paulsalter 84 Posted March 22, 2018 Posted March 22, 2018 Andy, I think that upcoming section is just coming from tvdb, nothing todo with recordings/epg, I have removed Emby dvr and see similar in the upcoming section Not sure why Luke keeps going back to SxxExx, these shows dont have this data Emmerdale records today at 7pm The only data we have is date, so emby checks tvdb and picks up the first episode for today - this is correct Emmerdale records today at 8pm The only data we have is date, so Emby checks against tvdb and picks up the first episode for today- this is wrong
andyblac644 69 Posted March 22, 2018 Author Posted March 22, 2018 (edited) Andy, I think that upcoming section is just coming from tvdb, nothing todo with recordings/epg, I have removed Emby dvr and see similar in the upcoming section Not sure why Luke keeps going back to SxxExx, these shows dont have this data Emmerdale records today at 7pm The only data we have is date, so emby checks tvdb and picks up the first episode for today - this is correct Emmerdale records today at 8pm The only data we have is date, so Emby checks against tvdb and picks up the first episode for today- this is wrong yeah, i understand that. but emby has data from TVDB so imo it should use it, once recording has completed. Edited March 22, 2018 by andyblac644
paulsalter 84 Posted March 22, 2018 Posted March 22, 2018 Good luck with getting them to change anything I have been through this many times in the past, perhaps you can have more luck with the devs This is the main reason i ditched Emby DVR
Luke 42244 Posted March 22, 2018 Posted March 22, 2018 I don't get why you think say that. We change things everyday based on feedback.
andyblac644 69 Posted March 22, 2018 Author Posted March 22, 2018 (edited) @@Luke anything you can do to better control this date / time base shows ?, when TVDB does have season / episode numbers ? Edited March 22, 2018 by andyblac644
Luke 42244 Posted March 22, 2018 Posted March 22, 2018 Well this actually isn't specific to dvr although i understand why you'd think that. The same situation could happen if you setup a tv series from scratch with similarly named files. I think a safe approach would be that if tvdb has multiple episodes listed from that same date, then we could correlate based on that.
andyblac644 69 Posted March 23, 2018 Author Posted March 23, 2018 with the change to filename Eastenders is no longer get scraped correctly it is detec scraped as a 2004 season / episodes.
Luke 42244 Posted March 23, 2018 Posted March 23, 2018 Right, on beta, that is to be expected, for now at least. I gave you the dvr naming, but the library scan has never supported those wmc style dates and we have to get that done before this gets released. Thanks. 1
andyblac644 69 Posted March 23, 2018 Author Posted March 23, 2018 (edited) Right, on beta, that is to be expected, for now at least. I gave you the dvr naming, but the library scan has never supported those wmc style dates and we have to get that done before this gets released. Thanks. also the name is a bit confusing, could we use name_2018-22-03_1930.ts name_2018-03-22_1930.ts ? Edited March 23, 2018 by andyblac644
Senna 368 Posted March 23, 2018 Posted March 23, 2018 I hope not, because with yyyy-dd-mm_time you get your dvr recordings all scrambled up, like this in file explorer when sorted by name: 2018-01-03_1930 2018-05-02_1930 2018-10-03_1930 2018-22-02_1930 2018-22-03_1930 For sorting options I favor yyyy-mm-dd_time and after seeing the above I'm wondering why you favor yyyy-dd-mm ?
andyblac644 69 Posted March 23, 2018 Author Posted March 23, 2018 (edited) @@Senna sorry typo, should be 2018-03-22, i'll update post Edited March 23, 2018 by andyblac644 1
paulsalter 84 Posted March 23, 2018 Posted March 23, 2018 Are the dates used in filenames the date of recording or the original aired date? ideally it should be original aired date
andyblac644 69 Posted March 23, 2018 Author Posted March 23, 2018 (edited) Are the dates used in filenames the date of recording or the original aired date? ideally it should be original aired date @@paulsalter original air date, that why time is missing from Corrie / Emmerdale, as SD data does not have time, @@Luke is going to try to do something for those. Edited March 23, 2018 by andyblac644
paulsalter 84 Posted March 23, 2018 Posted March 23, 2018 Thanks Andy Looking forward to seeing these changes
andyblac644 69 Posted March 26, 2018 Author Posted March 26, 2018 (edited) @@Luke wrong time in file name, due to BST ? should be 19:30 Edited March 26, 2018 by andyblac644
Luke 42244 Posted March 26, 2018 Posted March 26, 2018 In one of the recent betas i changed it to use local time rather than utc.
Senna 368 Posted March 26, 2018 Posted March 26, 2018 My guide provider delivers UTC times and can confirm that recent Emby server beta fixed dvr filename timestamp, to not to use the UTC timestamp from xml, but use my local time. What timestamp is in your xmltv listing @@andyblac644 for the episodes you recorded ?
andyblac644 69 Posted March 27, 2018 Author Posted March 27, 2018 (edited) My guide provider delivers UTC times and can confirm that recent Emby server beta fixed dvr filename timestamp, to not to use the UTC timestamp from xml, but use my local time. What timestamp is in your xmltv listing @@andyblac644 for the episodes you recorded ? i'm using SD guide data. and Emby Server Version 3.3.1.9 beta Edited March 27, 2018 by andyblac644
andyblac644 69 Posted March 27, 2018 Author Posted March 27, 2018 @@Luke you nearly there, the date and time are now in file name, but they are 1hr hour off, also, the 2 episodes now have the correct synopsis, but they share the 1st episode title can you fix this ?
paulsalter 84 Posted March 27, 2018 Posted March 27, 2018 Are these formats compatible with other systems? I see no mention of the underscore being a valid item for date based shows on other systems (the original dash is), thinking kodi/plex
andyblac644 69 Posted March 27, 2018 Author Posted March 27, 2018 Are these formats compatible with other systems? I see no mention of the underscore being a valid item for date based shows on other systems (the original dash is), thinking kodi/plex not sure.
paulsalter 84 Posted March 27, 2018 Posted March 27, 2018 just going by the formats here (about half way down) https://kodi.wiki/view/naming_video_files/TV_shows
Luke 42244 Posted March 27, 2018 Posted March 27, 2018 just going by the formats here (about half way down) https://kodi.wiki/view/naming_video_files/TV_shows These are longtime traditional windows media center dvr formats. I would guess that most do support them, even if they are not documented. 1
Senna 368 Posted March 27, 2018 Posted March 27, 2018 But still the fact remains that with current dvr naming, copying an Emby dvr recording only, to an Emby TV Shows library, doesn't get the file scraped in Emby. For my setup I only see "program name_date_time_episode name". Is that still work in progress Luke, that we eventually also get Season/Episode in dvr filename when available ?
andyblac644 69 Posted March 27, 2018 Author Posted March 27, 2018 But still the fact remains that with current dvr naming, copying an Emby dvr recording only, to an Emby TV Shows library, doesn't get the file scraped in Emby. For my setup I only see "program name_date_time_episode name". Is that still work in progress Luke, that we eventually also get Season/Episode in dvr filename when available ? it only uses this naming format when Season / Episode is not available in epg guide data.
