PenkethBoy 2068 Posted March 17, 2018 Posted March 17, 2018 I have been trying to get Vaapi to work on my QNAP 853A I have set it to Vaapi in the Transcoding section and have it set to /dev/dri/renderD128 In the DVR section i have set the option to convert to mkv I have enabled Hardware encoding as i want Vaapi to be used with Transcoding TV recordings as the NAS is not capable of recording two show as mkv at the same time at an acceptable speed Am i missing something? Couple of example files and log record-transcode-ef9e851e-0cf9-4034-a542-c5dfff717d54.txt record-transcode-efe8331f-caf5-4f65-b7d7-d4b762469520.txt server-63656841600.txt
Luke 42240 Posted March 17, 2018 Posted March 17, 2018 We don't use it for the recording conversion feature. It will be used for regular playback though.
PenkethBoy 2068 Posted March 17, 2018 Author Posted March 17, 2018 Ok - out of interest if thats the case what is hardware encoding used for? and no its not being used in playback either ffmpeg-transcode-2a6afb2f-e979-4678-b05f-75968dda03d4.txt
Luke 42240 Posted March 17, 2018 Posted March 17, 2018 There see certain kinds of files it can't be used with so assuming you've actually enabled it that's probably the reason. The converting feature is soon to be deprecated once we have a feature to convert after the recording. It's just too unstable to convert on the fly.
