best boy 0 Posted March 16, 2018 Posted March 16, 2018 (edited) Hi, it seems that the stream quality settings in the web application are broken. The dropdown lists a multitude of options for resolution and bit rate combinations (144p up to 1080p@60 Mbps), but none of them can be selected. The selection is set to "auto (720p - 1.5 Mbps)" when the stream starts and none of the other available options stick after selection. The user selection is entirely ignored. This behavior can be observed or all video files It spans across multiple browsers/platforms as it is reproducible forFirefox 59 and the current Chrome Canary on Windows 7 (desktop case) Chromium 65 on Android 8.1 (mobile case) There are no global bandwidth limits maintained on the server There are no user-specific bandwidth limits maintained The server and the desktop are located in the same subnet of a switched gigabit network The mobile device is on a low traffic WIFI network with very good reception (SNR >35 dBm) I'm running Emby Server 3.3.0.0 in a FreeBSD 10.3 jail (from package not ports). FFmpeg version is 3.4.2,1 Stats for nerds: Playback Info Player: Html Video Player Play method: Transcode Protocol: https Stream type: HLS Video Info Player dimensions: 1728x944.0999755859375 Video resolution: 720x360 Dropped frames: 0 Corrupted frames: 0 Transcoding Info Video codec: H264 Audio codec: AAC Bitrate: 1.5 Mbps Transcoding progress: 2.0% Reason for transcoding: Media bitrate exceeds limit. Original Media Info Container: webm Bitrate: 12.2 Mbps Video codec: H264 High Video bitrate: 12.2 Mbps Audio codec: EAC3 Audio bitrate: 448 kbps Audio channels: 6 Audio sample rate: 48000 Hz Transcoding: https://172.22.22.122:8920/emby/videos/132a95a2162a553ecc8e97b96bb0914b/hls1/main/0.ts?DeviceId=6521083d0205baf76e949813b97e9ada&MediaSourceId=132a95a2162a553ecc8e97b96bb0914b&VideoCodec=h264&AudioCodec=mp3,aac&AudioStreamIndex=1&VideoBitrate=1116000&AudioBitrate=384000&PlaySessionId=bf10ff4553ac4676a5a054b8af60b860&api_key=<redacted>&TranscodingMaxAudioChannels=2&RequireAvc=true&Tag=e9fc8fad20d6aed334388af521a5dcb4&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=51&h264-deinterlace=true&TranscodeReasons=ContainerBitrateExceedsLimit Media Info: Format : Matroska Format version : Version 4 / Version 2 File size : 5.01 GiB Duration : 58 min 53 s Overall bit rate : 12.2 Mb/s Encoded date : UTC 2018-02-02 19:01:29 Writing application : mkvmerge v19.0.0 ('Brave Captain') 64-bit Writing library : libebml v1.3.5 + libmatroska v1.4.8 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, RefFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 58 min 53 s Bit rate : 11.7 Mb/s Width : 1 920 pixels Height : 960 pixels Display aspect ratio : 2.000 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.265 Stream size : 4.82 GiB (96%) Writing library : x264 core 152 r2851kMod ba24899 Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / fade_compensate=0.00 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=17.0000 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.30 / pb_ratio=1.20 / aq=3:0.80 Language : English Default : Yes Forced : No Audio ID : 2 Format : E-AC-3 Format/Info : Enhanced Audio Coding 3 Format profile : E-AC-3+Atmos / E-AC-3 Codec ID : A_EAC3 Duration : 58 min 2 s Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 15 objects / 6 channels Channel positions : 15 objects / Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 187.500 FPS (256 SPF) Compression mode : Lossy Stream size : 186 MiB (4%) Language : English Service kind : Complete Main Default : Yes Forced : No Text #1 ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 54 min 57 s Bit rate : 66 b/s Count of elements : 723 Stream size : 26.7 KiB (0%) Language : English Default : No Forced : No [... more subtiles in other languages... removed for brevity] Any help would be greatly appreciated. Thanks! Edit: attached server and transcoding log files Edit2: attached system.xml ffmpeg-transcode.txt server.txt system.xml Edited June 30, 2018 by best boy
Luke 42210 Posted March 16, 2018 Posted March 16, 2018 Hi, in my testing this seems to be working just fine. Can you please attach the emby server and ffmpeg logs associated with this example? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
best boy 0 Posted March 16, 2018 Author Posted March 16, 2018 (edited) I attached the requested log files to the OP. Of most interest are probably these probing requests: 2018-03-16 23:49:02.640 Info HttpServer: HTTP GET https://172.22.22.122:8920/emby/Playback/BitrateTest?Size=500000. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3372.0 Safari/537.36 2018-03-16 23:49:02.661 Info HttpServer: HTTP Response 200 to 172.22.22.11. Time: 21ms. https://172.22.22.122:8920/emby/Playback/BitrateTest?Size=500000 2018-03-16 23:49:02.667 Info HttpServer: HTTP GET https://172.22.22.122:8920/emby/Playback/BitrateTest?Size=1000000. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3372.0 Safari/537.36 2018-03-16 23:49:02.703 Info HttpServer: HTTP GET https://172.22.22.122:8920/emby/Playback/BitrateTest?Size=3000000. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3372.0 Safari/537.36 2018-03-16 23:49:02.708 Info HttpServer: HTTP Response 200 to 172.22.22.11. Time: 42ms. https://172.22.22.122:8920/emby/Playback/BitrateTest?Size=1000000 2018-03-16 23:49:02.942 Info HttpServer: HTTP GET https://emby.home.lan:8920/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:59.0) Gecko/20100101 Firefox/59.0 2018-03-16 23:49:02.944 Info HttpServer: HTTP Response 200 to 172.22.22.11. Time: 2ms. https://emby.home.lan:8920/ScheduledTasks?IsEnabled=true 2018-03-16 23:49:02.957 Info HttpServer: HTTP Response 200 to 172.22.22.11. Time: 254ms. https://172.22.22.122:8920/emby/Playback/BitrateTest?Size=3000000 From the timestamps it looks like BitrateTest?Size=1000000 and BitrateTest?Size=3000000 are send concurrently. I'd have expected to see these probing requests in sequence each waiting for a response of the previous one. This is essentially a BitrateTest?Size=4000000 Edited March 16, 2018 by best boy
Luke 42210 Posted March 17, 2018 Posted March 17, 2018 The bitrate tests don't relate to this. Is 3.3.1 available for freebsd yet?
best boy 0 Posted March 17, 2018 Author Posted March 17, 2018 Unfortunately not yet. Even the ports version is still 3.3.0.0.
Luke 42210 Posted March 17, 2018 Posted March 17, 2018 Ok we may need to reevaluate once you have 3.3.1.
best boy 0 Posted April 29, 2018 Author Posted April 29, 2018 I've just updated to 3.3.1.0 and the behavior is still the same. The quality settings are set to auto (720p @ 1,5 MBit/s) and cannot be changed. This is independent of the client, it's location in the network segment and the content.
best boy 0 Posted April 29, 2018 Author Posted April 29, 2018 (edited) OK, I think I found the issue. It's related to the "LAN networks" settings (expert > advanced > LAN networks). When this field was introduced, I added 192.168.0.0/255.255.0.0, 172.16.0.0/255.240.0.0 to expand on what is considered a local network by Emby. The server is in the 172.22.22.0/255.255.255.0 segment with IP 172.22.22.122. It seems that there is a bug resulting in Emby not considering clients of the 192.168.0.0/16 net to be local. Also, does that mean that external networks are at best limited to 720p @ 1,5Mbps? I do not have any bandwidth limitations configured. It looks like even gigabit Ethernet limits you down to that maximum, if it gets tagged as "external". That really questions the functionality of the network quality assessment code. It's not even funny how wrong it is. How does it work? Can we disable it entirely and let external clients select their quality settings manually? Do we have to add 0.0.0.0/0 as LAN networks to disable it? Edited April 29, 2018 by best boy
Luke 42210 Posted April 29, 2018 Posted April 29, 2018 Please try again with the next release, thanks.
slippy1 0 Posted June 27, 2018 Posted June 27, 2018 (edited) Having this issue on my freebsd server. I manually updated to 3.4.1.0 and I still have this issue. I think it might be something that we're not setting properly?Internally this works fine, and i'm able to play at whatever bitrate i want or just direct play. externally there seems to be some hard 1.5mbps bitrate limit that i can't seem to change?adding 0.0.0.0/0 to lan networks allows this to work perfectly. is that the intended behavior? Edited June 27, 2018 by slippy1
Luke 42210 Posted June 27, 2018 Posted June 27, 2018 Hi, this sounds like you might have configured the servers max internet streaming bitrate setting. I would undo that and the lan network setting. Please let us know if this helps. Thanks.
best boy 0 Posted June 30, 2018 Author Posted June 30, 2018 (edited) As I have mentioned in any of my posts: I do not have bandwidth limitations configured. Not for users and not for the system. I've attached my settings.xml system.xml to the original post but the gist of it is: <ServerConfiguration> [...] <RemoteClientBitrateLimit>0</RemoteClientBitrateLimit> [...] <LocalNetworkSubnets> <string>0.0.0.0/0</string> </LocalNetworkSubnets> <LocalNetworkAddresses /> [...] </ServerConfiguration> Edited June 30, 2018 by best boy
Luke 42210 Posted June 30, 2018 Posted June 30, 2018 I would remove the local network setting because that may cause the server to believe that every connection is local.
best boy 0 Posted June 30, 2018 Author Posted June 30, 2018 Yeah, but that's the workaround. If we do not lead the server on to think everything is local, then some local networks will be considered external and exhibit the issue described: forced 720p @1.5Mbps. For me this works just fine. I do not have external networks.
Luke 42210 Posted June 30, 2018 Posted June 30, 2018 Ok, there were improvements and fixes to the in the latest release of emby server so we may just have to wait until that is available for freebsd. Thanks.
