diogosena 0 Posted May 7, 2018 Author Posted May 7, 2018 Can you please try 3.4.1.? Thanks. new error... embyserver.txt
diogosena 0 Posted May 8, 2018 Author Posted May 8, 2018 What is the issue? the same, exited by itself
diogosena 0 Posted May 8, 2018 Author Posted May 8, 2018 (edited) @@Luke another crash today. I have to say, 3.3 was a lot more stable than 3.4 embyserver.txt Edited May 8, 2018 by diogosena
Luke 42246 Posted May 8, 2018 Posted May 8, 2018 Unfortunately there is nothing obvious here for me to go on. We're looking into it though. Thanks.
diogosena 0 Posted May 8, 2018 Author Posted May 8, 2018 Unfortunately there is nothing obvious here for me to go on. We're looking into it though. Thanks. Thank's, if you need some help testing, send me an extra debug/more verbose version.
Luke 42246 Posted May 8, 2018 Posted May 8, 2018 We're going to be updating to the 2.1 version of the .net core runtime very soon, so we'll see if that has an impact. Thanks.
diogosena 0 Posted July 18, 2018 Author Posted July 18, 2018 (edited) We're going to be updating to the 2.1 version of the .net core runtime very soon, so we'll see if that has an impact. Thanks. Updated to 3.5 stable, emby crashed overnight, one of my cpu cores stuck at 100%, had to kill -9, (kill -15 didnt work) Also tried emby arm on docker (in another arm device), the process crash and restarts as soon as I try to open library webpage (everytime, no exceptions, cant even see thumbnails images). I'm so tired of these bugs that i had to do a health check script to detect those crashes/freezes and restart emby. Edited July 18, 2018 by diogosena
Luke 42246 Posted July 18, 2018 Posted July 18, 2018 Can you please attach the emby server log? The crash could very possibly have come from a third party plugin, and I can help you identify that and remove the plugin. Thanks.
diogosena 0 Posted July 18, 2018 Author Posted July 18, 2018 Can you please attach the emby server log? The crash could very possibly have come from a third party plugin, and I can help you identify that and remove the plugin. Thanks. I'm sending you the entire log folder, both from dpkg and from docker install. Hope it helps. logs_docker.zip logs_dpkg.zip
Luke 42246 Posted July 19, 2018 Posted July 19, 2018 Ok, I'm afraid we just haven't tested your scenario inside of a chroot. We will try to allocate some resources into doing this. Thanks.
diogosena 0 Posted July 19, 2018 Author Posted July 19, 2018 Ok, I'm afraid we just haven't tested your scenario inside of a chroot. We will try to allocate some resources into doing this. Thanks. thanks, just remember, the docker logs are from another test device, without chroot.
diogosena 0 Posted July 30, 2018 Author Posted July 30, 2018 Ok, I'm afraid we just haven't tested your scenario inside of a chroot. We will try to allocate some resources into doing this. Thanks. Still doing tests here, since I disabled "DLNA Playto" feature, i haven't had a single crash (4 days already). The problem is, this feature is the main reason I use emby, please try to fix it.
