SPARTAN_GIV 0 Posted March 16, 2018 Posted March 16, 2018 Hello all, Im runnig the following config: QNAP: TS-853A Hardware:CPU: Intel Celeron CPU N3160 @ 1.60Ghz RAM: 8 GB Software:Firmware version: 4.3.4.0486 Build 20180215 Emby Server: 3.3.1.0 ffmpeg: 3.4.2 Mono: 5.11.0 The Problems im having: Remote not accesebol/working as show below, cant forward, cant see anny details and cant go back If I want to play a hole album it will only play one song most of the time, I cant see the play list Emby is not cutting gables files and if they are cut in seperates there will be a break betwean them. Tanks in advance, Greatings, Spartan_GIV
Luke 42240 Posted March 16, 2018 Posted March 16, 2018 Hi, it looks like nothing is playing. Is that right?
SPARTAN_GIV 0 Posted March 16, 2018 Author Posted March 16, 2018 Hi, it looks like nothing is playing. Is that right? No it ain’t it is playing but it’s not showing on any device what it is playing. This is wat you get to see ore not if you go to the remote. The remote bar is also not showing that’s why I made this screenshot of the separate function. Also it will only play one song instead of full album, ore mix. Greetings SPARTAN_GIV
Luke 42240 Posted March 16, 2018 Posted March 16, 2018 Can you please discuss an example in detail? What device are you playing to?
SPARTAN_GIV 0 Posted March 16, 2018 Author Posted March 16, 2018 We are using a DNLAdevice a Yamaha networkplayer NPS303 also we use a Logitech media player. On the Emby app we select the device we want to play on than we select what we want to play for exempel a album. It will play one song. Not the full album and the Emby ui Will not display what it is playing. What specific details do You nead.
Luke 42240 Posted March 17, 2018 Posted March 17, 2018 Can you please attach the emby server log from when you tried to do this? You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
SPARTAN_GIV 0 Posted March 21, 2018 Author Posted March 21, 2018 (edited) The staps/problems and the log Connect to player Yamaha networkplayer NPS303 Play album Well playing the song there aint a remote showing up as it should Also not on mobile device's Afthere song 1 the player stops playing aint playng song 2 as it should Allsowe the Emby server does not open the right Ip when opening instead of the LocalHost::8096/emby it whants to open LocalHost:8920 Thx in advanse Log.txt Edited March 21, 2018 by SPARTAN_GIV
Luke 42240 Posted March 24, 2018 Posted March 24, 2018 Ok, I don't have a yamaha for testing, but on my smart tv's i'm not able to reproduce this. I will keep testing though. Thanks.
