jinxy88 0 Posted April 3, 2018 Author Posted April 3, 2018 @@Luke Samsung SmartTV (UE55KS7502) Emby Theater 1.0.38 kinda hard to belive how it can work for you this way, since i tried like 50+ movies with subs placen in the same folder as the strm, and with reencoding disabled and no subs will play on any app... here are the proofs attached from web app and emby theater, cant make one pics on the samsung tv now, as im not home. i will also send u an archive with strm's + srt files in pm, so you can check them all https://gyazo.com/c2ba694ef4420ce0ec0e4079a87ee5a6 https://gyazo.com/bd4f580002d3e9ab676e7f1e8aa1735e https://gyazo.com/9542a696bf6f860971d2f8a28bfa8518 https://gyazo.com/643adb9a10e17e4420937431002f1c91 https://gyazo.com/f8ebaf514aaccf0f9246fa92907267de
jinxy88 0 Posted April 3, 2018 Author Posted April 3, 2018 Yes please send something i can try. thanks. Check PM, i sent u some files
Luke 42245 Posted April 3, 2018 Posted April 3, 2018 Ok, we've just had release 1.0.40 approved. Samsung will hopefully launch that by the end of the week. Please try that. Thanks.
jinxy88 0 Posted April 3, 2018 Author Posted April 3, 2018 But what about webapp and emby thetre @@Luke ?
jinxy88 0 Posted April 3, 2018 Author Posted April 3, 2018 Will all the apps work now without that reencode thing enabled?
Luke 42245 Posted April 3, 2018 Posted April 3, 2018 Alphabetically i tested the first two but didn't get anywhere because it looks like the urls are bad.
jinxy88 0 Posted April 4, 2018 Author Posted April 4, 2018 @@Luke please try now, my server had some power outage, now all the STRM's i sent u are working, only need your magic to fix the subs
Luke 42245 Posted April 4, 2018 Posted April 4, 2018 The first one is working just fine for me in the browser with all transcoding features enabled. If you disable transcoding then it won't work because the video is VC1 and web browsers don't support that. Please note, this whole time you've been waiting for me to test this and give you answer, while the information has already been available to you on our wiki: https://github.com/MediaBrowser/Wiki/wiki/Web%20Client You can find the supported media formats for each app. If your media does not fall into that category, then transcoding will be needed. Thanks.
jinxy88 0 Posted April 4, 2018 Author Posted April 4, 2018 @@Luke we are not on the same page it seems, i am not talking about the builtin subs or the codec, i just said "external" srt subtitles will not work for any movie if transcoding is disabled....
Luke 42245 Posted April 4, 2018 Posted April 4, 2018 @@Luke we are not on the same page it seems, i am not talking about the builtin subs or the codec, i just said "external" srt subtitles will not work for any movie if transcoding is disabled.... The movie is vc1 video, you can't play that in the web browser with transcoding disabled. You can't even get to the point of enabling subtitles.
jinxy88 0 Posted April 4, 2018 Author Posted April 4, 2018 This is happening in emby theater and samsung emby app aswell, my players are capable of direct playing the files, only problem is it cant display the external srt subs unless i let it transcode, that 4th tick
jinxy88 0 Posted April 4, 2018 Author Posted April 4, 2018 As for webapp i will give you some now strm files with aac and h264, so you can see its no difference
Luke 42245 Posted April 4, 2018 Posted April 4, 2018 Here's Emby Theater direct playing. You can see the subs underneath the osd.
jinxy88 0 Posted April 4, 2018 Author Posted April 4, 2018 And u have that 4th tick disabled in emby server?
jinxy88 0 Posted April 4, 2018 Author Posted April 4, 2018 I will try again now, but im doing these tests for 1 month and never worked...
jinxy88 0 Posted April 4, 2018 Author Posted April 4, 2018 Ok so on samsung tv app 1.0.38 subs wont play and neither on emby theater for me, with transcoding disabled...cant understand how its working for you @@Luke Ill wait for samsung to push the 1.0.40 update and check then... The tv is what im the most interested in, so hopefully with the update subs will work
jinxy88 0 Posted April 10, 2018 Author Posted April 10, 2018 @@Luke tested with 1.1.40 and unfortunately there is no change for samsung tv, external subs wont work with the 4th tick enabled or disabled.
Luke 42245 Posted April 10, 2018 Posted April 10, 2018 Please try it again with the next server release, thanks.
jinxy88 0 Posted April 10, 2018 Author Posted April 10, 2018 I tried it with 3.3.1.15 beta U mean other server version?
