpenSubKey(String name,, Boolean writable) [n] at Microsoft.Win32.RegistryKey.OpenSubKey(String name) [n] at ServiceBus.UIFramework.EhFileInfo.GetPerceivedType(String path) [n] at Microsoft.MediaCenter.Playback.MediaCollectionEntryBuilder.Build(MediaCollectionItem mediaCollectionItem) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItem.Initialize(MediaCollection mediaCollection) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItem..ctor(MediaCollection mediaCollection) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItemBuilder.Build(MediaCollection mediaCollection) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean fAddToQueue) [n] at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target,, Boolean fExecuteInContext) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg,, Int32 methodPtr,, Boolean fExecuteInContext) [n] [n] Exception rethrown at [0]: [n] at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg,, IMessage retMsg) [n] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData,, Int32 type) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean fAddToQueue) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md,, Object[] args,, Object server,, Int32 methodPtr,, Boolean fExecuteInContext,, Object[]& outArgs) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.PrivateProcessMessage(RuntimeMethodHandle md,, Object[] args,, Object server,, Int32 methodPtr,, Boolean fExecuteInContext,, Object[]& outArgs) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg,, Int32 methodPtr,, Boolean fExecuteInContext) [n] [n] Exception rethrown at [1]: [n] at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg,, IMessage retMsg) [n] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData,, Int32 type) [n] at Microsoft.MediaCenter.AddIn.HostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean addToQueue) [n] at Microsoft.MediaCenter.MediaCenterEnvironment.PlayMedia(MediaType mediaType,, Object media,, Boolean addToQueue) [n] at MediaBrowser.Library.Playables.PlaybackControllerHelper.CallPlayMedia(MediaCenterEnvironment mediaCenterEnvironment,, MediaType type,, Object media,, Boolean queue) [n] at MediaBrowser.PlaybackController.CallPlayMediaUsingMediaCollection(MediaCenterEnvironment mediaCenterEnvironment,, PlayableItem playable) [n] at MediaBrowser.PlaybackController.CallPlayMediaForPlayableItem(MediaCenterEnvironment mediaCenterEnvironment,, PlayableItem playable) [n] at MediaBrowser.PlaybackController.PlayPlayableItem(PlayableItem playable) ),1,Application 2018-03-18 21:34:09.8611,Info,,MPC-HC about to play Back to the Future(\\HOMESERVER\Movies\Back to the Future\Back to the Future.mkv) ,1,Application 2018-03-18 21:34:09.8711,Info,,MPC-HC playing Back to the Future,1,Application 2018-03-18 21:34:09.8711,Debug,,Sending Http Post to http://192.168.29.194:8096/emby/Sessions/Playing?CanSeek=True&IsPaused=False&IsMuted=False&ItemId=536666f86ce67745bd70b22863b1a8d5&QueueableMediaTypes=Audio&PlayMethod=DirectPlay&format=Json,1,Application 2018-03-18 21:34:09.8811,Info,,Starting command line C:\Program Files\MPC-HC\mpc-hc.exe "\\HOMESERVER\Movies\Back to the Future\Back to the Future.mkv" /play /close /fullscreen /start 0,1,Application 2018-03-18 21:34:09.9411,Debug,,Minimizing Windows Media Center,17,Worker thread for Common 2018-03-18 21:34:10.2011,Debug,,Creating new web client for MPC-HC,35,Worker thread for WaitForExternalPlayerToLaunch 2018-03-18 21:34:10.4111,Info,,Received web socket message: UserDataChanged,10, 2018-03-18 21:34:24.8410,Debug,,MPC-HC playback finished,17,Worker thread for Common 2018-03-18 21:34:24.8510,Debug,,Reporting stopped to server for Back to the Future,17,Worker thread for Common 2018-03-18 21:34:24.8510,Debug,,Sending Http Post to http://192.168.29.194:8096/emby/Sessions/Playing/Stopped?positionTicks=0&ItemId=536666f86ce67745bd70b22863b1a8d5&format=Json,17,Worker thread for Common 2018-03-18 21:34:24.8910,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items/536666f8-6ce6-7745-bd70-b22863b1a8d5?format=Json,17,Worker thread for Common 2018-03-18 21:34:24.9210,Debug,,Setting new status on Back to the Future with parent of Movies,17,Worker thread for Common 2018-03-18 21:34:24.9210,Debug,,Firing Application.PlaybackFinished for: Back to the Future,17,Worker thread for Common 2018-03-18 21:34:24.9210,Debug,,Updating Resume status...,17,Worker thread for Common 2018-03-18 21:34:24.9210,Debug,,All post-playback actions have completed.,17,Worker thread for Common 2018-03-18 21:34:25.3810,Info,,Received web socket message: UserDataChanged,34, 2018-03-18 21:34:31.0231,Debug,,Keep alive call,, IsCurretntlyVisible=True,1,Application 2018-03-18 21:34:39.3831,Debug,,Could not find resource 'codec_vc1' in theme Chocolate,1,Application 2018-03-18 21:34:39.3831,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/codec_vc1 being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:34:41.5551,Debug,,Navigating to Despicable Me item type MediaBrowser.Library.Item,1,Application 2018-03-18 21:34:41.5551,Debug,,Loading full details for Despicable Me,1,Application 2018-03-18 21:34:41.5551,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items/e95aa51a-08e4-006a-3074-e3ab28f09715?format=Json,1,Application 2018-03-18 21:34:41.5951,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/MovieDetailsPage,1,Application 2018-03-18 21:34:41.5951,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Items/e95aa51a08e4006a3074e3ab28f09715/ThemeMedia?InheritFromParent=False&UserId=19f91e16b77d4fc4a43fedbd78496a6b&format=Json,21,Worker thread for Common 2018-03-18 21:34:42.4151,Debug,,Setting now playing status to True,1,Application 2018-03-18 21:34:42.4251,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2018-03-18 21:34:42.4451,Debug,,Environment property changed - hooking transport,1,Application 2018-03-18 21:34:42.4451,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2018-03-18 21:34:42.6951,Debug,,HandlePropertyChange has recognized that playback has started,1,Application 2018-03-18 21:34:42.6951,Debug,,Sending Http Post to http://192.168.29.194:8096/emby/Sessions/Playing?CanSeek=True&IsPaused=False&IsMuted=False&ItemId=eaf0d8cd4dea49a786e20ee42ccfd92a&QueueableMediaTypes=Audio&PlayMethod=Transcode&format=Json,1,Application 2018-03-18 21:34:42.7351,Debug,,Playstate changed to Playing for file://homeserver/Movies/Despicable Me/Backdrops/theme.mp4,, PositionTicks:0,, Playlist Index:-1,1,Application 2018-03-18 21:34:42.7351,Debug,,Back from PlayStateChanged,1,Application 2018-03-18 21:34:42.7651,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2018-03-18 21:34:42.7851,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2018-03-18 21:34:42.8151,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items/eaf0d8cd-4dea-49a7-86e2-0ee42ccfd92a?format=Json,1,Application 2018-03-18 21:34:43.2051,Info,,Received web socket message: UserDataChanged,10, 2018-03-18 21:34:44.2151,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2018-03-18 21:34:44.7051,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items/e95aa51a08e4006a3074e3ab28f09715/Intros?format=Json,1,Application 2018-03-18 21:34:44.7251,Info,,Playing 2 Intros before Despicable Me,1,Application 2018-03-18 21:34:44.7851,Debug,,Setting now playing status to False,1,Application 2018-03-18 21:34:44.7851,Debug,,Theme background stopped - unhooking,1,Application 2018-03-18 21:34:44.8051,Debug,,Setting now playing status to True,1,Application 2018-03-18 21:34:44.8051,Debug,,Playstate changed to Undefined for file://homeserver/Movies/Despicable Me/Backdrops/theme.mp4,, PositionTicks:0,, Playlist Index:-1,1,Application 2018-03-18 21:34:44.8051,Debug,,Back from PlayStateChanged,1,Application 2018-03-18 21:34:44.8051,Debug,,Calling HandleStopedState,1,Application 2018-03-18 21:34:44.8051,Debug,,In HandleStoppedState,1,Application 2018-03-18 21:34:44.8051,Debug,,Events unhooked,1,Application 2018-03-18 21:34:44.8051,Debug,,Turning off NPV,1,Application 2018-03-18 21:34:44.8051,Debug,,Setting now playing status to False,1,Application 2018-03-18 21:34:44.8051,Debug,,Internal Player playback finished,25,Worker thread for Common 2018-03-18 21:34:44.8051,Debug,,Updating Resume status...,25,Worker thread for Common 2018-03-18 21:34:44.8051,Info,,Internal Player about to play (http://192.168.29.194:8096/emby/videos/eaf0d8cd4dea49a786e20ee42ccfd92a/stream.asf?DeviceId=5f7736fd120448379ff50419ba4588c5&MediaSourceId=22523e44ca2c2896e754c31e39b2878b&VideoCodec=msmpeg4&AudioCodec=wmav2&AudioStreamIndex=-1&VideoBitrate=29872000&AudioBitrate=128000&MaxAudioChannels=2&api_key=222221129f814887b5a653336ac4e74b&CopyTimestamps=false&ForceLiveStream=false) ,1,Application 2018-03-18 21:34:44.8051,Debug,,All post-playback actions have completed.,25,Worker thread for Common 2018-03-18 21:34:44.8051,Info,,Internal Player playing ,1,Application 2018-03-18 21:34:44.8051,Debug,,Calling MediaCenterEnvironment.PlayMedia: Microsoft.MediaCenter.MediaCollection,1,Application 2018-03-18 21:34:44.8151,Error,,Error playing item: ( Exception. Type=System.ArgumentException Msg=Registry subkeys should not be greater than 255 characters. Src=mscorlib Method=HandleReturnMessage Line=0 Col=0 [n] StackTrace= [n] [n] Server stack trace: [n] at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource) [n] at Microsoft.Win32.RegistryKey.ValidateKeyName(String name) [n] at Microsoft.Win32.RegistryKey.OpenSubKey(String name,, Boolean writable) [n] at Microsoft.Win32.RegistryKey.OpenSubKey(String name) [n] at ServiceBus.UIFramework.EhFileInfo.GetPerceivedType(String path) [n] at Microsoft.MediaCenter.Playback.MediaCollectionEntryBuilder.Build(MediaCollectionItem mediaCollectionItem) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItem.Initialize(MediaCollection mediaCollection) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItem..ctor(MediaCollection mediaCollection) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItemBuilder.Build(MediaCollection mediaCollection) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean fAddToQueue) [n] at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target,, Boolean fExecuteInContext) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg,, Int32 methodPtr,, Boolean fExecuteInContext) [n] [n] Exception rethrown at [0]: [n] at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg,, IMessage retMsg) [n] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData,, Int32 type) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean fAddToQueue) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md,, Object[] args,, Object server,, Int32 methodPtr,, Boolean fExecuteInContext,, Object[]& outArgs) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.PrivateProcessMessage(RuntimeMethodHandle md,, Object[] args,, Object server,, Int32 methodPtr,, Boolean fExecuteInContext,, Object[]& outArgs) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg,, Int32 methodPtr,, Boolean fExecuteInContext) [n] [n] Exception rethrown at [1]: [n] at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg,, IMessage retMsg) [n] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData,, Int32 type) [n] at Microsoft.MediaCenter.AddIn.HostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean addToQueue) [n] at Microsoft.MediaCenter.MediaCenterEnvironment.PlayMedia(MediaType mediaType,, Object media,, Boolean addToQueue) [n] at MediaBrowser.Library.Playables.PlaybackControllerHelper.CallPlayMedia(MediaCenterEnvironment mediaCenterEnvironment,, MediaType type,, Object media,, Boolean queue) [n] at MediaBrowser.PlaybackController.CallPlayMediaUsingMediaCollection(MediaCenterEnvironment mediaCenterEnvironment,, PlayableItem playable) [n] at MediaBrowser.PlaybackController.CallPlayMediaForPlayableItem(MediaCenterEnvironment mediaCenterEnvironment,, PlayableItem playable) [n] at MediaBrowser.PlaybackController.PlayPlayableItem(PlayableItem playable) ),1,Application 2018-03-18 21:34:44.8251,Info,,MPC-HC about to play Despicable Me(\\HOMESERVER\Movies\Despicable Me\MoviesDespicable Me - 2010.wtv) ,1,Application 2018-03-18 21:34:44.8251,Info,,MPC-HC playing Despicable Me,1,Application 2018-03-18 21:34:44.8251,Debug,,Sending Http Post to http://192.168.29.194:8096/emby/Sessions/Playing?CanSeek=True&IsPaused=False&IsMuted=False&ItemId=e95aa51a08e4006a3074e3ab28f09715&QueueableMediaTypes=Audio&PlayMethod=DirectPlay&format=Json,1,Application 2018-03-18 21:34:44.8351,Info,,Starting command line C:\Program Files\MPC-HC\mpc-hc.exe "\\HOMESERVER\Movies\Despicable Me\MoviesDespicable Me - 2010.wtv" /play /close /fullscreen /start 0,1,Application 2018-03-18 21:34:44.8451,Debug,,Minimizing Windows Media Center,21,Worker thread for Common 2018-03-18 21:34:45.3351,Info,,Received web socket message: UserDataChanged,10, 2018-03-18 21:34:55.3897,Debug,,MPC-HC playback finished,21,Worker thread for Common 2018-03-18 21:34:55.3897,Debug,,Reporting stopped to server for Despicable Me,21,Worker thread for Common 2018-03-18 21:34:55.3897,Debug,,Sending Http Post to http://192.168.29.194:8096/emby/Sessions/Playing/Stopped?positionTicks=0&ItemId=e95aa51a08e4006a3074e3ab28f09715&format=Json,21,Worker thread for Common 2018-03-18 21:34:55.3897,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items/e95aa51a-08e4-006a-3074-e3ab28f09715?format=Json,21,Worker thread for Common 2018-03-18 21:34:55.4097,Debug,,Setting new status on Despicable Me with parent of Movies,21,Worker thread for Common 2018-03-18 21:34:55.4097,Debug,,Firing Application.PlaybackFinished for: Despicable Me,21,Worker thread for Common 2018-03-18 21:34:55.4097,Debug,,Updating Resume status...,21,Worker thread for Common 2018-03-18 21:34:55.4097,Debug,,All post-playback actions have completed.,21,Worker thread for Common 2018-03-18 21:34:55.8997,Info,,Received web socket message: UserDataChanged,5, 2018-03-18 21:35:01.1217,Debug,,Navigating to The Dark Knight item type MediaBrowser.Library.Item,1,Application 2018-03-18 21:35:01.1217,Debug,,Loading full details for The Dark Knight,1,Application 2018-03-18 21:35:01.1217,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items/277f2dba-9a45-1808-35bd-ad49e1695d7e?format=Json,1,Application 2018-03-18 21:35:01.1917,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/MovieDetailsPage,1,Application 2018-03-18 21:35:01.1917,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Items/277f2dba9a45180835bdad49e1695d7e/ThemeMedia?InheritFromParent=False&UserId=19f91e16b77d4fc4a43fedbd78496a6b&format=Json,21,Worker thread for Common 2018-03-18 21:35:01.8017,Debug,,Setting now playing status to True,1,Application 2018-03-18 21:35:01.8117,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2018-03-18 21:35:01.8317,Debug,,Environment property changed - hooking transport,1,Application 2018-03-18 21:35:01.8317,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2018-03-18 21:35:02.1117,Debug,,HandlePropertyChange has recognized that playback has started,1,Application 2018-03-18 21:35:02.1117,Debug,,Sending Http Post to http://192.168.29.194:8096/emby/Sessions/Playing?CanSeek=True&IsPaused=False&IsMuted=False&ItemId=eaf0d8cd4dea49a786e20ee42ccfd92a&QueueableMediaTypes=Audio&PlayMethod=Transcode&format=Json,1,Application 2018-03-18 21:35:02.1417,Debug,,Playstate changed to Playing for file://homeserver/Movies/The Dark knight/backdrops/theme.mp4,, PositionTicks:0,, Playlist Index:0,1,Application 2018-03-18 21:35:02.1417,Debug,,Back from PlayStateChanged,1,Application 2018-03-18 21:35:02.1617,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2018-03-18 21:35:02.2017,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2018-03-18 21:35:02.3017,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items/eaf0d8cd-4dea-49a7-86e2-0ee42ccfd92a?format=Json,1,Application 2018-03-18 21:35:02.6217,Info,,Received web socket message: UserDataChanged,10, 2018-03-18 21:35:03.6317,Debug,,MediaCenterEnvironment_PropertyChanged: MediaExperience,1,Application 2018-03-18 21:35:04.9717,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items/277f2dba9a45180835bdad49e1695d7e/Intros?format=Json,1,Application 2018-03-18 21:35:05.0117,Info,,Playing 2 Intros before The Dark Knight,1,Application 2018-03-18 21:35:05.0617,Debug,,Setting now playing status to False,1,Application 2018-03-18 21:35:05.0617,Debug,,Theme background stopped - unhooking,1,Application 2018-03-18 21:35:05.0917,Debug,,Setting now playing status to True,1,Application 2018-03-18 21:35:05.0917,Debug,,Playstate changed to Undefined for file://homeserver/Movies/The Dark knight/backdrops/theme.mp4,, PositionTicks:0,, Playlist Index:0,1,Application 2018-03-18 21:35:05.0917,Debug,,Back from PlayStateChanged,1,Application 2018-03-18 21:35:05.0917,Debug,,Calling HandleStopedState,1,Application 2018-03-18 21:35:05.0917,Debug,,In HandleStoppedState,1,Application 2018-03-18 21:35:05.0917,Debug,,Events unhooked,1,Application 2018-03-18 21:35:05.0917,Debug,,Turning off NPV,1,Application 2018-03-18 21:35:05.0917,Debug,,Setting now playing status to False,1,Application 2018-03-18 21:35:05.0917,Debug,,Internal Player playback finished,17,Worker thread for Common 2018-03-18 21:35:05.0917,Debug,,Updating Resume status...,17,Worker thread for Common 2018-03-18 21:35:05.0917,Debug,,All post-playback actions have completed.,17,Worker thread for Common 2018-03-18 21:35:05.0917,Info,,Internal Player about to play (http://192.168.29.194:8096/emby/videos/22aa9a5bfae28bcef82b74bb7a90ea54/stream.asf?DeviceId=5f7736fd120448379ff50419ba4588c5&MediaSourceId=fb500144670c0308abea9b40e289e154&VideoCodec=msmpeg4&AudioCodec=wmav2&AudioStreamIndex=-1&VideoBitrate=29872000&AudioBitrate=128000&MaxAudioChannels=2&api_key=222221129f814887b5a653336ac4e74b&CopyTimestamps=false&ForceLiveStream=false) ,1,Application 2018-03-18 21:35:05.0917,Info,,Internal Player playing ,1,Application 2018-03-18 21:35:05.0917,Debug,,Calling MediaCenterEnvironment.PlayMedia: Microsoft.MediaCenter.MediaCollection,1,Application 2018-03-18 21:35:05.1117,Error,,Error playing item: ( Exception. Type=System.ArgumentException Msg=Registry subkeys should not be greater than 255 characters. Src=mscorlib Method=HandleReturnMessage Line=0 Col=0 [n] StackTrace= [n] [n] Server stack trace: [n] at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource) [n] at Microsoft.Win32.RegistryKey.ValidateKeyName(String name) [n] at Microsoft.Win32.RegistryKey.OpenSubKey(String name,, Boolean writable) [n] at Microsoft.Win32.RegistryKey.OpenSubKey(String name) [n] at ServiceBus.UIFramework.EhFileInfo.GetPerceivedType(String path) [n] at Microsoft.MediaCenter.Playback.MediaCollectionEntryBuilder.Build(MediaCollectionItem mediaCollectionItem) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItem.Initialize(MediaCollection mediaCollection) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItem..ctor(MediaCollection mediaCollection) [n] at Microsoft.MediaCenter.Playback.MediaCollectionMediaItemBuilder.Build(MediaCollection mediaCollection) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean fAddToQueue) [n] at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target,, Boolean fExecuteInContext) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg,, Int32 methodPtr,, Boolean fExecuteInContext) [n] [n] Exception rethrown at [0]: [n] at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg,, IMessage retMsg) [n] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData,, Int32 type) [n] at MediaCenter.Extensibility.MCHostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean fAddToQueue) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md,, Object[] args,, Object server,, Int32 methodPtr,, Boolean fExecuteInContext,, Object[]& outArgs) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.PrivateProcessMessage(RuntimeMethodHandle md,, Object[] args,, Object server,, Int32 methodPtr,, Boolean fExecuteInContext,, Object[]& outArgs) [n] at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg,, Int32 methodPtr,, Boolean fExecuteInContext) [n] [n] Exception rethrown at [1]: [n] at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg,, IMessage retMsg) [n] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData,, Int32 type) [n] at Microsoft.MediaCenter.AddIn.HostControl.PlayMedia(MediaType mediaType,, Object media,, Boolean addToQueue) [n] at Microsoft.MediaCenter.MediaCenterEnvironment.PlayMedia(MediaType mediaType,, Object media,, Boolean addToQueue) [n] at MediaBrowser.Library.Playables.PlaybackControllerHelper.CallPlayMedia(MediaCenterEnvironment mediaCenterEnvironment,, MediaType type,, Object media,, Boolean queue) [n] at MediaBrowser.PlaybackController.CallPlayMediaUsingMediaCollection(MediaCenterEnvironment mediaCenterEnvironment,, PlayableItem playable) [n] at MediaBrowser.PlaybackController.CallPlayMediaForPlayableItem(MediaCenterEnvironment mediaCenterEnvironment,, PlayableItem playable) [n] at MediaBrowser.PlaybackController.PlayPlayableItem(PlayableItem playable) ),1,Application 2018-03-18 21:35:05.1117,Info,,MPC-HC about to play The Dark Knight(\\HOMESERVER\Movies\The Dark knight\The_Dark_Knight_t00.mkv) ,1,Application 2018-03-18 21:35:05.1217,Info,,MPC-HC playing The Dark Knight,1,Application 2018-03-18 21:35:05.1217,Debug,,Sending Http Post to http://192.168.29.194:8096/emby/Sessions/Playing?CanSeek=True&IsPaused=False&IsMuted=False&ItemId=277f2dba9a45180835bdad49e1695d7e&QueueableMediaTypes=Audio&PlayMethod=DirectPlay&format=Json,1,Application 2018-03-18 21:35:05.1217,Info,,Starting command line C:\Program Files\MPC-HC\mpc-hc.exe "\\HOMESERVER\Movies\The Dark knight\The_Dark_Knight_t00.mkv" /play /close /fullscreen /start 0,1,Application 2018-03-18 21:35:05.1317,Debug,,Minimizing Windows Media Center,21,Worker thread for Common 2018-03-18 21:35:05.6317,Info,,Received web socket message: UserDataChanged,10, 2018-03-18 21:35:15.2252,Debug,,MPC-HC playback finished,21,Worker thread for Common 2018-03-18 21:35:15.2252,Debug,,Reporting stopped to server for The Dark Knight,21,Worker thread for Common 2018-03-18 21:35:15.2252,Debug,,Sending Http Post to http://192.168.29.194:8096/emby/Sessions/Playing/Stopped?positionTicks=0&ItemId=277f2dba9a45180835bdad49e1695d7e&format=Json,21,Worker thread for Common 2018-03-18 21:35:15.2252,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items/277f2dba-9a45-1808-35bd-ad49e1695d7e?format=Json,21,Worker thread for Common 2018-03-18 21:35:15.2852,Debug,,Setting new status on The Dark Knight with parent of Movies,21,Worker thread for Common 2018-03-18 21:35:15.2852,Debug,,Firing Application.PlaybackFinished for: The Dark Knight,21,Worker thread for Common 2018-03-18 21:35:15.2852,Debug,,Updating Resume status...,21,Worker thread for Common 2018-03-18 21:35:15.2852,Debug,,All post-playback actions have completed.,21,Worker thread for Common 2018-03-18 21:35:15.7252,Info,,Received web socket message: UserDataChanged,34, 2018-03-18 21:35:31.0088,Debug,,Keep alive call,, IsCurretntlyVisible=True,1,Application 2018-03-18 21:35:31.2263,Info,,Received web socket message: LibraryChanged,5, 2018-03-18 21:35:31.2463,Debug,,Library Changed...,5, 2018-03-18 21:35:31.2463,Debug,,Folders Added to: 0 Items Added: 0 Items Removed: 0 Items Updated: 1,5, 2018-03-18 21:35:31.2463,Debug,,Changed Item 2b2bca16aacc8a14d53a11bb829eafa5 is not loaded,5, 2018-03-18 21:32:05.1408,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\strings-en.xml,1,Application 2018-03-18 21:32:05.2108,Debug,,=========System looking for assembly: System.Data.SQLite,, Version=1.0.88.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1,Application 2018-03-18 21:32:05.2108,Info,,System.Data.SQLite,, Version=1.0.88.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139 is being resolved to System.Data.SQLite,, Version=1.0.88.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1,Application 2018-03-18 21:32:05.2608,Info,,==========Using new SQL Repo========,1,Application 2018-03-18 21:32:05.5608,Info,,Playstate initialization took 0.01 seconds.,1,Application 2018-03-18 21:32:05.5708,Info,,Total Kernel Init took 0.48 seconds.,1,Application 2018-03-18 21:32:05.6008,Info,,Successfully loaded fastload data for : C:\ProgramData\MediaBrowser-Classic\Cache\playstate MediaBrowser.Library.Entities.PlaybackStatus,13,Worker thread for FastLoadLoader 2018-03-18 21:32:05.6508,Info,,Finished validating : C:\ProgramData\MediaBrowser-Classic\Cache\playstate MediaBrowser.Library.Entities.PlaybackStatus,13,Worker thread for FastLoadLoader 2018-03-18 21:32:05.6508,Info,,Dictionary loading and validation took 0.09 seconds.,13,Worker thread for FastLoadLoader 2018-03-18 21:32:06.1508,Info,,Information DisplayText: Welcome to Emby for WMC,1,Application 2018-03-18 21:32:06.1708,Info,,Emby (version 3.0.314.0 ) Starting up.,1,Application 2018-03-18 21:32:06.1708,Info,,Startup parameters: ,1,Application 2018-03-18 21:32:06.1908,Debug,,Having to get media experience by reflection due to bug in Windows 7,1,Application 2018-03-18 21:32:06.1908,Debug,,GetMediaExperienceUsingReflection was unsuccessful,1,Application 2018-03-18 21:32:06.6108,Info,,Sending Http Get to http://192.168.29.194:8096/emby/System/Info/Public?format=Json,1,Application 2018-03-18 21:32:06.6608,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/Public?isDisabled=False&format=Json,1,Application 2018-03-18 21:32:06.7408,Info,,Connected to server THEATERPC at http://192.168.29.194:8096,1,Application 2018-03-18 21:32:06.7408,Info,,Server version: 3.3.1.0,1,Application 2018-03-18 21:32:06.7408,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/MetroLoginPage,1,Application 2018-03-18 21:32:06.7708,Info,,Application Init took 1.20 seconds.,1,Application 2018-03-18 21:32:08.1509,Debug,,Sending Http Post to http://192.168.29.194:8096/emby/Users/19f91e16b77d4fc4a43fedbd78496a6b/Authenticate?format=Json,17,Worker thread for Common 2018-03-18 21:32:08.2409,Info,,Sending Http Get to http://192.168.29.194:8096/emby/System/Configuration?format=Json,17,Worker thread for Common 2018-03-18 21:32:08.3109,Info,,Sending Http Get to http://192.168.29.194:8096/emby/System/Info?format=Json,17,Worker thread for Common 2018-03-18 21:32:08.3609,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Plugins?format=Json,17,Worker thread for Common 2018-03-18 21:32:09.2709,Info,,*** Theme in use is: Chocolate,17,Worker thread for Common 2018-03-18 21:32:09.2709,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Packages?packagetype=UserInstalled&targetsystems=MBClassic&format=Json,20,Worker thread for Common 2018-03-18 21:32:09.3709,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.308.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1,Application 2018-03-18 21:32:09.3709,Info,,Plug-in reference to MediaBrowser,, Version=3.0.308.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.314.0,1,Application 2018-03-18 21:32:09.3709,Debug,,Added Plugin assembly: Chocolate,, Version=3.0.9.0,, Culture=neutral,, PublicKeyToken=cbacf2b624ff6ad4,1,Application 2018-03-18 21:32:09.4009,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\Chocolate-strings-en.xml,1,Application 2018-03-18 21:32:09.4309,Info,,Chocolate Theme (version 3.0.9.0) Loaded.,1,Application 2018-03-18 21:32:09.4309,Info,,Plugin Loading and Init took 0.16 seconds.,1,Application 2018-03-18 21:32:09.4509,Debug,,=========System looking for assembly: WebSocket4Net,, Version=0.12.0.0,, Culture=neutral,, PublicKeyToken=eb4e154b696bf72a,1,Application 2018-03-18 21:32:09.4509,Info,,Resolving WebSocket4Net,, Version=0.12.0.0,, Culture=neutral,, PublicKeyToken=eb4e154b696bf72a to C:\ProgramData\MediaBrowser-Classic\websocket4net.dll,1,Application 2018-03-18 21:32:09.4909,Info,,Connected to ws://192.168.29.194:8096/mediabrowser,1,Application 2018-03-18 21:32:09.4909,Debug,,Sending Http Post to http://192.168.29.194:8096/emby/Sessions/Capabilities?format=Json,1,Application 2018-03-18 21:32:09.5109,Debug,,Navigating to My Library item type MediaBrowser.Library.FolderModel,1,Application 2018-03-18 21:32:09.5109,Debug,,Loading display prefs for ,1,Application 2018-03-18 21:32:09.5109,Info,,Sending Http Get to http://192.168.29.194:8096/emby/DisplayPreferences/3f0912cb-11f9-0ea0-1031-b8d6746fa181?userId=19f91e16b77d4fc4a43fedbd78496a6b&client=MBC&format=Json,1,Application 2018-03-18 21:32:09.5709,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16b77d4fc4a43fedbd78496a6b/Views?format=Json,1,Application 2018-03-18 21:32:09.9609,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/Page,1,Application 2018-03-18 21:32:09.9609,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Items/3f0912cb11f90ea01031b8d6746fa181/ThemeMedia?InheritFromParent=False&UserId=19f91e16b77d4fc4a43fedbd78496a6b&format=Json,20,Worker thread for Common 2018-03-18 21:32:10.0609,Error,,Error getting response from http://192.168.29.194:8096/emby/Items/3f0912cb11f90ea01031b8d6746fa181/ThemeMedia?InheritFromParent=False&UserId=19f91e16b77d4fc4a43fedbd78496a6b&format=Json ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (404) Not Found. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),20,Worker thread for Common 2018-03-18 21:32:10.5409,Debug,,=========System looking for assembly: Chocolate,1,Application 2018-03-18 21:32:10.5409,Info,,Resolving plug-in reference to: Chocolate,1,Application 2018-03-18 21:32:10.9309,Debug,,Loading display prefs for ,1,Application 2018-03-18 21:32:11.0109,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Images/General?format=Json,1,Application 2018-03-18 21:32:11.0209,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16-b77d-4fc4-a43f-edbd78496a6b/Items?ParentId=9df4efab1f9566a6088195a3f6029855&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&artistIds=&years=&format=Json,19,Worker thread for Common 2018-03-18 21:32:11.0309,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Localization/ParentalRatings?format=Json,1,Application 2018-03-18 21:32:11.0809,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Images/MediaInfo?format=Json,1,Application 2018-03-18 21:32:11.0909,Debug,,Could not find resource 'rated_none' in theme Chocolate,1,Application 2018-03-18 21:32:11.0909,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/rated_none being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:32:11.1009,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16b77d4fc4a43fedbd78496a6b/Items?ParentId=9df4efab1f9566a6088195a3f6029855&limit=20&sortBy=DateCreated&sortOrder=Descending&fields=Overview,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&Filters=&ImageTypes=&recursive=True&genres=&Ids=&studioIds=&ExcludeItemTypes=series,,season,,musicalbum,,musicartist,,folder,,movie,,audio,,episode&IncludeItemTypes=boxset&ExcludeLocationTypes=Virtual&personIds=&personTypes=&artistIds=&years=&format=Json,22,Worker thread for Common 2018-03-18 21:32:11.1409,Info,,RAL child retrieval for Collections option added took 0.04 seconds.,22,Worker thread for Common 2018-03-18 21:32:11.1409,Debug,,added list for Collections loaded with 0 items.,22,Worker thread for Common 2018-03-18 21:32:11.1609,Info,,Information DisplayText: Welcome to Emby for WMC,1,Application 2018-03-18 21:32:12.8009,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16b77d4fc4a43fedbd78496a6b/Items?ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805&sortBy=&fields=Overview,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&Filters=&ImageTypes=&recursive=True&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=Movie&ExcludeLocationTypes=&personIds=&personTypes=&artistIds=&years=&format=Json,20,Worker thread for Common 2018-03-18 21:32:13.4009,Info,,Sending Http Get to http://192.168.29.194:8096/emby/DisplayPreferences/f137a2dd21bbc1b99aa5c0f6bf02a805?userId=19f91e16b77d4fc4a43fedbd78496a6b&client=MBC&format=Json,20,Worker thread for Common 2018-03-18 21:32:13.4209,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Users/19f91e16b77d4fc4a43fedbd78496a6b/Items?ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805&limit=20&sortBy=DateCreated&sortOrder=Descending&fields=Overview,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&Filters=&ImageTypes=&recursive=True&genres=&Ids=&studioIds=&ExcludeItemTypes=series,,season,,musicalbum,,musicartist,,folder,,boxset&IncludeItemTypes=movie&ExcludeLocationTypes=Virtual&personIds=&personTypes=&artistIds=&years=&format=Json,20,Worker thread for Common 2018-03-18 21:32:13.4809,Info,,RAL child retrieval for Movies option added took 0.06 seconds.,20,Worker thread for Common 2018-03-18 21:32:13.4809,Debug,,added list for Movies loaded with 20 items.,20,Worker thread for Common 2018-03-18 21:32:13.4809,Info,,Sending Http Get to http://192.168.29.194:8096/emby/DisplayPreferences/3940a914-d772-f9de-cc32-64f4ddd41ec5?userId=19f91e16b77d4fc4a43fedbd78496a6b&client=MBC&format=Json,20,Worker thread for Common 2018-03-18 21:32:13.8609,Debug,,Navigating to Movies item type MediaBrowser.Library.FolderModel,1,Application 2018-03-18 21:32:13.8609,Debug,,Loading display prefs for C:\Users\DenComputer\AppData\Roaming\Emby-Server\programdata\root\default\Movies,1,Application 2018-03-18 21:32:13.8709,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/Page,1,Application 2018-03-18 21:32:13.8709,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/ThemeMedia?InheritFromParent=False&UserId=19f91e16b77d4fc4a43fedbd78496a6b&format=Json,26,Worker thread for Common 2018-03-18 21:32:13.9109,Debug,,Loading display prefs for C:\Users\DenComputer\AppData\Roaming\Emby-Server\programdata\root\default\Movies,1,Application 2018-03-18 21:32:14.4409,Debug,,Could not find resource 'rated_r' in theme Chocolate,1,Application 2018-03-18 21:32:14.4409,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/rated_r being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:32:14.7309,Debug,,Could not find resource 'codec_h262' in theme Chocolate,1,Application 2018-03-18 21:32:14.7309,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/codec_h262 being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:32:14.7409,Debug,,Could not find resource 'codec_ac3' in theme Chocolate,1,Application 2018-03-18 21:32:14.7409,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/codec_ac3 being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:32:14.7409,Debug,,Could not find resource 'channels_6' in theme Chocolate,1,Application 2018-03-18 21:32:14.7409,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/channels_6 being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:32:14.7509,Debug,,Could not find resource 'aspect_150' in theme Chocolate,1,Application 2018-03-18 21:32:14.7509,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/aspect_150 being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:32:14.7609,Debug,,Could not find resource 'media_mkv' in theme Chocolate,1,Application 2018-03-18 21:32:14.7609,Debug,,===CustomImage resx://MediaBrowser/MediaBrowser.Resources/media_mkv being cached on first access. Should only have to do this once per session...,1,Application 2018-03-18 21:32:19.2909,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Plugins/RegistrationRecords/mbsupporter?Mb2Equivalent=mbsupporter&format=Json,22,Worker thread for Common 2018-03-18 21:32:19.5209,Info,,Sending Http Get to http://192.168.29.194:8096/emby/Packages/MBClassic?format=Json,19,Worker thread for Common 2018-03-18 21:32:20.1009,Info,,==== Emby for WMC is up to date.,19,Worker thread for Common 2018-03-18 21:32:22.1709,Info,,Information DisplayText: Emby for WMC is up to date,1,Application 2018-03-18 21:32:35.9754,Info,,Received web socket message: LibraryChanged,15, 2018-03-18 21:32:35.9854,Debug,,Library Changed...,15, 2018-03-18 21:32:35.9854,Debug,,Folders Added to: 0 Items Added: 0 Items Removed: 0 Items Updated: 1,15, 2018-03-18 21:32:35.9954,Debug,,Changed Item 2b2bca16aacc8a14d53a11bb829eafa5 is not loaded,15, 2018-03-18 21:32:46.7704,Info,,Received web socket message: ScheduledTaskEnded,15, 2018-03-18 21:32:55.5195,Info,,Received web socket message: ServerRestarting,33, 2018-03-18 21:33:06.1795,Debug,,Keep alive call,, IsCurretntlyVisible=False,1,Application 2018-03-18 21:33:09.5895,Info,,Reconnecting WebSocket which has dropped.,32, 2018-03-18 21:33:09.5895,Info,,Sending Http Get to http://192.168.29.194:8096/emby/System/Info?format=Json,32, 2018-03-18 21:33:09.6695,Error,,Error getting response from http://192.168.29.194:8096/emby/System/Info?format=Json ( Exception. Type=System.Net.WebException Msg=The remote server returned an error: (503) Server Unavailable. Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),32,
ebr 16332 Posted March 19, 2018 Posted March 19, 2018 I don't think this is related to the external player at all. Seems to be the same issue reported here with the length of the trailer URL.
