Luke 42246 Posted April 4, 2018 Posted April 4, 2018 What do you mean by "didn't worked"? Did you get an error message? If so, what did it say?
diogosena 0 Posted April 4, 2018 Author Posted April 4, 2018 What do you mean by "didn't worked"? Did you get an error message? If so, what did it say? No error message.. I select my lg webos tv as the renderer in the emby android app, but when i click play, nothing happens, a restart in the emby process usually solves that.
Luke 42246 Posted April 5, 2018 Posted April 5, 2018 Ok. I don't see any issues on a webos 3 TV although admittedly i do not have a 1.x TV for testing.
diogosena 0 Posted April 10, 2018 Author Posted April 10, 2018 Ok. I don't see any issues on a webos 3 TV although admittedly i do not have a 1.x TV for testing. Another log, this time its really a crash, emby process is missing (seems like a crash while trying to download subtitles.) embyserver.txt
Luke 42246 Posted April 10, 2018 Posted April 10, 2018 Since you're running betas I would make sure to stay up to date with the latest. thanks.
diogosena 0 Posted April 11, 2018 Author Posted April 11, 2018 Since you're running betas I would make sure to stay up to date with the latest. thanks. Updated, same problem today. embyserver.txt
Luke 42246 Posted April 11, 2018 Posted April 11, 2018 Ok. The log looks OK. Unfortunately without a webos 1.x device for testing I'm not sure what it is right now. I'll see if I can think of anything. Thanks.
diogosena 0 Posted April 11, 2018 Author Posted April 11, 2018 Ok. The log looks OK. Unfortunately without a webos 1.x device for testing I'm not sure what it is right now. I'll see if I can think of anything. Thanks. You misunderstood, there's two problems, 1. DLNA server missing sometimes 2. Spontaneous emby crash/exit while doing nothing These last two logs, are about problem 2.
diogosena 0 Posted April 14, 2018 Author Posted April 14, 2018 Are you still seeing this? yes, nearly daily.
diogosena 0 Posted April 17, 2018 Author Posted April 17, 2018 @@Luke with last version dlna dont work with any client.
diogosena 0 Posted April 17, 2018 Author Posted April 17, 2018 (edited) @@Luke another crash while doing nothing.. (I have flexget, tvheadend, qbittorrent and enigma2, running without problems on the same device) These logs are useful? embyserver.txt Edited April 17, 2018 by diogosena
Luke 42246 Posted April 17, 2018 Posted April 17, 2018 Can you try removing the kodi sync plugin and see if that makes a difference? thanks.
diogosena 0 Posted April 17, 2018 Author Posted April 17, 2018 Can you try removing the kodi sync plugin and see if that makes a difference? thanks. i just reverted to stable, if it crash again, i do that.
diogosena 0 Posted April 19, 2018 Author Posted April 19, 2018 @@Luke Using latest stable, server Idle, Emby is unresponsive and using 100% of one cpu core. Now I'm uninstalling the kodi plugin and trying again. server-63659692803.txt
Luke 42246 Posted April 19, 2018 Posted April 19, 2018 Well in this log it looks like you already had the kodi plugin installed ?
diogosena 0 Posted April 19, 2018 Author Posted April 19, 2018 yes, i uninstalled as soon as I got that error, if/when it happens again, i'll post the log here.
diogosena 0 Posted April 23, 2018 Author Posted April 23, 2018 Well in this log it looks like you already had the kodi plugin installed ? Just a feedback, no problems since runnning stable without the kodi plugin. (no crashes, no dlna server missing, no 100% cpu)
diogosena 0 Posted May 2, 2018 Author Posted May 2, 2018 Thanks for the feedback. Got a crash today (emby process exited by itself, was running since 29/04 13:22:35 ) server-63660816004.txt
diogosena 0 Posted May 5, 2018 Author Posted May 5, 2018 Ok. I would suggest trying the new release. Thanks. unfortunately, this last stable version has the same dlna server problem as the betas. i was trying to cast, and can't find the server. emby was still running and can play just fine, (only not trough dlna)
diogosena 0 Posted May 7, 2018 Author Posted May 7, 2018 Ok. I would suggest trying the new release. Thanks. This time process exited by itself. embyserver.txt
