jinxy88 0 Posted March 16, 2018 Posted March 16, 2018 The problem appeared after the latest 3.3.1.5 update, before this update external subs were working with strm files. Now even if you download one, it will still no show it at all, and sometimes instead of displaying the external subtitle it will display the strm embedded default sub. I have tried this in the web app, emby theater, smart tv and its the exact same situation. You have the server log attached serverlog.txt
Luke 42245 Posted March 16, 2018 Posted March 16, 2018 What do you mean no show? It can't be selected? Or it is selected but doesn't show?
jinxy88 0 Posted March 16, 2018 Author Posted March 16, 2018 You can select them but they wont be displayed @@Luke
Senna 368 Posted March 16, 2018 Posted March 16, 2018 (edited) Same issue here... https://emby.media/community/index.php?/topic/57098-297-subtitle-issues-srt-strm-library/ Edit: webapp seems to be fixed now. Edited March 16, 2018 by Senna
jinxy88 0 Posted March 16, 2018 Author Posted March 16, 2018 @@Senna fixed how? There is no server update, and for me is the same on every device
Senna 368 Posted March 16, 2018 Posted March 16, 2018 (edited) Only in webapp I said, which they can update. Just like all other online Emby config files that are loaded by the Emby apps, without updating the app itself, to fix issues. Edited March 16, 2018 by Senna
jinxy88 0 Posted March 16, 2018 Author Posted March 16, 2018 I see but for me it still doesnt work, not even in webapp
Senna 368 Posted March 16, 2018 Posted March 16, 2018 (edited) It works in web app, you can test this way: Create a new Test library, place a couple of strm with matching srt in it. Play those couple of strm's to let Emby probe media info. Back out of Test library, so that it refreshes the media info and go back in Test library. Before play, select srt to play with and now it should work in webapp. To make it clear, the webapp is the page you land on by pressing the "Emby Web App" button on top of every forum page here. So don't confuse this with http://localhost:8096/web/home.html or whatever your local Emby server address is. Those two can be different, regarding functionality and format support. Edited March 16, 2018 by Senna
jinxy88 0 Posted March 16, 2018 Author Posted March 16, 2018 So u mean create a new library and place the external srt in the same folder as the strm?
jinxy88 0 Posted March 17, 2018 Author Posted March 17, 2018 @@Senna i also tried the way you told me and it still doesnt seem to be working. i made a new library, placed the matching srt with strm in the same folders and its not displaying them.
Luke 42245 Posted March 17, 2018 Posted March 17, 2018 I'm not able to reproduce this with external srt in the web app.
jinxy88 0 Posted March 17, 2018 Author Posted March 17, 2018 (edited) @@Luke i can send u some strm so u can try with them, you will see it is not working check your pm Edited March 17, 2018 by jinxy88
Luke 42245 Posted March 17, 2018 Posted March 17, 2018 I tried the daddy's home example in Chrome. The external subs are working fine for me on the first try.
jinxy88 0 Posted March 17, 2018 Author Posted March 17, 2018 Lol i dont understand how, im using chrome too, but no matter what i try it wont work...
jinxy88 0 Posted March 17, 2018 Author Posted March 17, 2018 Did u place the srt and strm in the same folder? Did u try on windows server/linux server? Can u also try on emby theater?
Luke 42245 Posted March 17, 2018 Posted March 17, 2018 Yes same folder. I was able to reproduce some issues in Theater. It's resolved for the next update to the app. thanks.
jinxy88 0 Posted March 17, 2018 Author Posted March 17, 2018 Wow, if u fix it for theater is awesome <3
Senna 368 Posted March 17, 2018 Posted March 17, 2018 Yes same folder. I was able to reproduce some issues in Theater. That's was already mentioned multiple times..... From post #39 and up here https://emby.media/community/index.php?/topic/49752-api-allow-duration-to-be-supplied-for-strm-files-to-allow-resume/page-2&do=findComment&comment=556198 and https://emby.media/community/index.php?/topic/57098-297-subtitle-issues-srt-strm-library/ Sometimes it could be handy that you read effectively what users are already saying multiple times on forum @@Luke I know you guys are busy fixing all things on different platforms, but sometimes it could be done more efficiently, so users don't have to repeat themselves.
jinxy88 0 Posted March 18, 2018 Author Posted March 18, 2018 Yes same folder. I was able to reproduce some issues in Theater. It's resolved for the next update to the app. thanks. @@Luke Does this also affects emby for samsung smart tv's ?
jinxy88 0 Posted March 18, 2018 Author Posted March 18, 2018 Strange, cause i cant get it to work here either...tought its related to emby theater.
jinxy88 0 Posted April 2, 2018 Author Posted April 2, 2018 ok, so after many tests i finally got it to work @@Luke , the problem is this only works if you allow transcoding, if you uncheck this box it will not work no matter what you try. the problem is by using strm with passthrough thats exactly what i wanted to avoid...transcoding Maybe you guys can find a way for subs to work without "Allow video playback that requires transcoding without re-encoding" enabled
Luke 42245 Posted April 2, 2018 Posted April 2, 2018 ok, so after many tests i finally got it to work @@Luke , the problem is this only works if you allow transcoding, if you uncheck this box it will not work no matter what you try. the problem is by using strm with passthrough thats exactly what i wanted to avoid...transcoding Maybe you guys can find a way for subs to work without "Allow video playback that requires transcoding without re-encoding" enabled It just depends on the subtitle format and the app you're using. Again it's not necessarily a bug to be fixed. If you provide the information requested in how to report a media playback issue, than i can provide a more detailed answer. Thanks.
jinxy88 0 Posted April 2, 2018 Author Posted April 2, 2018 It just depends on the subtitle format and the app you're using. Again it's not necessarily a bug to be fixed. If you provide the information requested in how to report a media playback issue, than i can provide a more detailed answer. Thanks. Ok @@Luke u can try with the strm files and subs i sent u a while ago. With that 4 tick enabled subs are working on webapp and emby theater but not on emby for samsung ks7500, but it transcodes. Without that tick enabled no external subs working on any app. The subs are all srt files placed in the same folder as strm.
Luke 42245 Posted April 2, 2018 Posted April 2, 2018 I tried one and it worked fine for me. can you give a specific example? Also what version of the samsung app? thanks.
