PenkethBoy 2068 Posted March 22, 2018 Posted March 22, 2018 you did uninstall the other version first?
schogobong 3 Posted March 22, 2018 Posted March 22, 2018 Yes, I uninstalled the most current version of Qmono and then installed the previous version (5.10.0.140). The installation worked fine, unfortunately it didn't resolve my issue. I am now going back to the version before last (5.4.1.6.0). 5.4.1.6.0 was released on November 20th 2017. Emby was definitely working for me back then. So if this doesn't resolve my issue, then I'm assuming that something else is wrong.
schogobong 3 Posted March 22, 2018 Posted March 22, 2018 You have got to be kidding me - that did the trick Thank you both so much for your support Luke and PenkethBoy! So for all the tl;dr: Issue: When trying to access itemdetails or playing a movie, Emby starts loading, which is indicated by a spinning circle. However, the circle keeps spinning without ever showing anything. This was first noticed on March 19th in my case (while I don't use Emby every single day). I could access my library without any major issues (just smaller bugs), just displaying itemdetails and playing movies wasn't working. Solution: Uninstalling the latest Qmono version and instead installing the one before last (V5.4.1.6.0) via manual installation. Then I shut down Emby and restarted Emby through the App Center. That is it.
TTuna99 1 Posted May 23, 2018 Posted May 23, 2018 Hello all So, i have the same problem However, my Nas is the ts-128A and there isn't a 5.4.1.6.0V of Qmono to install. Still didn't find a solution Can you help me please? Thank you! You have got to be kidding me - that did the trick Thank you both so much for your support Luke and PenkethBoy! So for all the tl;dr: Issue: When trying to access itemdetails or playing a movie, Emby starts loading, which is indicated by a spinning circle. However, the circle keeps spinning without ever showing anything. This was first noticed on March 19th in my case (while I don't use Emby every single day). I could access my library without any major issues (just smaller bugs), just displaying itemdetails and playing movies wasn't working. Solution: Uninstalling the latest Qmono version and instead installing the one before last (V5.4.1.6.0) via manual installation. Then I shut down Emby and restarted Emby through the App Center. That is it.
Luke 42240 Posted May 23, 2018 Posted May 23, 2018 What have you tried to do so far? What Qmono is available for your NAS?
PenkethBoy 2068 Posted May 23, 2018 Posted May 23, 2018 @@Luke the Ts-128A cpu is Realtek RTD1295 quad-core 1.4GHz processorArchitecture: 64-bit ARM A53Hardware encryption acceleration engine may depend on what version of QTS he is running as well
TTuna99 1 Posted May 23, 2018 Posted May 23, 2018 Qmono is V5.12.0.266 (2018/05/23) And yes, the CPU is the one PenkethBoy said. I've tried previous Qmono versions and disabling subtitles... Do you think it has to do with ffmpeg?? I have version 4.0.0 Emby version is 3.4.0.0 (there is no 3.4.0.1 for my NAS) QTS is 4.3.4.0588 (2018/05/19) What do you mean with "Hardware encryption acceleration engine"? Thank you
Luke 42240 Posted May 24, 2018 Posted May 24, 2018 I'm a little unclear on what your issue is. Can you please describe your problem in more detail? thanks.
schogobong 3 Posted May 24, 2018 Posted May 24, 2018 If 5.4.1.6.0V is not available for your NAS, you could also try any other version that was released before March 17th (that's when the updates were released that messed with my system at least).
Luke 42240 Posted May 24, 2018 Posted May 24, 2018 I'm guessing yes. Hopefully you can at least stay on something 5.2 or higher because that's going to be needed soon.
TTuna99 1 Posted May 26, 2018 Posted May 26, 2018 The problem is that my NAS is the TS-128A, wich is very recent, so there aren't previous versions of Qmono.... My issue is the same as this thread owner... If the movie or series has media info, when i open it, the details start loading and the circle keeps spining forever, the video never starts... If i turn off media info, such as the TVDB or IMDB, the files play fine... Strange.... 1
Luke 42240 Posted May 28, 2018 Posted May 28, 2018 The problem is that my NAS is the TS-128A, wich is very recent, so there aren't previous versions of Qmono.... My issue is the same as this thread owner... If the movie or series has media info, when i open it, the details start loading and the circle keeps spining forever, the video never starts... If i turn off media info, such as the TVDB or IMDB, the files play fine... Strange.... Can you please attach the emby server log from when you experienced a problem? You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
igrgic 0 Posted July 22, 2018 Posted July 22, 2018 Which is the solution for problem with media info. I have QNAP TS-128A.
Luke 42240 Posted July 22, 2018 Posted July 22, 2018 Which is the solution for problem with media info. I have QNAP TS-128A. Hi there, can you please describe the problem that you're having? Thanks !
igrgic 0 Posted July 22, 2018 Posted July 22, 2018 If the movie or series has media info, when i open it, the details start loading, but never show details, and the circle keeps spining forever,
Luke 42240 Posted July 22, 2018 Posted July 22, 2018 Please attach the information requested in how to report a problem. thanks !
igrgic 0 Posted July 24, 2018 Posted July 24, 2018 (edited) Hardware:NAS QNAP TS-128A SOftware:QTS 4.3.4.0644QMono V5.12.0.266 from https://www.qnapclub.eu/en/qpkg/193ffmpeg static V4.0.0. from https://www.qnapclub.eu/en/qpkg/379Emby server 3.5.0.0. from https://www.qnapclub.eu/en/qpkg/343 Clients:Chrome on Win 10 64 bitEmby Teather on Win 10 64 bitSONY Bravia KDL-55W756, Android 7.0 Problem:- when I want to open movie, the details start loading, but never show details, and the circle keeps spining forever. - the same problem with all clients Hardware:NAS QNAP TS-128A SOftware:QTS 4.3.4.0644QMono V5.12.0.266 from https://www.qnapclub.eu/en/qpkg/193ffmpeg static V4.0.0. from https://www.qnapclub.eu/en/qpkg/379Emby server 3.5.0.0. from https://www.qnapclub.eu/en/qpkg/343 Clients:Chrome on Win 10 64 bitEmby Teather on Win 10 64 bitSONY Bravia KDL-55W756, Android 7.0 Problem:- when I want to open movie, the details start loading, but never show details, and the circle keeps spining forever. - the same problem with all clients embyserver.txt embyserver-63667987200.txt.txt embyserver-63667987198.txt Edited July 24, 2018 by igrgic
Luke 42240 Posted July 24, 2018 Posted July 24, 2018 @@igrgic, I see you're using the qnap community package. Can you please switch to our official package? Instructions can be found on our website: https://emby.media/download Thanks !
igrgic 0 Posted July 24, 2018 Posted July 24, 2018 I can not install official package because error: Type Date Time Users Source IP Computer name Content Error 24.07.2018 23:11:23 System 127.0.0.1 localhost [App Center] Failed to install Emby Server 3.5.1.0. Installation package is incompatible. Use the correct package. ---------------Prepoznaj jezikAfrikaansAlbanskiAmharskiArapskiArmenskiAzerbajdžanskiBanglaBaskijskiBjeloruskiBosanskiBugarskiBurmanskiCebuanoČeškiDanskiEngleskiEsperantoEstonskiFinskiFrancuskiGalicijskiGrčkiGruzijskiGudžaratskiHaićanski kreolskiHausaHavajskiHebrejskiHindskiHmongHrvatskiIgboIndonezijskiIrskiIslandskiJapanskiJavanskiJidišJorupskiKarnatačkiKatalonskiKazaškiKineski (pojednost.)Kineski (tradicionalni)KirgiskiKmerskiKorejskiKorzičkiKurdskiLaoskiLatinskiLatvijskiLitavskiLuksemburškiMađarskiMakedonskiMalajalamskiMalajskiMalgaškiMalteškiMaorskiMarathskiMongolskiNepalskiNizozemskiNorveškiNjandžaNjemačkiPandžapskiPaštunskiPerzijskiPoljskiPortugalskiRumunjskiRuskiSamoanskiSesotskiShonaSindskiSinhaleškiSlovačkiSlovenskiSomalskiSrpskiSundanskiSvahiliŠkotski gaelskiŠpanjolskiŠvedskiTadžičkiTagalogTajlandskiTalijanskiTamilskiTeluškiTurskiUkrajinskiUrdskiUzbečkiVelškiVijetnamskiXhosaZapadnofrizijskiZuluHrvatski I can not
PenkethBoy 2068 Posted July 24, 2018 Posted July 24, 2018 @@Luke the cpu is Realtek RTD1295 quad-core 1.4GHz processor Architecture: 64-bit ARM A53Hardware encryption acceleration engine and the OP is running the latest firmware QTS 4.3.4.0644 - which is the same as my TS-853A x64 In theory it should run the latest .netcore 3.5.1.0 package Although the CPU may be unknown to the latest package build install script Its very much an entry level NAS so speed and power will be limited
Luke 42240 Posted July 24, 2018 Posted July 24, 2018 My mistake, sorry. I saw 64 bit in the server log and assumed incorrectly. So we don't currently have an official package but stay tuned. We might have something for you soon.
Luke 42240 Posted July 24, 2018 Posted July 24, 2018 For your current installation, based on this log, can you try turning off the server's Dlna features and see if that helps? Thanks !
igrgic 0 Posted July 25, 2018 Posted July 25, 2018 I tried to disable server's DLNA on Emby, but still no change. I tried to disable general DLNA on QANP, but still no change. I know the CPU is weak but I just need direct play, not transcoding.
